I have what appears to be a simple problem but I cannot seem to figure it out. For some reason, at random my Turris MOX appears to not allow connections to the internet. You could still connect to the router but you are unable to connect to the internet (WAN). I can confirm the connection works fine on LAN. I received a Early Bird MOX: Classic w/ Module G. Anyone mind helping me troubleshoot this issue with the Wi-Fi?
there were some fixes over the time that worked for me to get stable wifi:
for SDIO wifi (which is most probably what you have set up?):
ssh to your router
run wget -O /lib/firmware/mrvl/sd8997_uapsta.bin https://github.com/tmshlvck/turris-debian/raw/master/mox/files/sd8997_uapsta.bin && sync reboot your router
(if you are on latest update above update might not be needed, diff or md5 the bin files first!!!)
Thank you for the reply. It looks like I already have the latest software so I should be good there. I do have logs from a diagnostic when the issue occured and I lost all internet. Here are the logs attached.
