hello i hope this is the correct forum section, can you help/suggest?
i manage two Omnia, one is my personal, and in both i have verified this behaviour.
in streaming low latency/live video streams an issue appears (hickups/disconnection) to arise while using the Omnia.
in both cases connecting directly to the router modem solves the issue, so i wonder if there is something wrong with the router modem distribution or if there is a certain setting i can use to solve this on the Omnia. thank you
Your issues sounded exactly like the bufferbloat issue. It’s been a while since I’ve seen it discussed and it’s not really the easiest thing to search for.
It should probably be in a standard list of things to check on initial setup.
