Well it happened again,something appears to be running on the Turris Omnia in the early hours that really screws up the whole configuration. Last night was by far the worst as follows:
Woke up and started to work at around 2am; none of my VLAN1 / Eth0 Port Devices seemed to be working so connected via Wifi. Strangely my Linux Server on VLAN2 / Eth2 was working fine and I could connect to it from myh computer on VLAN1.
While i was connected to the Omnia interface via Wifi that died also, leaving me with no connection to the Omnia router at all, however another device I had connected via Wifi was connecting to the Internet without any problems.
I rebooted (powered down) the box and was able to connect to the Omnia Admin & Luci interface via Wifi, however when I connected via SSH, all the logs list were from the moment I switched the the Omnia back on. There were no Archived Logs and there were no IPTables logs. After spending 2 hour trying to get the eth0 / VLAN1 to work, i decided to restore from a Backup
So got up at 2am to do some work ready for the morning and spent the whole time trying to work out what had gone wrong since I was last Logged onto my LAN.
Something us not quite right; what runs on the Box as part of a maintenance process that could screw up my Omnia so badly?
Any feedback would be appreciated, as I cannot keep doing Factory Reset and Recovery from Backups on a regular basis!!. I’m sure the box will only cope with me doing this for so many time
