Turris MOX Wifi-6 Upgrade kit - what modules needed?
Hi there,
what modules do I need when upgrading the wifi on my MOX to Wifi-6 with the official MOX-Wifi-6-Upgrade kit? Is it module B and G?
Or does the upgrade kit just replace the wifi card on Mox B?
Thanks for any hint and best regards,
David
It replaces your currently installed mPCIe card, no additional modules needed.
Ah, ok. The current wifi card has 3 antennas connected, but the Wifi-6 card has only 2 antennas. So in the end I can use 2 of the current installed antennas for wifi-6, correct?
Thanks, David
