What branch are you on? hbs? or hbs-sdio?
Iām probably on hbs (did not try to manually switch to another one). How can I check?
edit: found a way to check: Iām indeed on hbs:
root@turris:~# cat /etc/config/updater
config turris 'turris'
option mode 'branch'
option branch 'hbs'
config l10n 'l10n'
list langs 'fr'
config autorun 'autorun'
option enable '1'
option approvals '1'
I switched back to my snapshot of January 15th, asked the UI to look for updates again, and it still finds kernel 5.15.88.
Then you could try switching to hbt. There is no release currently in testing, but it might still be worth tryingā¦
switch-branch hbt
In fact, if I open file https://repo.turris.cz/hbs/mox/packages/core/Packages.gz (which is the URL grabbed if I run opkg update, on hbs branch), it only contains kernel 5.15.88, no 5.15.89.
and the hbs-sdio branch (https://repo.turris.cz/hbs-sdio/mox/packages/core/Packages.gz) contains an older kernel: 4.14.294-1
@peci1 : hbt is also with 5.15.88. I would need to switch to hbk to have 5.15.89. @jada4p on which branch are you?
When I read Turris OS 6.2.2 is out!, I thought it meant it was released on hbs?
Correct.
I think weāre just randomly trying to find stuff that might help you. Trying to switch to hbk might be a good test to see whether your issue is still there.
I tried hbs, hbt (6.2.2 with kernel 5.15.88) and hbk (6.2.3 with kernel 5.15.89).
My USB3 HDD doesnāt work with any of those versions.
6.2.2:
# uname -a
Linux turris 5.15.88 #0 SMP Wed Jan 18 07:04:32 2023 aarch64 GNU/Linux
# cat /etc/os-release
NAME="TurrisOS"
VERSION="6.2.2"
ID="turrisos"
ID_LIKE="lede openwrt"
PRETTY_NAME="TurrisOS 6.2.2"
VERSION_ID="6.2.2"
HOME_URL="https://www.turris.cz/"
BUG_URL="https://gitlab.nic.cz/groups/turris/-/issues/"
SUPPORT_URL="https://www.turris.cz/support/"
BUILD_ID="r16820+125-8b46a263ab"
OPENWRT_BOARD="mvebu/cortexa53"
OPENWRT_ARCH="aarch64_cortex-a53"
OPENWRT_TAINTS="busybox"
OPENWRT_DEVICE_MANUFACTURER="CZ.NIC"
OPENWRT_DEVICE_MANUFACTURER_URL="https://www.turris.cz/"
OPENWRT_DEVICE_PRODUCT="Turris Mox"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="TurrisOS 6.2.2 8b46a263ab4afaf9857f0d29d369c2eefbf8a4f4"
# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p1 15554048 1719212 12216148 12% /
devtmpfs 512 0 512 0% /dev
tmpfs 249172 20716 228456 8% /tmp
# lsusb -vt
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
ID 1d6b:0003
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
ID 1d6b:0002
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M
ID 1d6b:0002
# opkg list-installed kmod-usb*
kmod-usb-core - 5.15.88-2-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-ehci - 5.15.88-2-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-storage - 5.15.88-2-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-storage-extras - 5.15.88-2-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-storage-uas - 5.15.88-2-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb2 - 5.15.88-2-64722ee4b91fa2779e55bbf4f1bbe4a6
6.2.3:
# uname -a
Linux turris 5.15.89 #0 SMP Fri Jan 27 00:08:56 2023 aarch64 GNU/Linux
NAME="TurrisOS"
VERSION="6.2.3"
ID="turrisos"
PRETTY_NAME="TurrisOS 6.2.3"
VERSION_ID="6.2.3"
BUILD_ID="r16821+124-944265347a"
OPENWRT_RELEASE="TurrisOS 6.2.3 944265347a81eadc3354731d5f739a6a4fdf6e7b"
# lsusb -vt
ID 1d6b:0003
ID 1d6b:0002
ID 1d6b:0002
# df
/dev/mmcblk0p1 15554048 2224732 11755092 16% /
tmpfs 249172 20704 228468 8% /tmp
kmod-usb-core - 5.15.89-1-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-ehci - 5.15.89-1-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-storage - 5.15.89-1-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-storage-extras - 5.15.89-1-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb-storage-uas - 5.15.89-1-64722ee4b91fa2779e55bbf4f1bbe4a6
kmod-usb2 - 5.15.89-1-64722ee4b91fa2779e55bbf4f1bbe4a6
Iāve rolled back to 5.4.4 where USB3 drive works just fine.
Just to add, re-connecting USB cable to MOX doesnāt make any effect, nothing in dmesg output.
Thatās it! On MOX Iām on HBK branch, on Omnia itās HBS
I think you can safely switch to HBK branch as well, at least to be able to use USB3 for time being, and later switch back to HBS, to be on safe side
Well, not so sure that switching to hbk is enough, based on the feedback from @padam above.
Iāve reverted to 5.4.4 too, because I canāt block all my hosted services for too long.
USB3 still doesnāt work for me on MOX hbs 6.2.2 either. I tried a flash drive and a USB3 SATA adapter.
As a workaround I got myself a USB2 SATA adapter.
It doesnāt work on 6.2.3. I did a factory reset to 6.2.2 and then switched to HBK branch, and my USB3.0 devices are still ignored.
Iāve just updated my unused MOX from 6.1.0 to 6.2.2. On 6.1.0, an external magnetic drive did not show up in dmesg, while a USB flash did. On 6.2.2, I can see both. So it seems the fix worked for some devices, but not yet for all. Did you also try other USB3 storage devices? Could you spot some important difference for the working ones and non-working ones in lsusb -v
If the problem is not insufficient power supply ??
If the problem ⦠is not insufficient power supply ??
I have external USB3 HDD which has itās own power, so I guess thatās not related.
In my case (6.2.2 hbs), I had tested with 3 different USB3 mass-storage devices, all not detected at all:
An external hard drive (which is the one I really need to have working):
Bus 003 Device 002: ID 152d:1576 JMicron Technology Corp. / JMicron USA Technology Corp. External Disk 3.0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x152d JMicron Technology Corp. / JMicron USA Technology Corp.
idProduct 0x1576 External Disk 3.0
bcdDevice 2.04
iManufacturer 1 JMicron
iProduct 2 JMS579
iSerial 3 987654321029
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 121
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 224mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 15
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 4
bInterfaceProtocol 98
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
Command pipe (0x01)
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
MaxStreams 32
Status pipe (0x02)
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
MaxStreams 32
Data-in pipe (0x03)
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 7
MaxStreams 32
Data-out pipe (0x04)
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000f0e
Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 32 micro seconds
Device Status: 0x0000
(Bus Powered)
And 2 different USB sticks for testing (from the same brand, lsusb -v gives almost identical data):
Bus 004 Device 003: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2/50
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.20
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x0951 Kingston Technology
idProduct 0x1666 DataTraveler 100 G3/G4/SE9 G2/50
bcdDevice 1.10
iManufacturer 1 Kingston
iProduct 2 DataTraveler 3.0
iSerial 3 408D5CE57217E46079118521
bLength 9
bDescriptorType 2
wTotalLength 0x002c
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 504mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 5
bDescriptorType 15
wTotalLength 0x0016
bNumDeviceCaps 2
bLength 7
bDescriptorType 16
bmAttributes 0x00000006
BESL Link Power Management (LPM) Supported
bLength 10
bDescriptorType 16
bmAttributes 0x00
bFunctionalitySupport 2
Lowest fully-functional device speed is High Speed (480Mbps)
bU2DevExitLat 2047 micro seconds
(Bus Powered)
Bus 004 Device 004: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2/50
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
bcdDevice 1.10
iSerial 3 60A44C3FABFFE260F96C11CF
bLength 9
bDescriptorType 2
wTotalLength 0x002c
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 504mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 3
bLength 5
bDescriptorType 15
wTotalLength 0x0016
bNumDeviceCaps 2
bLength 7
bDescriptorType 16
bLength 10
bDescriptorType 16
bmAttributes 0x00
(Bus Powered)
6.2.2. - tried USB3 flashdisk - in modul A not working, in modul F working OK.
I see that @jada4p reported working USB3 in Turris OS 6.2.3 is in the testing branch - #2 by jada4p (with TOS 6.2.3, on hbk branch). It was already working for him with 6.2.2, and USB3 is not mentioned in the changelog of 6.2.3.
If anyone else can test on hbk, it would be cool to give your status on your USB3 mass-storage devices on the same thread. Iād say itās likely to give the same result as with 6.2.2, but I might be wrong.
Forget the link above, 6.2.3 is already in hbs, and feedback can be written in Turris OS 6.2.3 is out!
I will be unable to test in the short term, but it would be good to make them aware that the usb3 issue is not fixed for all users/devices
Tested on 6.2.3 hbs - USB3 not working for me. Details shared in the Turris OS 6.2.3 is out!
