Alternatively, it might be possible to set it up with the config file:
Use a USB Stick with a storage partition that normally works on Linux (like EXT4, BTRFS, FAT32)
Place a file in the main (root) directory here: medkit-config.json
"foris_password": "password you enter in the web ui",
"wireless": {
"ssid": "Turris Router Name",
"key": "Wifi password that users enter"
Change these values!
Insert the USB Stick in the omnia, wait a bit, press the Reset button long until 4 LEDs glow. Let go and it should (?) reset and apply the override config, changing these passwords
This didnt work for me (before the first setup at least)
To be fair, it is pretty unusual at least for home routers, to not open a wifi network by default. But I like this more secure approach.
The packaged documentation is extremely barebones. A setup guide would be very useful.
From these first steps on, the web UI is AWESOME. But the first steps are not easy to find.
