I would like to generate some diagnostic export for support.
I found that the fw_printenv
command, executed because i checked “firmware” in the list of modules to export, has some issue.
root 18249 0.0 0.0 1364 1052 ? S Aug09 0:00 /bin/sh /usr/share/diagnostics/diagnostics.sh -b -o /tmp/diagnostics-2024-08-09-17-11-43_63620226.out certgen cron dmesg dns filesystems firewall fi
root 22426 0.0 0.0 1372 600 ? S Aug09 0:00 /bin/sh modules/module.sh ./modules/18_firmware.module run
root 22427 99.6 0.3 7416 6844 ? R Aug09 1618:39 tail -n 100000
root 23101 1.8 0.0 940 616 ? S Aug09 29:39 fw_printenv
I’m running on latest stable version:
k | v |
Device | Turris Omnia |
reForis version | 1.5.0 |
Turris OS version | 7.0.2 |
Turris OS branch | HBS |
Kernel version | 5.15.148 |
Executing the command display this and never stop:
Warning on /dev/mtd0: Attempted to read 65536 bytes but got 0
Here is the config file (found somewhere on another topic)
root@turris:~# cat /etc/fw_env.config
/dev/mtd0 0xf0000 0x10000 0x10000
root@turris:~# strings /dev/mtd0 | grep 'U-Boot 20'
U-Boot 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
I could make an export without firmware, but I think support need it to understand why the official SFP+ module doesn’t work on my device =/
Any help is welcome.
Thanks.
