wolfie
November 18, 2021, 2:52pm
1
Hey!
I have a Turris Omnia 2020.
I replaced the original TP link router with the Turris and the previously trouble free network started to be absolutely awful.
disconnecting devices
very weak signal in the house
no signal in places where 30 % was before
Any advice? I thought this hardware was top notch but so far I’m very disappointed.
Thanks in advance for any tips.
I found this for example, but as I am no expert, at most a very advanced user,
I preferred to go here first.
https://feeding.cloud.geek.nz/posts/fixing-turris-omnia-wifi-quality/
Omnia hardware
Omnia HW tweaks
I think this will help a lot of Turris Omnia users to solve slow WiFi problem. From the beginning I was quite satisfied with WiFi performance. My setup was personal 2,4 WiFi on first WiFi card (the dual one) and guest 2,4 on second card. About a...
Reading time: 6 mins 🕑
Likes: 14 ❤
I tried the basic wifi combinations - 2.4ghz, 5ghz / 20mhz / 40mhz = same results
Currently : 2.4ghz, 20Mhz
I have diagnostics log if somebody seems it useful, just dont want to share straight away.
Maybe your wifi coverage has changed. If you live in rural area try to check with WifiAnalyzer app channel coverage.
wolfie
November 18, 2021, 3:10pm
3
Thanks for your reply, but no
The problem occurred immediately after reconnection
the problem disappears when I use the TP link router
I have internet via fiber optic cable, wifi is only home network
So thats just Omnia issue.
hagrid
November 18, 2021, 3:11pm
4
Hello.
Can you please open the device (use the PH1 or PH2 screwdriver) and take a picture of the pigtails connecting the WiFi cards with the duplexers?
wolfie
November 18, 2021, 3:28pm
5
@hagrid
Definitely, thanks for quick reply, images below:
deleted
hagrid
November 18, 2021, 3:31pm
6
Thank you very much. So, it seems the pigtails are connected in order (big card to 5.6GHz path and small card to 2.4GHz path).
Can you verify you have not mismatched the configuration? Like, the big card is set to broadcast on 5GHz band and not on 2.4GHz band?
wolfie
November 18, 2021, 3:36pm
7
@hagrid
If you mean the Wifi options in the settings in the reTurris environment:
Wifi 1 (5ghz + 2Ghz)
Wifi 2 (2ghz)
I tried all combinations.
(Turn off turn on 5ghz, just 5ghz, just 2ghz on 1 or 2 or in parallel, as well as I wrote, I’ve also tried the alternative bands 20mhz/40mhz)
I left the current setting at Wifi 1 : 2.4ghz because I found somewhere that the transmitter on Wifi 1 should be stronger (but no change.)
hagrid
November 18, 2021, 3:44pm
8
One more thing… have you set the correct timezone?
Can you paste here the output of uci show wireless
(do not forget to redact the keys)
wolfie
November 18, 2021, 3:57pm
9
@hagrid
Due to LuCI & reForris timezone and time match.
uci show wireless
wireless.radio0=wifi-device
wireless.radio0.type=‘mac80211’
wireless.radio0.macaddr=‘macadresswashere’
wireless.radio0.country=‘CZ’
wireless.radio0.channel=‘auto’
wireless.radio0.disabled=‘0’
wireless.radio0.hwmode=‘11g’
wireless.radio0.htmode=‘HT20’
wireless.default_radio0=wifi-iface
wireless.default_radio0.device=‘radio0’
wireless.default_radio0.network=‘lan’
wireless.default_radio0.mode=‘ap’
wireless.default_radio0.hidden=‘0’
wireless.default_radio0.encryption=‘psk2+ccmp’
wireless.default_radio0.wpa_group_rekey=‘86400’
wireless.default_radio0.disabled=‘0’
wireless.default_radio0.ssid=‘namewashere’
wireless.default_radio0.key=‘passwashere’
wireless.radio1=wifi-device
wireless.radio1.type=‘mac80211’
wireless.radio1.channel=‘11’
wireless.radio1.hwmode=‘11g’
wireless.radio1.macaddr=‘macadresswashere’
wireless.radio1.htmode=‘HT20’
wireless.radio1.country=‘CZ’
wireless.radio1.disabled=‘1’
wireless.default_radio1=wifi-iface
wireless.default_radio1.device=‘radio1’
wireless.default_radio1.network=‘lan’
wireless.default_radio1.mode=‘ap’
wireless.default_radio1.ssid=‘namewashere’
wireless.default_radio1.hidden=‘0’
wireless.default_radio1.encryption=‘psk2+ccmp’
wireless.default_radio1.wpa_group_rekey=‘86400’
wireless.default_radio1.key=‘passwashere’
wireless.default_radio1.disabled=‘1’
wireless.guest_iface_0=wifi-iface
wireless.guest_iface_0.disabled=‘1’
wireless.guest_iface_0.device=‘radio0’
wireless.guest_iface_1=wifi-iface
wireless.guest_iface_1.disabled=‘1’
wireless.guest_iface_1.device=‘radio1’
when I configured my omnia, I somewhere read NOT to run both cards ad 2.4GHz because they may interfere with each other.
You should be able to run standard and guest network on both interfaces,
try disabling one of those cards (1st one), optionally move it to 5ghz band
wolfie
November 19, 2021, 7:07pm
12
Have tried that already.
Current setting is
Wifi 1: 2.4 Ghz / 20mhz
Wifi 2 : Disabled
I have tried also the switched option
Wifi 1 : Disabled
Wifi 2: 2.4 Ghz / 20mhz
Without change.
Remember, that 5GHz wifi card is connected to 5GHz antenna connectors at diplexers, so it is necessary to reconnect antenna cables to 2,4 GHz connectors at diplexers too when you are going to use this card at 2,4 GHz.
Don’t run the 1st adapter in 2.4GHz mode, run only as 5GHz.
Once I tried disabling the 2nd adapter and setting the 1st one as 2.4GHz, it had poor performance and was unstable.
wolfie
December 18, 2021, 2:21am
16
DM. Waiting for reply, thx-
