@peci1 : @Hai mentioned in Turris Mox USB (from module A) not working any more (for mass storage) after TOS 6.0 upgrade - #2 by Hai the same issue with an externally powered disk.
I finally have some (good) news.
They managed to reproduce the issue, but only on Mox devices that have an old U-Boot version.
So they asked me which U-Boot version I have on my board. Mine is 2018.11. You can check yours with the following command:
root@turris:~# strings /dev/mtdblock1 | grep "U-Boot 20"
U-Boot 2018.11 (Dec 16 2018 - 12:50:19 +0000)
root@turris:~#
Their conclusion:
Dear Mossroy,
this means that you have old firmware, which is the cause of the issue.
Please install the nor-update package and run it, with commands:
opkg update
opkg install nor-update
nor-updateWe will be sending you back your USB flash drive on monday.
I havenāt tested yet.
Do you have the same U-Boot version as I have?
@jada4p can you check you already have a more recent one? (which would explain why the issue was solved for you since TOS 6.2.2)
Sure:
root@MOXjp:~# strings /dev/mtdblock1 | grep "U-Boot 20"
U-Boot 2021.10-rc3-00050-g7d3fea2c7f (Sep 07 2021 - 18:16:56 +0200)
Thus it is really newer one.
I canāt neither remember nor explain how it happened that there is newer U-boot version installed on my MOX⦠Sorry.
Hello, the nor-update worked on my MOX machine even though the update seemed to fail at first attempt (unrequested run right after package installation). Also I havenāt found nor-update
package, but found similar fix-nor-update
that I installed.
# opkg update
Downloading https://repo.turris.cz/hbk/mox/packages/core/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_core
Downloading https://repo.turris.cz/hbk/mox/packages/core/Packages.sig
Signature check passed.
Downloading https://repo.turris.cz/hbk/mox/packages/base/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_base
Downloading https://repo.turris.cz/hbk/mox/packages/base/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/cesnet/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_cesnet
Downloading https://repo.turris.cz/hbk/mox/packages/cesnet/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_luci
Downloading https://repo.turris.cz/hbk/mox/packages/luci/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/node/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_node
Downloading https://repo.turris.cz/hbk/mox/packages/node/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_packages
Downloading https://repo.turris.cz/hbk/mox/packages/packages/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_routing
Downloading https://repo.turris.cz/hbk/mox/packages/routing/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_telephony
Downloading https://repo.turris.cz/hbk/mox/packages/telephony/Packages.sig
Downloading https://repo.turris.cz/hbk/mox/packages/turrispackages/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_turrispackages
Downloading https://repo.turris.cz/hbk/mox/packages/turrispackages/Packages.sig
# opkg install fix-nor-update
Installing fix-nor-update (1-61) to root...
Downloading https://repo.turris.cz/hbk/mox/packages/turrispackages/fix-nor-update_1-61_aarch64_cortex-a53.ipk
Installing turris-mox-firmware (2.0-3) to root...
Downloading https://repo.turris.cz/hbk/mox/packages/turrispackages/turris-mox-firmware_2.0-3_aarch64_cortex-a53.ipk
Installing turris-nor-update (1.1.0-7) to root...
Downloading https://repo.turris.cz/hbk/mox/packages/turrispackages/turris-nor-update_1.1.0-7_aarch64_cortex-a53.ipk
Configuring turris-mox-firmware.
Configuring turris-nor-update.
Configuring fix-nor-update.
Mount is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
Verifying /dev/mtd0 against secure-firmware.bin ...
18a0c1bc58839cbbc7aef70db637d261 - /dev/mtd0
e12a263c63bd9860cff844763e81e56b - secure-firmware.bin
Failed
Unlocking /dev/mtd0 ...
Erasing /dev/mtd0 ...
Writing from secure-firmware.bin to /dev/mtd0 ...
Verifying /dev/mtd1 against uboot ...
437cb920201336f556abd2b448248714 - /dev/mtd1
bd802eb0ec60fd89f983ac3cd4860fba - uboot
Failed
Cannot parse config file '/etc/fw_env.config': No such file or directory
Unlocking /dev/mtd1 ...
Erasing /dev/mtd1 ...
Writing from uboot to /dev/mtd1 ...
Verifying /dev/mtd3 against rescue ...
e9b30ada843663c579829652847c7bb8 - /dev/mtd3
39f02d9fb36b4258bac37924bcdf570c - rescue
Failed
Unlocking /dev/mtd3 ...
Erasing /dev/mtd3 ...
Writing from rescue to /dev/mtd3 ...
Can''t find anything to flash to 'dtb' partition
# reboot
Warning: Changes performed using anything other than
official web interface reForis are not covered by
Turris support team unless instructed!
______ _ ____ _____
/_ __/_ ____________(_)____ / __ \/ ___/
/ / / / / / ___/ ___/ / ___/ / / / /\__
/ / / /_/ / / / / / (__ ) / /_/ /___/ /
/_/ \__,_/_/ /_/ /_/____/ \____//____/
TurrisOS 6.3.2, Turris Mox
$ su
Password:
# nor-update
e12a263c63bd9860cff844763e81e56b - /dev/mtd0
Success
bd802eb0ec60fd89f983ac3cd4860fba - /dev/mtd1
Success
39f02d9fb36b4258bac37924bcdf570c - /dev/mtd3
Success
U-Boot 2022.07 (Aug 15 2022 - 12:25:08 +0000)
# lsusb
Bus 003 Device 002: ID 0951:1656 Kingston DT Ultimate G2
Bus 002 Device 001: ID 1d6b:0002 Linux 5.15.107 xhci-hcd xHCI Host Controller
Bus 001 Device 001: ID 1d6b:0002 Linux 5.15.107 ehci_hcd EHCI Host Controller
Bus 003 Device 001: ID 1d6b:0003 Linux 5.15.107 xhci-hcd xHCI Host Controller
For me also run right after package installation, second run was not necessary. After it was run strings showed new U-Boot installed:
root@turris:~# opkg install nor-update
Unknown package 'nor-update'.
Collected errors:
* opkg_install_cmd: Cannot install package nor-update.
root@turris:~# opkg install fix-nor-update
Downloading https://repo.turris.cz/hbs/mox/packages/turrispackages/fix-nor-update_1-61_aarch64_cortex-a53.ipk
Downloading https://repo.turris.cz/hbs/mox/packages/turrispackages/turris-mox-firmware_2.0-3_aarch64_cortex-a53.ipk
Downloading https://repo.turris.cz/hbs/mox/packages/turrispackages/turris-nor-update_1.1.0-7_aarch64_cortex-a53.ipk
Failed
Failed
Failed
Can't find anything to flash to 'dtb' partition
Iāll upgrade my MOX to 6.x in the evening today.
Itās peculiar - I see from above that there is even more recent version of U-boat⦠I wonder if I should update to it⦠Could someone from team/support advice?
I can confirm that my USB3 HDD is working after the upgrade of U-Boot.
BusyBox v1.33.2 (2023-04-26 23:52:34 UTC) built-in shell (ash)
______ _ ____ _____
root@turris:~# lsusb
Bus 003 Device 002: ID 0bc2:3322 Seagate Expansion Desk
Bus 002 Device 001: ID 1d6b:0002 Linux 5.15.96 xhci-hcd xHCI Host Controller
Bus 001 Device 001: ID 1d6b:0002 Linux 5.15.96 ehci_hcd EHCI Host Controller
Bus 003 Device 001: ID 1d6b:0003 Linux 5.15.96 xhci-hcd xHCI Host Controller
I can also confirm that the USB3 SSD now continues to work with my MOX after the TOS 6.0 upgrade. Fix was the u-boot upgrade from U-Boot 2018.11 to U-Boot 2022.07 via
Now I have:
- U-Boot 2022.07 (Aug 15 2022 - 12:25:08 +0000)
- TurrisOS 6.3.2, Turris Mox
USB SSD listed (as it was before with TOS 5)
Bus 003 Device 002: ID 0781:55bb SanDisk Portable SSD
Thanks a lot @Mossroy for taking the time and effort to get this solved via Turris Support and lending your hardware!
The Turris guys rock! This is the second super-weird low-level problem solved in the last month
Itās finally working!
What was needed was āonlyā a u-boot upgrade, that can be done by installing package fix-nor-update
(see below)
After that, I upgraded to TOS 6.3.2 and my USB HDD is detected and working fine
BusyBox v1.30.1 () built-in shell (ash)
______ _ ____ _____
TurrisOS 5.4.4, Turris Mox
root@turris:~# opkg update
Downloading https://repo.turris.cz/hbs/mox/packages/core/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/core/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/base/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/base/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/cesnet/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/cesnet/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/luci/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/luci/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/node/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/node/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/packages/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/packages/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/routing/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/routing/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/sidn/Packages.gz
*** Failed to download the package list from https://repo.turris.cz/hbs/mox/packages/sidn/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/telephony/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/telephony/Packages.sig
Downloading https://repo.turris.cz/hbs/mox/packages/turrispackages/Packages.gz
Downloading https://repo.turris.cz/hbs/mox/packages/turrispackages/Packages.sig
Collected errors:
* opkg_download: Failed to download https://repo.turris.cz/hbs/mox/packages/sidn/Packages.gz, wget returned 8.
Collected errors:
Failed
Failed
Failed
root@turris:~# reboot
Yes, Marek did a great job.
Iām very grateful for that, and told him.
However, Iām also very disappointed that it took sooo long for us to be taken seriously. A serious regression lasting 7 months!
Now that we know the root cause, I understand that they did not reproduce it on newer Turris Mox boards (that already had a recent U-boot). But, hey, it was not only one person reporting this, we gave all details (including mentioning that we had boards from the indiegogo campaign), tried to follow all directions Turris team gave us etc.
It probably affects all early Turris Mox boards: not cool to let early supporters in the dark like that. I suggested Marek to communicate about that, or to automatically deploy this U-boot update.
NB: Iām wondering if we should keep the āfix-nor-updateā package, or if it would be better to remove it now. I suppose that keeping it might provide us subsequent u-boot upgrades (that we would not have by default). Is it a good idea or not? Do we take a risk of having (in the future) a not-so-tested version of U-boot automatically installed with Turris OS upgrade?
Oh, now imagine youād solve this kind of regression with Netgear or TP-Link⦠7 months would be just the time before you get to communicate with a real engineer (if ever).
Well, youāre probably right, I donāt know.
Itās probably complicated to compare. Other āclassicalā commercial vendors probably have sold more devices, so might have been informed of the issue from more customers (or hopefully would have found it before shipping the upgrade).
But donāt get me wrong: I know why I chose Turris, and these reasons are still there: free software, transparency, unrestricted capabilities including root rights (that certainly make support more complicated for Turris) etc.
In this particular case, weāve been āsavedā by the ability to rollback to previous Turris OS version, which is probably not a common feature.
However, I still believe there is room for improvement in their processes.
But, anyway, letās focus on the good news: Iām so glad to finally be able to upgrade my Mox!
As far as above entries were encouraging I updated u-boot as well⦠All seems OK.
Just out of curiosity: can anyone explain how a bootloader can influence what does kernel see on the USB bus?
I have no knowledge about the details of hardware platforms of Turris products, but generally speaking, U-boot does hardware testing and initialization, so anything not done properly in those early stages will have a huge impact on the hardware capabilities as seen by the operating system kernel.
