Turris MOX as Wi-Fi client with bridge to LAN
is it possible to configure Turris MOX Wi-FI to station (client) mode and bridge it with LAN port?
I would like to (temporarily) replace the cable which is connecting my main router to the neighbour’s network by Turris MOX connected to the neighbour’s Wi-Fi network and the LAN port connected to my main router.
I know, it should be possible to do it with routing, but would it be possible to make bridge between the Wi-Fi and LAN port - so I’ll not need to configure any routing anywhere - and just reconnect the cables?
Thanks
Daniel
I used my MOX as a Wi-Fi client/bridge for few months, but I stopped to use it because of very poor SDIO card - poor signal, lost packets and so on - but it worked some way… So if you have full Wi-Fi card ( not only SDIO ) try to use setup here:
