I have problem with setuping Turris Shield and Turris Omnia (tried both these devices) on xdsl as ppoe connection (xdsl modem is properly setup in a bridge mode with public static IPv4 address - with disabled IPv6)
- Turris Shield:
Factory reset - connected to xdsl modem - on Shield site I’ve setup only the WAN Connection (as a PPoe (with PAP/CHAP username and password o2). And on this screen I get error - IPv4 Gateway connectivity. IPv4 connectivity is OK.
This error doesn’t change even I change DNS settings (Use/don’t use forwarding (providers dns, CZnic DNS), use/don’t use DNSSec)
Device:CZ.NIC Turris Mox Board
reForis version: 0.9.1
Turris OS version: 5.1.10
Kernel version: 4.14.222
2.Turris Omnia
Therefore I’ve tried Turris Omnia - factory reset - and during the wizzard when I setup the PPoe connection it freezed on checking connection.
Nevermind - I’ve skipped this wizzard and setup there the WAN setting for PPoe (with default LAN settings)
Ipv4 Protocol PPPoE
PAP/CHAP username,password o2
IPv6 protocol - disable IPv6
Connection test:
Ipv4 connectivity - Error
IPv4 gateway connectivity - Error
moreover in DNS setting:
use forwarder (Google or CZnic) - enable/disable DNSsec - I get everytime DNS and DNSsec Error
Device: Turris Omnia
Turris OS version: 3.11.23
Kernel version: 4.4.199-a890a5a94ebb621f8f1720c24d12fef-1
Why I get everytime connection error?
and my next guestion is: I’ve tried to setup VPN (on shield you can just enable it - create certification authority and setup UDP or TCP) I’ve tried both option bud I didn’t able to connect to my public IP over VPN.
When I did the same on Turris Omnia - I was able to connect to VPN.
Is the Shield able to use as a VPN server and work is for anybody?
Best regards
Vaclav
