Turris loses connection after FTTH GPON installation
some weeks ago we changed our internet connection from dsl to fiber. I bought the sfp-module from fs.com (GPON-ONU-34-20BI) for my omnia (kickstarter-model). Installation went well: I changed the serial number of the GPON-stick to one of the fritzbox I got from my service provider. In reforis I established a PPPoE-connection.
Problem:
Nearly every day internet connection stops at the same time. But in most cases the omnia also stops working - reforis and luci aren’t available any more and I’ve to press the reset button. Here is the dmesg output:
Why is the omnia freezing? Could you help me, please?
Kind regards
Aug 28 08:36:35 turris syslog-ng[4234]: syslog-ng starting up; version='4.7.1'
Aug 28 08:36:35 turris kernel: [    0.000000] Booting Linux on physical CPU 0x0
Aug 28 08:36:35 turris kernel: [    0.000000] Linux version 5.15.148 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 11.2.0 r20343+125-4e1d1b7df0) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 SMP Mon Aug 5 02:29:04 2024
Aug 28 08:36:35 turris kernel: [    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Aug 28 08:36:35 turris kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Aug 28 08:36:35 turris kernel: [    0.000000] OF: fdt: Machine model: Turris Omnia
Aug 28 08:36:35 turris kernel: [    0.000000] Memory policy: Data cache writealloc
Aug 28 08:36:35 turris kernel: [    0.000000] Zone ranges:
Aug 28 08:36:35 turris kernel: [    0.000000]   Normal   [mem 0x0000000000000000-0x000000002fffffff]
Aug 28 08:36:35 turris kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x000000003fffffff]
Aug 28 08:36:35 turris kernel: [    0.000000] Movable zone start for each node
Aug 28 08:36:35 turris kernel: [    0.000000] Early memory node ranges
Aug 28 08:36:35 turris kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003fffffff]
Aug 28 08:36:35 turris kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
Aug 28 08:36:35 turris kernel: [    0.000000] percpu: Embedded 11 pages/cpu s14988 r8192 d21876 u45056
Aug 28 08:36:35 turris kernel: [    0.000000] pcpu-alloc: s14988 r8192 d21876 u45056 alloc=11*4096
Aug 28 08:36:35 turris kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1
Aug 28 08:36:35 turris kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
Aug 28 08:36:35 turris kernel: [    0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
Aug 28 08:36:35 turris kernel: [    0.000000] Bootloader command line not present
Aug 28 08:36:35 turris kernel: [    0.000000] Unknown kernel command line parameters "earlyprintk mangled_fs=btrfs", will be passed to user space.
Aug 28 08:36:35 turris kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Aug 28 08:36:35 turris kernel: [    0.000000] Memory: 1023104K/1048576K available (10240K kernel code, 672K rwdata, 2192K rodata, 1024K init, 258K bss, 25472K reserved, 0K cma-reserved, 262144K highmem)
Aug 28 08:36:35 turris kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Aug 28 08:36:35 turris kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Aug 28 08:36:35 turris kernel: [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Aug 28 08:36:35 turris kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Aug 28 08:36:35 turris kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Aug 28 08:36:35 turris kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Aug 28 08:36:35 turris kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Aug 28 08:36:35 turris kernel: [    0.000000] Registering MPIC SoC Error Interrupt Controller
Aug 28 08:36:35 turris kernel: [    0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
Aug 28 08:36:35 turris kernel: [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
Aug 28 08:36:35 turris kernel: [    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
Aug 28 08:36:35 turris kernel: [    0.000000] L2C-310 D prefetch enabled, offset 1 lines
Aug 28 08:36:35 turris kernel: [    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
Aug 28 08:36:35 turris kernel: [    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
Aug 28 08:36:35 turris kernel: [    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
Aug 28 08:36:35 turris kernel: [    0.000001] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
Aug 28 08:36:35 turris kernel: [    0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
Aug 28 08:36:35 turris kernel: [    0.000033] Switching to timer-based delay loop, resolution 1ns
Aug 28 08:36:35 turris kernel: [    0.000174] Ignoring duplicate/late registration of read_current_timer delay
Aug 28 08:36:35 turris kernel: [    0.000181] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Aug 28 08:36:35 turris kernel: [    0.000365] Console: colour dummy device 80x30
Aug 28 08:36:35 turris kernel: [    0.000392] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
Aug 28 08:36:35 turris kernel: [    0.000400] CPU: Testing write buffer coherency: ok
Aug 28 08:36:35 turris kernel: [    0.000419] CPU0: Spectre v2: using BPIALL workaround
Aug 28 08:36:35 turris kernel: [    0.000424] pid_max: default: 32768 minimum: 301
Aug 28 08:36:35 turris kernel: [    0.000508] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.000517] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.000988] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Aug 28 08:36:35 turris kernel: [    0.001294] Setting up static identity map for 0x100000 - 0x100060
Aug 28 08:36:35 turris kernel: [    0.001375] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
Aug 28 08:36:35 turris kernel: [    0.001464] mvebu-pmsu: Initializing Power Management Service Unit
Aug 28 08:36:35 turris kernel: [    0.001525] rcu: Hierarchical SRCU implementation.
Aug 28 08:36:35 turris kernel: [    0.001602] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
Aug 28 08:36:35 turris kernel: [    0.001666] smp: Bringing up secondary CPUs ...
Aug 28 08:36:35 turris kernel: [    0.001837] Booting CPU 1
Aug 28 08:36:35 turris kernel: [    0.001967] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Aug 28 08:36:35 turris kernel: [    0.001973] CPU1: Spectre v2: using BPIALL workaround
Aug 28 08:36:35 turris kernel: [    0.002027] smp: Brought up 1 node, 2 CPUs
Aug 28 08:36:35 turris kernel: [    0.002033] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
Aug 28 08:36:35 turris kernel: [    0.002039] CPU: All CPU(s) started in SVC mode.
Aug 28 08:36:35 turris kernel: [    0.002304] devtmpfs: initialized
Aug 28 08:36:35 turris kernel: [    0.004212] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Aug 28 08:36:35 turris kernel: [    0.004266] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Aug 28 08:36:35 turris kernel: [    0.004276] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.004349] pinctrl core: initialized pinctrl subsystem
Aug 28 08:36:35 turris kernel: [    0.004876] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Aug 28 08:36:35 turris kernel: [    0.005394] DMA: preallocated 256 KiB pool for atomic coherent allocations
Aug 28 08:36:35 turris kernel: [    0.005851] thermal_sys: Registered thermal governor 'step_wise'
Aug 28 08:36:35 turris kernel: [    0.005990] cpuidle: using governor ladder
Aug 28 08:36:35 turris kernel: [    0.006080] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
Aug 28 08:36:35 turris kernel: [    0.006086] hw-breakpoint: maximum watchpoint size is 4 bytes.
Aug 28 08:36:35 turris kernel: [    0.006208] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
Aug 28 08:36:35 turris kernel: [    0.006215] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
Aug 28 08:36:35 turris kernel: [    0.014692] cryptd: max_cpu_qlen set to 1000
Aug 28 08:36:35 turris kernel: [    0.015502] raid6: skip pq benchmark and using algorithm neonx8
Aug 28 08:36:35 turris kernel: [    0.015512] raid6: using neon recovery algorithm
Aug 28 08:36:35 turris kernel: [    0.015767] SCSI subsystem initialized
Aug 28 08:36:35 turris kernel: [    0.015848] libata version 3.00 loaded.
Aug 28 08:36:35 turris kernel: [    0.015936] usbcore: registered new interface driver usbfs
Aug 28 08:36:35 turris kernel: [    0.015956] usbcore: registered new interface driver hub
Aug 28 08:36:35 turris kernel: [    0.015974] usbcore: registered new device driver usb
Aug 28 08:36:35 turris kernel: [    0.016586] clocksource: Switched to clocksource arm_global_timer
Aug 28 08:36:35 turris kernel: [    0.018825] NET: Registered PF_INET protocol family
Aug 28 08:36:35 turris kernel: [    0.018937] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019439] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019456] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019464] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019503] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019564] TCP: Hash tables configured (established 8192 bind 8192)
Aug 28 08:36:35 turris kernel: [    0.019610] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019639] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Aug 28 08:36:35 turris kernel: [    0.019737] NET: Registered PF_UNIX/PF_LOCAL protocol family
Aug 28 08:36:35 turris kernel: [    0.019756] PCI: CLS 0 bytes, default 64
Aug 28 08:36:35 turris kernel: [    0.020251] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Aug 28 08:36:35 turris kernel: [    0.022133] workingset: timestamp_bits=14 max_order=18 bucket_order=4
Aug 28 08:36:35 turris kernel: [    0.024114] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Aug 28 08:36:35 turris kernel: [    0.024121] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Aug 28 08:36:35 turris kernel: [    0.024547] xor: measuring software checksum speed
Aug 28 08:36:35 turris kernel: [    0.028379]    arm4regs        :  2598 MB/sec
Aug 28 08:36:35 turris kernel: [    0.033506]    8regs           :  1920 MB/sec
Aug 28 08:36:35 turris kernel: [    0.038643]    32regs          :  1916 MB/sec
Aug 28 08:36:35 turris kernel: [    0.043669]    neon            :  1957 MB/sec
Aug 28 08:36:35 turris kernel: [    0.043673] xor: using function: arm4regs (2598 MB/sec)
Aug 28 08:36:35 turris kernel: [    0.043714] bounce: pool size: 64 pages
Aug 28 08:36:35 turris kernel: [    0.043743] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Aug 28 08:36:35 turris kernel: [    0.044819] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
Aug 28 08:36:35 turris kernel: [    0.045347] debugfs: Directory 'f1018100.gpio' with parent 'regmap' already present!
Aug 28 08:36:35 turris kernel: [    0.045631] debugfs: Directory 'f1018140.gpio' with parent 'regmap' already present!
Aug 28 08:36:35 turris kernel: [    0.045956] mvebu-pcie soc:pcie: host bridge /soc/pcie ranges:
Aug 28 08:36:35 turris kernel: [    0.045984] mvebu-pcie soc:pcie:      MEM 0x00f1080000..0x00f1081fff -> 0x0000080000
Aug 28 08:36:35 turris kernel: [    0.046001] mvebu-pcie soc:pcie:      MEM 0x00f1040000..0x00f1041fff -> 0x0000040000
Aug 28 08:36:35 turris kernel: [    0.046014] mvebu-pcie soc:pcie:      MEM 0x00f1044000..0x00f1045fff -> 0x0000044000
Aug 28 08:36:35 turris kernel: [    0.046026] mvebu-pcie soc:pcie:      MEM 0x00f1048000..0x00f1049fff -> 0x0000048000
Aug 28 08:36:35 turris kernel: [    0.046040] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
Aug 28 08:36:35 turris kernel: [    0.046052] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
Aug 28 08:36:35 turris kernel: [    0.046065] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
Aug 28 08:36:35 turris kernel: [    0.046076] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
Aug 28 08:36:35 turris kernel: [    0.046088] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
Aug 28 08:36:35 turris kernel: [    0.046100] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
Aug 28 08:36:35 turris kernel: [    0.046111] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
Aug 28 08:36:35 turris kernel: [    0.046120] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
Aug 28 08:36:35 turris kernel: [    0.046209] mvebu-pcie soc:pcie: pcie0.0: Slot power limit 10.0W
Aug 28 08:36:35 turris kernel: [    0.046264] mvebu-pcie soc:pcie: pcie1.0: Slot power limit 10.0W
Aug 28 08:36:35 turris kernel: [    0.046322] mvebu-pcie soc:pcie: pcie2.0: Slot power limit 10.0W
Aug 28 08:36:35 turris kernel: [    0.047135] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
Aug 28 08:36:35 turris kernel: [    0.047148] pci_bus 0000:00: root bus resource [bus 00-ff]
Aug 28 08:36:35 turris kernel: [    0.047157] pci_bus 0000:00: root bus resource [mem 0xf1080000-0xf1081fff] (bus address [0x00080000-0x00081fff])
Aug 28 08:36:35 turris kernel: [    0.047165] pci_bus 0000:00: root bus resource [mem 0xf1040000-0xf1041fff] (bus address [0x00040000-0x00041fff])
Aug 28 08:36:35 turris kernel: [    0.047172] pci_bus 0000:00: root bus resource [mem 0xf1044000-0xf1045fff] (bus address [0x00044000-0x00045fff])
Aug 28 08:36:35 turris kernel: [    0.047178] pci_bus 0000:00: root bus resource [mem 0xf1048000-0xf1049fff] (bus address [0x00048000-0x00049fff])
Aug 28 08:36:35 turris kernel: [    0.047185] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
Aug 28 08:36:35 turris kernel: [    0.047190] pci_bus 0000:00: root bus resource [io  0x1000-0xeffff]
Aug 28 08:36:35 turris kernel: [    0.047257] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
Aug 28 08:36:35 turris kernel: [    0.047418] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
Aug 28 08:36:35 turris kernel: [    0.047559] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
Aug 28 08:36:35 turris kernel: [    0.048382] PCI: bus0: Fast back to back transfers disabled
Aug 28 08:36:35 turris kernel: [    0.048390] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Aug 28 08:36:35 turris kernel: [    0.048400] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Aug 28 08:36:35 turris kernel: [    0.048410] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Aug 28 08:36:35 turris kernel: [    0.049239] PCI: bus1: Fast back to back transfers enabled
Aug 28 08:36:35 turris kernel: [    0.049246] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Aug 28 08:36:35 turris kernel: [    0.049319] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
Aug 28 08:36:35 turris kernel: [    0.049341] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Aug 28 08:36:35 turris kernel: [    0.049369] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Aug 28 08:36:35 turris kernel: [    0.049439] pci 0000:02:00.0: supports D1 D2
Aug 28 08:36:35 turris kernel: [    0.050313] PCI: bus2: Fast back to back transfers disabled
Aug 28 08:36:35 turris kernel: [    0.050320] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
Aug 28 08:36:35 turris kernel: [    0.050395] pci 0000:03:00.0: [168c:002e] type 00 class 0x028000
Aug 28 08:36:35 turris kernel: [    0.050417] pci 0000:03:00.0: reg 0x10: [mem 0xe8000000-0xe800ffff 64bit]
Aug 28 08:36:35 turris kernel: [    0.050517] pci 0000:03:00.0: supports D1
Aug 28 08:36:35 turris kernel: [    0.050522] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
Aug 28 08:36:35 turris kernel: [    0.051396] PCI: bus3: Fast back to back transfers disabled
Aug 28 08:36:35 turris kernel: [    0.051403] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Aug 28 08:36:35 turris kernel: [    0.051427] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe03fffff]
Aug 28 08:36:35 turris kernel: [    0.051437] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0400000-0xe07fffff]
Aug 28 08:36:35 turris kernel: [    0.051445] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0800000-0xe0bfffff]
Aug 28 08:36:35 turris kernel: [    0.051451] pci 0000:00:01.0: BAR 7: assigned [io  0x10000-0x10fff]
Aug 28 08:36:35 turris kernel: [    0.051458] pci 0000:00:02.0: BAR 7: assigned [io  0x20000-0x20fff]
Aug 28 08:36:35 turris kernel: [    0.051464] pci 0000:00:03.0: BAR 7: assigned [io  0x30000-0x30fff]
Aug 28 08:36:35 turris kernel: [    0.051470] pci 0000:00:01.0: PCI bridge to [bus 01]
Aug 28 08:36:35 turris kernel: [    0.051476] pci 0000:00:01.0:   bridge window [io  0x10000-0x10fff]
Aug 28 08:36:35 turris kernel: [    0.051486] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xe03fffff]
Aug 28 08:36:35 turris kernel: [    0.051499] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0400000-0xe05fffff 64bit]
Aug 28 08:36:35 turris kernel: [    0.051511] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0600000-0xe060ffff pref]
Aug 28 08:36:35 turris kernel: [    0.051518] pci 0000:00:02.0: PCI bridge to [bus 02]
Aug 28 08:36:35 turris kernel: [    0.051523] pci 0000:00:02.0:   bridge window [io  0x20000-0x20fff]
Aug 28 08:36:35 turris kernel: [    0.051532] pci 0000:00:02.0:   bridge window [mem 0xe0400000-0xe07fffff]
Aug 28 08:36:35 turris kernel: [    0.051543] pci 0000:03:00.0: BAR 0: assigned [mem 0xe0800000-0xe080ffff 64bit]
Aug 28 08:36:35 turris kernel: [    0.051555] pci 0000:00:03.0: PCI bridge to [bus 03]
Aug 28 08:36:35 turris kernel: [    0.051560] pci 0000:00:03.0:   bridge window [io  0x30000-0x30fff]
Aug 28 08:36:35 turris kernel: [    0.051568] pci 0000:00:03.0:   bridge window [mem 0xe0800000-0xe0bfffff]
Aug 28 08:36:35 turris kernel: [    0.051632] pcieport 0000:00:01.0: enabling device (0140 -> 0143)
Aug 28 08:36:35 turris kernel: [    0.051699] pcieport 0000:00:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Aug 28 08:36:35 turris kernel: [    0.051940] pcieport 0000:00:01.0: pciehp: Slot(1): Card present
Aug 28 08:36:35 turris kernel: [    0.051997] pcieport 0000:00:02.0: enabling device (0140 -> 0143)
Aug 28 08:36:35 turris kernel: [    0.052052] pcieport 0000:00:02.0: pciehp: Slot #2 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Aug 28 08:36:35 turris kernel: [    0.052459] pcieport 0000:00:03.0: enabling device (0140 -> 0143)
Aug 28 08:36:35 turris kernel: [    0.052516] pcieport 0000:00:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Aug 28 08:36:35 turris kernel: [    0.053087] mv_xor f1060800.xor: Marvell shared XOR driver
Aug 28 08:36:35 turris kernel: [    0.066584] mvebu-pcie soc:pcie: pcie2.0: link up
Aug 28 08:36:35 turris kernel: [    0.066608] mvebu-pcie soc:pcie: pcie1.0: link up
Aug 28 08:36:35 turris kernel: [    0.106979] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Aug 28 08:36:35 turris kernel: [    0.107112] mv_xor f1060900.xor: Marvell shared XOR driver
Aug 28 08:36:35 turris kernel: [    0.166967] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Aug 28 08:36:35 turris kernel: [    0.167258] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Aug 28 08:36:35 turris kernel: [    0.168712] printk: console [ttyS0] disabled
Aug 28 08:36:35 turris kernel: [    0.188808] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 30, base_baud = 15625000) is a 16550A
Aug 28 08:36:35 turris kernel: [    1.439554] printk: console [ttyS0] enabled
Aug 28 08:36:35 turris kernel: [    1.464213] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 31, base_baud = 15625000) is a 16550A
Aug 28 08:36:35 turris kernel: [    1.475588] loop: module loaded
Aug 28 08:36:35 turris kernel: [    1.478768] Loading iSCSI transport class v2.0-870.
Aug 28 08:36:35 turris kernel: [    1.484769] ahci-mvebu f10a8000.sata: supply ahci not found, using dummy regulator
Aug 28 08:36:35 turris kernel: [    1.492453] ahci-mvebu f10a8000.sata: supply phy not found, using dummy regulator
Aug 28 08:36:35 turris kernel: [    1.499983] ahci-mvebu f10a8000.sata: supply target not found, using dummy regulator
Aug 28 08:36:35 turris kernel: [    1.507820] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
Aug 28 08:36:35 turris kernel: [    1.516899] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
Aug 28 08:36:35 turris kernel: [    1.526214] scsi host0: ahci-mvebu
Aug 28 08:36:35 turris kernel: [    1.529933] scsi host1: ahci-mvebu
Aug 28 08:36:35 turris kernel: [    1.533426] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 53
Aug 28 08:36:35 turris kernel: [    1.541388] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 53
Aug 28 08:36:35 turris kernel: [    1.550326] spi-nor spi0.0: s25fl164k (8192 Kbytes)
Aug 28 08:36:35 turris kernel: [    1.555336] 2 fixed-partitions partitions found on MTD device spi0.0
Aug 28 08:36:35 turris kernel: [    1.561723] Creating 2 MTD partitions on "spi0.0":
Aug 28 08:36:35 turris kernel: [    1.566525] 0x000000000000-0x000000100000 : "U-Boot"
Aug 28 08:36:35 turris kernel: [    1.571881] 0x000000100000-0x000000800000 : "Rescue system"
Aug 28 08:36:35 turris kernel: [    1.580183] hwmon hwmon0: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    1.587348] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Aug 28 08:36:35 turris kernel: [    1.609954] hwmon hwmon1: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    1.631325] hwmon hwmon2: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    1.650393] hwmon hwmon3: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    1.664978] hwmon hwmon4: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    1.681800] hwmon hwmon5: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    1.818224] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
Aug 28 08:36:35 turris kernel: [    1.827208] mvneta f1070000.ethernet eth0: Using device tree mac address 000000000000000
Aug 28 08:36:35 turris kernel: [    1.836789] mvneta f1030000.ethernet eth1: Using hardware mac address 000000000000000
Aug 28 08:36:35 turris kernel: [    1.846044] mvneta f1034000.ethernet eth2: Using hardware mac address 000000000000000
Aug 28 08:36:35 turris kernel: [    1.854214] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 28 08:36:35 turris kernel: [    1.860770] ehci-pci: EHCI PCI platform driver
Aug 28 08:36:35 turris kernel: [    1.865253] ehci-platform: EHCI generic platform driver
Aug 28 08:36:35 turris kernel: [    1.870576] ehci-orion: EHCI orion driver
Aug 28 08:36:35 turris kernel: [    1.874683] orion-ehci f1058000.usb: EHCI Host Controller
Aug 28 08:36:35 turris kernel: [    1.880118] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
Aug 28 08:36:35 turris kernel: [    1.882934] ata2: SATA link down (SStatus 0 SControl 300)
Aug 28 08:36:35 turris kernel: [    1.887756] orion-ehci f1058000.usb: irq 49, io mem 0xf1058000
Aug 28 08:36:35 turris kernel: [    1.926590] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
Aug 28 08:36:35 turris kernel: [    1.932822] hub 1-0:1.0: USB hub found
Aug 28 08:36:35 turris kernel: [    1.936610] hub 1-0:1.0: 1 port detected
Aug 28 08:36:35 turris kernel: [    1.940964] xhci-hcd f10f0000.usb3: xHCI Host Controller
Aug 28 08:36:35 turris kernel: [    1.946300] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
Aug 28 08:36:35 turris kernel: [    1.953869] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Aug 28 08:36:35 turris kernel: [    1.963143] xhci-hcd f10f0000.usb3: irq 55, io mem 0xf10f0000
Aug 28 08:36:35 turris kernel: [    1.968982] xhci-hcd f10f0000.usb3: xHCI Host Controller
Aug 28 08:36:35 turris kernel: [    1.974311] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
Aug 28 08:36:35 turris kernel: [    1.981853] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
Aug 28 08:36:35 turris kernel: [    1.988481] hub 2-0:1.0: USB hub found
Aug 28 08:36:35 turris kernel: [    1.992255] hub 2-0:1.0: 1 port detected
Aug 28 08:36:35 turris kernel: [    1.996320] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 28 08:36:35 turris kernel: [    2.004640] hub 3-0:1.0: USB hub found
Aug 28 08:36:35 turris kernel: [    2.008423] hub 3-0:1.0: 1 port detected
Aug 28 08:36:35 turris kernel: [    2.012544] xhci-hcd f10f8000.usb3: xHCI Host Controller
Aug 28 08:36:35 turris kernel: [    2.017889] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
Aug 28 08:36:35 turris kernel: [    2.025453] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Aug 28 08:36:35 turris kernel: [    2.034726] xhci-hcd f10f8000.usb3: irq 56, io mem 0xf10f8000
Aug 28 08:36:35 turris kernel: [    2.040556] xhci-hcd f10f8000.usb3: xHCI Host Controller
Aug 28 08:36:35 turris kernel: [    2.045885] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
Aug 28 08:36:35 turris kernel: [    2.053411] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
Aug 28 08:36:35 turris kernel: [    2.060014] hub 4-0:1.0: USB hub found
Aug 28 08:36:35 turris kernel: [    2.063786] hub 4-0:1.0: 1 port detected
Aug 28 08:36:35 turris kernel: [    2.066606] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 28 08:36:35 turris kernel: [    2.067857] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 28 08:36:35 turris kernel: [    2.082069] ata1.00: supports DRM functions and may not be fully accessible
Aug 28 08:36:35 turris kernel: [    2.089063] ata1.00: ATA-9: SAMSUNG MZNLN256HCHP-000L7, EMT23L6Q, max UDMA/133
Aug 28 08:36:35 turris kernel: [    2.096306] ata1.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32)
Aug 28 08:36:35 turris kernel: [    2.096783] hub 5-0:1.0: USB hub found
Aug 28 08:36:35 turris kernel: [    2.106543] hub 5-0:1.0: 1 port detected
Aug 28 08:36:35 turris kernel: [    2.110710] usbcore: registered new interface driver usb-storage
Aug 28 08:36:35 turris kernel: [    2.117074] ata1.00: Features: Trust Dev-Sleep
Aug 28 08:36:35 turris kernel: [    2.117271] armada38x-rtc f10a3800.rtc: registered as rtc0
Aug 28 08:36:35 turris kernel: [    2.127112] armada38x-rtc f10a3800.rtc: setting system clock to 2024-08-28T06:35:54 UTC (1724826954)
Aug 28 08:36:35 turris kernel: [    2.136358] ata1.00: supports DRM functions and may not be fully accessible
Aug 28 08:36:35 turris kernel: [    2.136423] i2c_dev: i2c /dev entries driver
Aug 28 08:36:35 turris kernel: [    2.148587] ata1.00: configured for UDMA/133
Aug 28 08:36:35 turris kernel: [    2.149809] orion_wdt: Initial timeout 171 sec
Aug 28 08:36:35 turris kernel: [    2.153228] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG MZNLN256 3L6Q PQ: 0 ANSI: 5
Aug 28 08:36:35 turris kernel: [    2.157582] sdhci: Secure Digital Host Controller Interface driver
Aug 28 08:36:35 turris kernel: [    2.166655] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
Aug 28 08:36:35 turris kernel: [    2.171658] sdhci: Copyright(c) Pierre Ossman
Aug 28 08:36:35 turris kernel: [    2.179420] sd 0:0:0:0: [sda] Write Protect is off
Aug 28 08:36:35 turris kernel: [    2.183623] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 28 08:36:35 turris kernel: [    2.188325] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 28 08:36:35 turris kernel: [    2.194762] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 28 08:36:35 turris kernel: [    2.204983]  sda: sda1
Aug 28 08:36:35 turris kernel: [    2.208068] marvell-cesa f1090000.crypto: CESA device successfully registered
Aug 28 08:36:35 turris kernel: [    2.208082] sd 0:0:0:0: [sda] Attached SCSI removable disk
Aug 28 08:36:35 turris kernel: [    2.215705] NET: Registered PF_INET6 protocol family
Aug 28 08:36:35 turris kernel: [    2.226372] Segment Routing with IPv6
Aug 28 08:36:35 turris kernel: [    2.230111] In-situ OAM (IOAM) with IPv6
Aug 28 08:36:35 turris kernel: [    2.234082] NET: Registered PF_PACKET protocol family
Aug 28 08:36:35 turris kernel: [    2.239184] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Aug 28 08:36:35 turris kernel: [    2.246608] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
Aug 28 08:36:35 turris kernel: [    2.256606] 8021q: 802.1Q VLAN Support v1.8
Aug 28 08:36:35 turris kernel: [    2.263865] Registering SWP/SWPB emulation handler
Aug 28 08:36:35 turris kernel: [    2.270917] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
Aug 28 08:36:35 turris kernel: [    2.278934] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Aug 28 08:36:35 turris kernel: [    2.303869] hwmon hwmon2: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    2.326814] hwmon hwmon3: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    2.343480] hwmon hwmon4: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    2.358067] hwmon hwmon5: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    2.374902] hwmon hwmon6: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [    2.385146] mmc0: new high speed MMC card at address 0001
Aug 28 08:36:35 turris kernel: [    2.390881] mmcblk0: mmc0:0001 H8G4a� 7.28 GiB
Aug 28 08:36:35 turris kernel: [    2.396202]  mmcblk0: p1
Aug 28 08:36:35 turris kernel: [    2.399036] mmcblk0boot0: mmc0:0001 H8G4a� 4.00 MiB
Aug 28 08:36:35 turris kernel: [    2.404383] mmcblk0boot1: mmc0:0001 H8G4a� 4.00 MiB
Aug 28 08:36:35 turris kernel: [    2.409754] mmcblk0rpmb: mmc0:0001 H8G4a� 4.00 MiB, chardev (247:0)
Aug 28 08:36:35 turris kernel: [    3.246585] pcieport 0000:00:01.0: pciehp: Slot(1): No link
Aug 28 08:36:35 turris kernel: [    3.275617] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
Aug 28 08:36:35 turris kernel: [    3.285521] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
Aug 28 08:36:35 turris kernel: [    3.294925] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
Aug 28 08:36:35 turris kernel: [    3.305095] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
Aug 28 08:36:35 turris kernel: [    3.401098] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540] (irq=79)
Aug 28 08:36:35 turris kernel: [    3.523337] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540] (irq=80)
Aug 28 08:36:35 turris kernel: [    3.640215] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540] (irq=81)
Aug 28 08:36:35 turris kernel: [    3.747978] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540] (irq=82)
Aug 28 08:36:35 turris kernel: [    3.858861] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540] (irq=83)
Aug 28 08:36:35 turris kernel: [    3.874816] DSA: tree 0 setup
Aug 28 08:36:35 turris kernel: [    3.878571] Waiting 2 sec before mounting root device...
Aug 28 08:36:35 turris kernel: [    5.927806] squashfs: Unknown parameter 'subvol'
Aug 28 08:36:35 turris kernel: [    5.932662] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Aug 28 08:36:35 turris kernel: [    5.939916] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
Aug 28 08:36:35 turris kernel: [    5.947774] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Aug 28 08:36:35 turris kernel: [    5.955014] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
Aug 28 08:36:35 turris kernel: [    5.963106] BTRFS: device fsid bf452356-b638-4de0-b55f-4ba25eca3ce1 devid 1 transid 34872 /dev/root scanned by swapper/0 (1)
Aug 28 08:36:35 turris kernel: [    5.974960] BTRFS info (device mmcblk0p1): using crc32c (crc32c-generic) checksum algorithm
Aug 28 08:36:35 turris kernel: [    5.983381] BTRFS info (device mmcblk0p1): disk space caching is enabled
Aug 28 08:36:35 turris kernel: [    5.990108] BTRFS info (device mmcblk0p1): has skinny extents
Aug 28 08:36:35 turris kernel: [    6.002144] BTRFS info (device mmcblk0p1): enabling ssd optimizations
Aug 28 08:36:35 turris kernel: [    6.018132] VFS: Mounted root (btrfs filesystem) on device 0:14.
Aug 28 08:36:35 turris kernel: [    6.024555] devtmpfs: mounted
Aug 28 08:36:35 turris kernel: [    6.028113] Freeing unused kernel image (initmem) memory: 1024K
Aug 28 08:36:35 turris kernel: [    6.066742] Run /sbin/init as init process
Aug 28 08:36:35 turris kernel: [    6.070849]   with arguments:
Aug 28 08:36:35 turris kernel: [    6.070851]     /sbin/init
Aug 28 08:36:35 turris kernel: [    6.070853]     earlyprintk
Aug 28 08:36:35 turris kernel: [    6.070855]   with environment:
Aug 28 08:36:35 turris kernel: [    6.070857]     HOME=/
Aug 28 08:36:35 turris kernel: [    6.070859]     TERM=linux
Aug 28 08:36:35 turris kernel: [    6.070861]     mangled_fs=btrfs
Aug 28 08:36:35 turris kernel:    6.110446] init: Console is alive
Aug 28 08:36:35 turris kernel:    6.113964] init: - watchdog -
Aug 28 08:36:35 turris kernel:    6.557494] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Aug 28 08:36:35 turris kernel: [    6.571025] Key type encrypted registered
Aug 28 08:36:35 turris kernel: [    6.579299] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
Aug 28 08:36:35 turris kernel: [    6.598117] SGI XFS with ACLs, security attributes, no debug enabled
Aug 28 08:36:35 turris kernel: [    6.605930] fsl-ehci: Freescale EHCI Host controller driver
Aug 28 08:36:35 turris kernel: [    6.615049] usbcore: registered new interface driver uas
Aug 28 08:36:35 turris kernel:    6.624149] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Aug 28 08:36:35 turris kernel:    6.637063] init: - preinit -
Aug 28 08:36:35 turris kernel:    8.753175] Starting lvm2 during preinit
Aug 28 08:36:35 turris kernel: [    8.858515] random: lvm: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel: [    9.005430] random: lvm: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel:    9.107082] mount_root: mounting /dev/root
Aug 28 08:36:35 turris kernel:    9.438335] mount_root: loading kmods from internal overlay
Aug 28 08:36:35 turris kernel:    9.459473] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Aug 28 08:36:35 turris kernel:    9.467906] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Aug 28 08:36:35 turris kernel:    9.976936] block: attempting to load /etc/config/fstab
Aug 28 08:36:35 turris kernel:    9.983174] block: extroot: not configured
Aug 28 08:36:35 turris kernel: [   10.003726] random: procd: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel: [   10.065258] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by mount (736)
Aug 28 08:36:35 turris kernel:   10.087162] urandom-seed: Seeding with /etc/urandom.seed
Aug 28 08:36:35 turris kernel: [   10.451647] BTRFS: device label srv devid 1 transid 661006 /dev/sda1 scanned by btrfs (743)
Aug 28 08:36:35 turris kernel:   10.463790] procd: - early -
Aug 28 08:36:35 turris kernel:   10.467090] procd: - watchdog -
Aug 28 08:36:35 turris kernel: [   10.556572] random: jshn: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel: [   10.620748] random: jshn: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel:   11.006414] procd: - watchdog -
Aug 28 08:36:35 turris kernel:   11.011440] procd: - ubus -
Aug 28 08:36:35 turris kernel: [   11.021414] random: ubusd: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel: [   11.063894] random: ubusd: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel: [   11.070450] random: ubusd: uninitialized urandom read (4 bytes read)
Aug 28 08:36:35 turris kernel:   11.078165] procd: - init -
Aug 28 08:36:35 turris kernel:   11.499277] kmodloader: loading kernel modules from /etc/modules.d/*
Aug 28 08:36:35 turris kernel: [   11.612996] NET: Registered PF_ALG protocol family
Aug 28 08:36:35 turris kernel: [   11.654530] async_tx: api initialized (async)
Aug 28 08:36:35 turris kernel: [   11.675554] Key type dns_resolver registered
Aug 28 08:36:35 turris kernel: [   11.687878] Key type cifs.idmap registered
Aug 28 08:36:35 turris kernel: [   11.702395] RPC: Registered named UNIX socket transport module.
Aug 28 08:36:35 turris kernel: [   11.708380] RPC: Registered udp transport module.
Aug 28 08:36:35 turris kernel: [   11.713098] RPC: Registered tcp transport module.
Aug 28 08:36:35 turris kernel: [   11.717817] RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 28 08:36:35 turris kernel: [   11.749850] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Aug 28 08:36:35 turris kernel: [   11.756343] tun: Universal TUN/TAP device driver, 1.6
Aug 28 08:36:35 turris kernel: [   11.794199] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Aug 28 08:36:35 turris kernel: [   11.831872] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Aug 28 08:36:35 turris kernel: [   11.852695] NFS: Registering the id_resolver key type
Aug 28 08:36:35 turris kernel: [   11.856566] random: crng init done
Aug 28 08:36:35 turris kernel: [   11.857846] Key type id_resolver registered
Aug 28 08:36:35 turris kernel: [   11.861234] random: 28 urandom warning(s) missed due to ratelimiting
Aug 28 08:36:35 turris kernel: [   11.865424] Key type id_legacy registered
Aug 28 08:36:35 turris kernel: [   11.907064] cryptodev: driver 1.12 loaded.
Aug 28 08:36:35 turris kernel: [   11.914974] turris-omnia-mcu 1-002a: Your board's MCU firmware does not support the feature reading feature.
Aug 28 08:36:35 turris kernel: [   11.924864] turris-omnia-mcu 1-002a: MCU type STM32
Aug 28 08:36:35 turris kernel: [   11.934215] turris-omnia-mcu 1-002a: MCU bootloader firmware version hash: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
Aug 28 08:36:35 turris kernel: [   11.946953] turris-omnia-mcu 1-002a: MCU application firmware version hash: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
Aug 28 08:36:35 turris kernel: [   11.957512] turris-omnia-mcu 1-002a: Your board's MCU firmware does not support the extended control and status feature.
Aug 28 08:36:35 turris kernel: [   11.968412] turris-omnia-mcu 1-002a: Your board's MCU firmware does not support the watchdog pinging feature.
Aug 28 08:36:35 turris kernel: [   11.978352] turris-omnia-mcu 1-002a: Your board's MCU firmware does not support the peripheral LED pins reading feature.
Aug 28 08:36:35 turris kernel: [   11.989250] turris-omnia-mcu 1-002a: Your board's MCU firmware does not support the new interrupt API feature.
Aug 28 08:36:35 turris kernel: [   11.999276] turris-omnia-mcu 1-002a: Your board's MCU firmware does not support the poweroff and wakeup feature.
Aug 28 08:36:35 turris kernel: [   12.009471] turris-omnia-mcu 1-002a: Consider upgrading MCU firmware with the omnia-mcutool utility.
Aug 28 08:36:35 turris kernel: [   12.020308] leds-turris-omnia 1-002b: Your board's MCU firmware does not support the LED gamma correction feature.
Aug 28 08:36:35 turris kernel: [   12.030707] leds-turris-omnia 1-002b: Consider upgrading MCU firmware with the omnia-mcutool utility.
Aug 28 08:36:35 turris kernel: [   12.060390] i2c i2c-0: Added multiplexed i2c bus 1
Aug 28 08:36:35 turris kernel: [   12.065667] i2c i2c-0: Added multiplexed i2c bus 2
Aug 28 08:36:35 turris kernel: [   12.070941] i2c i2c-0: Added multiplexed i2c bus 3
Aug 28 08:36:35 turris kernel: [   12.076058] i2c i2c-0: Added multiplexed i2c bus 4
Aug 28 08:36:35 turris kernel: [   12.081223] i2c i2c-0: Added multiplexed i2c bus 5
Aug 28 08:36:35 turris kernel: [   12.086331] i2c i2c-0: Added multiplexed i2c bus 6
Aug 28 08:36:35 turris kernel: [   12.091584] i2c i2c-0: Added multiplexed i2c bus 7
Aug 28 08:36:35 turris kernel: [   12.096945] pca953x 8-0071: supply vcc not found, using dummy regulator
Aug 28 08:36:35 turris kernel: [   12.103657] pca953x 8-0071: using no AI
Aug 28 08:36:35 turris kernel: [   12.116692] i2c i2c-0: Added multiplexed i2c bus 8
Aug 28 08:36:35 turris kernel: [   12.121508] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
Aug 28 08:36:35 turris kernel: [   12.130554] sfp sfp: Host maximum power 3.0W
Aug 28 08:36:35 turris kernel: [   12.135886] GACT probability on
Aug 28 08:36:35 turris kernel: [   12.139758] Mirror/redirect action on
Aug 28 08:36:35 turris kernel: [   12.147635] u32 classifier
Aug 28 08:36:35 turris kernel: [   12.150355]     input device check on
Aug 28 08:36:35 turris kernel: [   12.154024]     Actions configured
Aug 28 08:36:35 turris kernel: [   12.162775] fuse: init (API version 7.34)
Aug 28 08:36:35 turris kernel: [   12.171079] at24 1-0054: supply vcc not found, using dummy regulator
Aug 28 08:36:35 turris kernel: [   12.182885] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
Aug 28 08:36:35 turris kernel: [   12.190474] Bridge firewalling registered
Aug 28 08:36:35 turris kernel: [   12.195886] Loading modules backported from Linux version v5.15.162-0-gf45bea23c39cb
Aug 28 08:36:35 turris kernel: [   12.203713] Backport generated by backports.git v5.15.162-1-0-g9fa1c65c
Aug 28 08:36:35 turris kernel: [   12.224841] usbcore: registered new interface driver ums-alauda
Aug 28 08:36:35 turris kernel: [   12.231296] usbcore: registered new interface driver ums-cypress
Aug 28 08:36:35 turris kernel: [   12.237906] usbcore: registered new interface driver ums-datafab
Aug 28 08:36:35 turris kernel: [   12.244883] usbcore: registered new interface driver ums-freecom
Aug 28 08:36:35 turris kernel: [   12.255328] usbcore: registered new interface driver ums-isd200
Aug 28 08:36:35 turris kernel: [   12.261979] usbcore: registered new interface driver ums-jumpshot
Aug 28 08:36:35 turris kernel: [   12.268596] usbcore: registered new interface driver ums-karma
Aug 28 08:36:35 turris kernel: [   12.274872] usbcore: registered new interface driver ums-sddr09
Aug 28 08:36:35 turris kernel: [   12.284843] usbcore: registered new interface driver ums-sddr55
Aug 28 08:36:35 turris kernel: [   12.291226] usbcore: registered new interface driver ums-usbat
Aug 28 08:36:35 turris kernel: [   12.299918] usbcore: registered new interface driver usbserial_generic
Aug 28 08:36:35 turris kernel: [   12.306494] usbserial: USB Serial support registered for generic
Aug 28 08:36:35 turris kernel: [   12.322065] xt_time: kernel timezone is -0000
Aug 28 08:36:35 turris kernel: [   12.327836] usbcore: registered new interface driver cdc_ether
Aug 28 08:36:35 turris kernel: [   12.380416] PPP generic driver version 2.4.2
Aug 28 08:36:35 turris kernel: [   12.385412] NET: Registered PF_PPPOX protocol family
Aug 28 08:36:35 turris kernel: [   12.391173] usbcore: registered new interface driver rndis_host
Aug 28 08:36:35 turris kernel: [   12.399164] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Aug 28 08:36:35 turris kernel: [   12.407032] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Aug 28 08:36:35 turris kernel: [   12.435681] ath10k_pci 0000:02:00.0: enabling device (0140 -> 0142)
Aug 28 08:36:35 turris kernel: [   12.442233] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Aug 28 08:36:35 turris kernel: [   12.461737] sfp sfp: module FS               GPON-ONU-34-20BI rev 01   sn G2410075185      dc 240301
Aug 28 08:36:35 turris kernel: [   12.471104] mvneta f1034000.ethernet eth2: switched to inband/1000base-x link mode
Aug 28 08:36:35 turris kernel: [   12.498235] hwmon hwmon7: temp1_input not attached to any thermal zone
Aug 28 08:36:35 turris kernel: [   22.060338] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Aug 28 08:36:35 turris kernel: [   22.069620] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Aug 28 08:36:35 turris kernel: [   22.079245] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
Aug 28 08:36:35 turris kernel: [   22.137241] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Aug 28 08:36:35 turris kernel: [   23.276583] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Aug 28 08:36:35 turris kernel: [   23.397980] ath: EEPROM regdomain: 0x0
Aug 28 08:36:35 turris kernel: [   23.397987] ath: EEPROM indicates default country code should be used
Aug 28 08:36:35 turris kernel: [   23.397990] ath: doing EEPROM country->regdmn map search
Aug 28 08:36:35 turris kernel: [   23.397994] ath: country maps to regdmn code: 0x3a
Aug 28 08:36:35 turris kernel: [   23.397998] ath: Country alpha2 being used: US
Aug 28 08:36:35 turris kernel: [   23.398000] ath: Regpair used: 0x3a
Aug 28 08:36:35 turris kernel: [   23.409491] usbcore: registered new interface driver qcserial
Aug 28 08:36:35 turris kernel: [   23.415301] usbserial: USB Serial support registered for Qualcomm USB modem
Aug 28 08:36:35 turris kernel: [   23.513798] ath: EEPROM regdomain: 0x0
Aug 28 08:36:35 turris kernel: [   23.513812] ath: EEPROM indicates default country code should be used
Aug 28 08:36:35 turris kernel: [   23.513814] ath: doing EEPROM country->regdmn map search
Aug 28 08:36:35 turris kernel: [   23.513819] ath: country maps to regdmn code: 0x3a
Aug 28 08:36:35 turris kernel: [   23.513822] ath: Country alpha2 being used: US
Aug 28 08:36:35 turris kernel: [   23.513824] ath: Regpair used: 0x3a
Aug 28 08:36:35 turris kernel: [   23.525745] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Aug 28 08:36:35 turris kernel: [   23.527248] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0x1abccf2d, irq=103
Aug 28 08:36:35 turris kernel:   23.534278] kmodloader: done loading kernel modules from /etc/modules.d/*
Aug 28 08:36:35 turris kernel: [   26.396041] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
Aug 28 08:36:35 turris kernel: [   26.404002] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Aug 28 08:36:35 turris kernel: [   26.412142] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
Aug 28 08:36:35 turris kernel: [   26.425556] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Aug 28 08:36:35 turris kernel: [   26.431994] br-lan: port 1(lan0) entered blocking state
Aug 28 08:36:35 turris kernel: [   26.437267] br-lan: port 1(lan0) entered disabled state
Aug 28 08:36:35 turris kernel: [   26.499931] device lan0 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   26.504582] device eth1 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   26.707091] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control off
Aug 28 08:36:35 turris kernel: [   26.708600] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
Aug 28 08:36:35 turris kernel: [   26.727324] br-lan: port 1(lan0) entered blocking state
Aug 28 08:36:35 turris kernel: [   26.732575] br-lan: port 1(lan0) entered forwarding state
Aug 28 08:36:35 turris kernel: [   26.787089] br-lan: port 2(lan1) entered blocking state
Aug 28 08:36:35 turris kernel: [   26.792341] br-lan: port 2(lan1) entered disabled state
Aug 28 08:36:35 turris kernel: [   26.840536] device lan1 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   26.863558] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Aug 28 08:36:35 turris kernel: [   26.872009] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
Aug 28 08:36:35 turris kernel: [   26.936785] br-lan: port 3(lan2) entered blocking state
Aug 28 08:36:35 turris kernel: [   26.942036] br-lan: port 3(lan2) entered disabled state
Aug 28 08:36:35 turris kernel: [   26.990537] device lan2 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   27.014148] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
Aug 28 08:36:35 turris kernel: [   27.076729] br-lan: port 4(lan3) entered blocking state
Aug 28 08:36:35 turris kernel: [   27.081978] br-lan: port 4(lan3) entered disabled state
Aug 28 08:36:35 turris kernel: [   27.131823] device lan3 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   27.157807] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
Aug 28 08:36:35 turris kernel: [   27.169729] br-lan: port 5(lan4) entered blocking state
Aug 28 08:36:35 turris kernel: [   27.174976] br-lan: port 5(lan4) entered disabled state
Aug 28 08:36:35 turris kernel: [   27.254713] device lan4 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   27.293183] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 28 08:36:35 turris kernel: [   27.722676] BTRFS info (device sda1): using crc32c (crc32c-generic) checksum algorithm
Aug 28 08:36:35 turris kernel: [   27.726050] ath: EEPROM regdomain: 0x8114
Aug 28 08:36:35 turris kernel: [   27.730701] BTRFS info (device sda1): disk space caching is enabled
Aug 28 08:36:35 turris kernel: [   27.734673] ath: EEPROM indicates we should expect a country code
Aug 28 08:36:35 turris kernel: [   27.734676] ath: doing EEPROM country->regdmn map search
Aug 28 08:36:35 turris kernel: [   27.740958] BTRFS info (device sda1): has skinny extents
Aug 28 08:36:35 turris kernel: [   27.747071] ath: country maps to regdmn code: 0x37
Aug 28 08:36:35 turris kernel: [   27.762522] ath: Country alpha2 being used: DE
Aug 28 08:36:35 turris kernel: [   27.766988] ath: Regpair used: 0x37
Aug 28 08:36:35 turris kernel: [   27.770489] ath: regdomain 0x8114 dynamically updated by user
Aug 28 08:36:35 turris kernel: [   27.776300] ath: EEPROM regdomain: 0x8114
Aug 28 08:36:35 turris kernel: [   27.780332] ath: EEPROM indicates we should expect a country code
Aug 28 08:36:35 turris kernel: [   27.786447] ath: doing EEPROM country->regdmn map search
Aug 28 08:36:35 turris kernel: [   27.791790] ath: country maps to regdmn code: 0x37
Aug 28 08:36:35 turris kernel: [   27.796613] ath: Country alpha2 being used: DE
Aug 28 08:36:35 turris kernel: [   27.801076] ath: Regpair used: 0x37
Aug 28 08:36:35 turris kernel: [   27.804578] ath: regdomain 0x8114 dynamically updated by user
Aug 28 08:36:35 turris kernel: [   27.852553] BTRFS info (device sda1): enabling ssd optimizations
Aug 28 08:36:35 turris kernel: [   29.984575] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 28 08:36:35 turris kernel: [   31.023643] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
Aug 28 08:36:35 turris kernel: [   31.045617] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 28 08:36:35 turris kernel: [   31.053178] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 28 08:36:35 turris kernel: [   31.060322] br-lan: port 6(wlan0) entered blocking state
Aug 28 08:36:35 turris kernel: [   31.065679] br-lan: port 6(wlan0) entered disabled state
Aug 28 08:36:35 turris kernel: [   31.071178] device wlan0 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   31.124226] br-lan: port 7(wlan1) entered blocking state
Aug 28 08:36:35 turris kernel: [   31.129625] br-lan: port 7(wlan1) entered disabled state
Aug 28 08:36:35 turris kernel: [   31.135142] device wlan1 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   31.140015] br-lan: port 7(wlan1) entered blocking state
Aug 28 08:36:35 turris kernel: [   31.145353] br-lan: port 7(wlan1) entered forwarding state
Aug 28 08:36:35 turris kernel: [   32.086846] br-lan: port 7(wlan1) entered disabled state
Aug 28 08:36:35 turris kernel: [   39.249808] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Aug 28 08:36:35 turris kernel: [   39.256290] br-lan: port 7(wlan1) entered blocking state
Aug 28 08:36:35 turris kernel: [   39.261637] br-lan: port 7(wlan1) entered forwarding state
Aug 28 08:36:35 turris kernel: [   39.409310] br-guest-turris: port 1(guest_turris_1) entered blocking state
Aug 28 08:36:35 turris kernel: [   39.416243] br-guest-turris: port 1(guest_turris_1) entered disabled state
Aug 28 08:36:35 turris kernel: [   39.423355] device guest_turris_1 entered promiscuous mode
Aug 28 08:36:35 turris kernel: [   39.479228] br-guest-turris: port 1(guest_turris_1) entered blocking state
Aug 28 08:36:35 turris kernel: [   39.486150] br-guest-turris: port 1(guest_turris_1) entered forwarding state
Aug 28 08:36:35 turris kernel: [   39.493413] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest-turris: link becomes ready
Aug 28 08:36:35 turris kernel: [   39.599004] IPv6: ADDRCONF(NETDEV_CHANGE): guest_turris_1: link becomes ready
Aug 28 08:36:35 turris kernel: [   41.427254] pppoe-wan: renamed from ppp0
Aug 28 06:36:36 turris netifd: Wireguardturris (2834): Try again: `000000000000000'. Trying again in 1.44 seconds...
Aug 28 06:36:36 turris procd: /etc/rc.d/S99start-indicator: Command failed: ubus call service signal { "name": "rainbow-animator", "signal": 10 } (Not found)
Aug 28 08:36:27 turris dnsmasq[4959]: started, version 2.86 DNS disabled
Aug 28 08:36:37 turris dnsmasq[4959]: overflow: 8 log entries lost
Aug 28 08:36:37 turris dnsmasq-dhcp[4959]: DHCPOFFER(br-guest-turris) 10.111.222.244 000000000000000
Aug 28 08:36:37 turris dnsmasq-dhcp[4959]: DHCPDISCOVER(br-guest-turris) 000000000000000
Aug 28 08:36:37 turris dnsmasq-dhcp[4959]: DHCPREQUEST(br-guest-turris) 10.111.222.244 000000000000000
Aug 28 08:36:37 turris dnsmasq-dhcp[4959]: DHCPACK(br-guest-turris) 10.111.222.244 000000000000000
Aug 28 06:36:37 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:36:37 turris odhcp6c[6431]: Failed to send RS (Network unreachable)
Aug 28 06:36:37 turris procd: /etc/rc.d/S99start-indicator: Command failed: ubus call service signal { "name": "rainbow-animator", "signal": 12 } (Not found)
Aug 28 06:36:38 turris dhcp_host_domain_ng.py: DHCP add new hostname [000000000000000,10.111.222.244]
Aug 28 06:36:38 turris procd: /etc/rc.d/S99start-indicator: setting up led wan
Aug 28 06:36:38 turris dhcp_host_domain_ng.py: Kresd is probably not running no socket found.
Aug 28 06:36:38 turris procd: /etc/rc.d/S99start-indicator: setting up led pci1
Aug 28 06:36:38 turris procd: /etc/rc.d/S99start-indicator: setting up led pci2
Aug 28 06:36:38 turris procd: /etc/rc.d/S99start-indicator: setting up led pci3
Aug 28 06:36:38 turris hostapd: guest_turris_1: STA 000000000000000 IEEE 802.11: authenticated
Aug 28 06:36:38 turris hostapd: guest_turris_1: STA 000000000000000 IEEE 802.11: associated (aid 2)
Aug 28 06:36:38 turris hostapd: guest_turris_1: AP-STA-CONNECTED 000000000000000
Aug 28 06:36:38 turris hostapd: guest_turris_1: STA 000000000000000 RADIUS: starting accounting session A579E3296923C69E
Aug 28 06:36:38 turris hostapd: guest_turris_1: STA 000000000000000 WPA: pairwise key handshake completed (RSN)
Aug 28 06:36:38 turris hostapd: guest_turris_1: EAPOL-4WAY-HS-COMPLETED 000000000000000
Aug 28 06:36:39 turris transmission: Starting with 512064000 virt mem
Aug 28 06:36:39 turris adblock-4.1.5[7669]: backup directory '/tmp/adblock-Backup' created
Aug 28 06:36:39 turris adblock-4.1.5[7669]: adblock instance started ::: action: start, priority: 0, pid: 7669
Aug 28 06:36:39 turris ddns-scripts[7536]: afraid_org: PID '7536' started at 2024-08-28 08:36
Aug 28 06:36:39 turris procd: - init complete -
Aug 28 06:36:40 turris ddns-scripts[7535]: myddns_ipv4: PID '7535' started at 2024-08-28 08:36
Aug 28 06:36:40 turris ddns-scripts[7535]: myddns_ipv4: Service section disabled! - TERMINATE
Aug 28 06:36:40 turris ddns-scripts[7535]: myddns_ipv4: PID '7535' exit WITH ERROR '1' at 2024-08-28 08:36
Aug 28 06:36:41 turris netifd: Interface 'Wireguardturris' is now up
Aug 28 06:36:41 turris netifd: Network device 'Wireguardturris' link is up
Aug 28 06:36:41 turris odhcp6c[6431]: Failed to send RS (Network unreachable)
Aug 28 08:36:42 turris dnsmasq-dhcp[4959]: DHCPDISCOVER(br-guest-turris) 000000000000000
Aug 28 08:36:42 turris dnsmasq-dhcp[4959]: DHCPOFFER(br-guest-turris) 10.111.222.249 000000000000000
Aug 28 08:36:42 turris dnsmasq-dhcp[4959]: DHCPREQUEST(br-guest-turris) 10.111.222.249 000000000000000
Aug 28 08:36:42 turris dnsmasq-dhcp[4959]: DHCPACK(br-guest-turris) 10.111.222.249 000000000000000 000000000000000
Aug 28 06:36:42 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:36:43 turris dhcp_host_domain_ng.py: DHCP add new hostname [000000000000000,10.111.222.249]
Aug 28 06:36:43 turris dhcp_host_domain_ng.py: Refresh kresd leases
Aug 28 06:36:43 turris hostapd: wlan0: ACS-COMPLETED freq=5660 channel=132
Aug 28 06:36:43 turris hostapd: wlan0: interface state ACS->HT_SCAN
Aug 28 06:36:44 turris hostapd: wlan0: interface state HT_SCAN->DFS
Aug 28 06:36:44 turris hostapd: wlan0: DFS-CAC-START freq=5660 chan=132 sec_chan=1, width=1, seg0=138, seg1=0, cac_time=60s
Aug 28 06:36:44 turris firewall: Reloading firewall due to ifup of Wireguardturris (Wireguardturris)
Aug 28 06:36:45 turris odhcp6c[6431]: Failed to send RS (Network unreachable)
Aug 28 06:36:51 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:36:53 turris hostapd: wlan1: STA 000000000000000 IEEE 802.11: authenticated
Aug 28 06:36:53 turris hostapd: wlan1: STA 000000000000000 IEEE 802.11: associated (aid 1)
Aug 28 06:36:53 turris hostapd: wlan1: AP-STA-CONNECTED 000000000000000
Aug 28 06:36:53 turris hostapd: wlan1: STA 000000000000000 RADIUS: starting accounting session 751C38D561DCC16D
Aug 28 06:36:53 turris hostapd: wlan1: STA 000000000000000 WPA: pairwise key handshake completed (RSN)
Aug 28 06:36:53 turris hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED 000000000000000
Aug 28 08:36:53 turris dnsmasq-dhcp[4959]: DHCPREQUEST(br-lan) 192.168.3.127 000000000000000
Aug 28 08:36:53 turris dnsmasq-dhcp[4959]: DHCPACK(br-lan) 192.168.3.127 000000000000000 000000000000000
Aug 28 06:36:53 turris dhcp_host_domain_ng.py: DHCP add new hostname [000000000000000,192.168.3.127]
Aug 28 06:36:53 turris dhcp_host_domain_ng.py: Refresh kresd leases
Aug 28 06:37:02 turris hostapd: wlan1: AP-STA-DISCONNECTED 000000000000000
Aug 28 06:37:08 turris adblock-4.1.5[7669]: blocklist with overall 69572 blocked domains loaded successfully (Turris Omnia, TurrisOS 7.0.2 4e1d1b7df0ce6fa96d7462dc883917682f428046)
Aug 28 06:37:09 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:37:46 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:37:47 turris hostapd: wlan0: DFS-CAC-COMPLETED success=1 freq=5660 ht_enabled=0 chan_offset=0 chan_width=3 cf1=5690 cf2=0
Aug 28 08:37:47 turris kernel: [  115.390897] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Aug 28 08:37:47 turris kernel: [  115.397384] br-lan: port 6(wlan0) entered blocking state
Aug 28 08:37:47 turris kernel: [  115.402725] br-lan: port 6(wlan0) entered forwarding state
Aug 28 06:37:47 turris netifd: Network device 'wlan0' link is up
Aug 28 08:37:47 turris kernel: [  115.444283] br-guest-turris: port 2(guest_turris_0) entered blocking state
Aug 28 08:37:47 turris kernel: [  115.451189] br-guest-turris: port 2(guest_turris_0) entered disabled state
Aug 28 08:37:47 turris kernel: [  115.458232] device guest_turris_0 entered promiscuous mode
Aug 28 08:37:47 turris kernel: [  115.472345] br-guest-turris: port 2(guest_turris_0) entered blocking state
Aug 28 08:37:47 turris kernel: [  115.479278] br-guest-turris: port 2(guest_turris_0) entered forwarding state
Aug 28 06:37:47 turris netifd: Network device 'guest_turris_0' link is up
Aug 28 08:37:47 turris kernel: [  115.508905] IPv6: ADDRCONF(NETDEV_CHANGE): guest_turris_0: link becomes ready
Aug 28 06:37:47 turris hostapd: wlan0: interface state DFS->ENABLED
Aug 28 06:37:47 turris hostapd: wlan0: AP-ENABLED
Aug 28 06:39:04 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:40:00 turris crond[9521]: (root) CMD (/usr/bin/notifier)
Aug 28 06:40:00 turris crond[9520]: (root) CMDOUT (There is no message to send.)
Aug 28 06:40:00 turris crond[9520]: (root) CMDEND (/usr/bin/notifier)
Aug 28 06:41:17 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:43:10 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:45:00 turris crond[10007]: (root) CMD (/usr/bin/notifier)
Aug 28 06:45:00 turris crond[10006]: (root) CMDOUT (There is no message to send.)
Aug 28 06:45:00 turris crond[10006]: (root) CMDEND (/usr/bin/notifier)
Aug 28 06:45:07 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:47:10 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:49:08 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:50:00 turris crond[10578]: (root) CMD (/usr/bin/notifier)
Aug 28 06:50:00 turris crond[10577]: (root) CMDOUT (There is no message to send.)
Aug 28 06:50:00 turris crond[10577]: (root) CMDEND (/usr/bin/notifier)
Aug 28 08:50:45 turris kernel: [  893.381938] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
Aug 28 06:51:21 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:53:19 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:55:00 turris crond[11067]: (root) CMD (/usr/bin/notifier)
Aug 28 06:55:00 turris crond[11066]: (root) CMDOUT (There is no message to send.)
Aug 28 06:55:00 turris crond[11066]: (root) CMDEND (/usr/bin/notifier)
Aug 28 06:55:27 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:57:20 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 06:59:28 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:00:00 turris crond[11663]: (root) CMD (/usr/bin/notifier)
Aug 28 07:00:01 turris crond[11662]: (root) CMDOUT (There is no message to send.)
Aug 28 07:00:01 turris crond[11662]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:01:30 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:03:38 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:05:00 turris crond[12163]: (root) CMD (/usr/bin/notifier)
Aug 28 07:05:00 turris crond[12162]: (root) CMDOUT (There is no message to send.)
Aug 28 07:05:00 turris crond[12162]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:05:36 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:07:29 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:09:42 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:10:00 turris crond[12744]: (root) CMD (/usr/bin/notifier)
Aug 28 07:10:00 turris crond[12743]: (root) CMDOUT (There is no message to send.)
Aug 28 07:10:00 turris crond[12743]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:11:40 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:12:00 turris crond[12960]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
Aug 28 07:12:00 turris crond[12959]: (root) CMDEND (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
Aug 28 07:13:37 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:15:00 turris crond[13237]: (root) CMD (/usr/bin/notifier)
Aug 28 07:15:00 turris crond[13236]: (root) CMDOUT (There is no message to send.)
Aug 28 07:15:00 turris crond[13236]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:15:30 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:17:43 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:19:56 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:20:00 turris crond[13800]: (root) CMD (/usr/bin/notifier)
Aug 28 07:20:00 turris crond[13799]: (root) CMDOUT (There is no message to send.)
Aug 28 07:20:00 turris crond[13799]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:21:54 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:23:47 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:25:00 turris crond[14296]: (root) CMD (/usr/bin/notifier)
Aug 28 07:25:00 turris crond[14295]: (root) CMDOUT (There is no message to send.)
Aug 28 07:25:00 turris crond[14295]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:26:00 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:27:58 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:30:00 turris crond[14857]: (root) CMD (/usr/bin/notifier)
Aug 28 07:30:00 turris crond[14856]: (root) CMDOUT (There is no message to send.)
Aug 28 07:30:00 turris crond[14856]: (root) CMDEND (/usr/bin/notifier)
Aug 28 07:30:00 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 28 07:31:21 turris hostapd: wlan0: STA 6a:ea:ba:da:03:3a IEEE 802.11: authenticated
Aug 28 07:31:21 turris hostapd: wlan0: STA 6a:ea:ba:da:03:3a IEEE 802.11: associated (aid 1)
Aug 28 07:31:21 turris hostapd: wlan0: AP-STA-CONNECTED 000000000000000
Aug 28 07:31:21 turris hostapd: wlan0: STA 000000000000000 RADIUS: starting accounting session BAE795CC025DD083
Aug 28 07:31:21 turris hostapd: wlan0: STA 000000000000000 WPA: pairwise key handshake completed (RSN)
Aug 28 07:31:21 turris hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED 000000000000000
Aug 28 09:31:21 turris dnsmasq-dhcp[4959]: DHCPREQUEST(br-lan) 192.168.3.141 000000000000000
Aug 28 09:31:21 turris dnsmasq-dhcp[4959]: DHCPACK(br-lan) 192.168.3.141 000000000000000 000000000000000
Aug 28 07:31:22 turris dhcp_host_domain_ng.py: DHCP add new hostname [000000000000000,192.168.3.141]
Aug 28 07:31:22 turris dhcp_host_domain_ng.py: Refresh kresd leases
Aug 28 07:32:03 turris hostapd: wlan0: AP-STA-DISCONNECTED 000000000000000
Aug 29 06:33:36 turris dhcp_host_domain_ng.py: Refresh kresd leases
Aug 29 06:35:00 turris crond[1184]: (root) CMD (/usr/bin/notifier)
Aug 29 06:35:00 turris crond[1183]: (root) CMDOUT (There is no message to send.)
Aug 29 06:35:00 turris crond[1183]: (root) CMDEND (/usr/bin/notifier)
Aug 29 06:35:39 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:36:31 turris hostapd: guest_turris_1: STA 000000000000000 WPA: group key handshake completed (RSN)
Aug 29 06:36:36 turris pppd[6277]: LCP terminated by peer
Aug 29 06:36:36 turris pppd[6277]: Connect time 1440.1 minutes.
Aug 29 06:36:36 turris pppd[6277]: Sent 60190874 bytes, received 389402705 bytes.
Aug 29 06:36:36 turris netifd: Network device 'pppoe-wan' link is down
Aug 29 06:36:36 turris netifd: Network alias 'pppoe-wan' link is down
Aug 29 06:36:36 turris netifd: Interface 'wan6' has link connectivity loss
Aug 29 06:36:36 turris odhcp6c[6431]: Failed to send RS (Network unreachable)
Aug 29 06:36:36 turris netifd: Interface 'wan' has lost the connection
Aug 29 06:36:36 turris pppd[6277]: Modem hangup
Aug 29 06:36:36 turris pppd[6277]: Connection terminated.
Aug 29 06:36:36 turris pppd[6277]: Exit.
Aug 29 06:36:36 turris netifd: Interface 'wan' is now down
Aug 29 06:36:36 turris odhcp6c[6431]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 08:36:36 turris kernel: [86437.713722] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:36 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:36 turris kernel: [86437.734799] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:36 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:36 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:36 turris netifd: Interface 'wan6' is now down
Aug 29 06:36:36 turris netifd: Interface 'wan6' is disabled
Aug 29 06:36:36 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:36 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:36 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:36 turris kernel: [86437.778737] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:36 turris kernel: [86437.787876] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:36 turris kernel: [86437.794419] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:36 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:36 turris netifd: VLAN 'eth2.37' link is up
Aug 29 08:36:36 turris kernel: [86437.862228] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 08:36:36 turris kernel: [86437.894950] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:37 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:37 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:37 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:37 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:37 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:37 turris kernel: [86437.940178] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:37 turris kernel: [86437.966268] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:37 turris kernel: [86437.972903] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:37 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:37 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:37 turris insmod: module is already loaded - slhc
Aug 29 06:36:37 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:37 turris insmod: module is already loaded - pppox
Aug 29 06:36:37 turris insmod: module is already loaded - pppoe
Aug 29 06:36:37 turris netifd: wan (1556): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:38 turris netifd: Interface 'wan' is now down
Aug 29 08:36:38 turris kernel: [86439.151092] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:38 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:38 turris kernel: [86439.175620] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:38 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:38 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:38 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:38 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:38 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:38 turris kernel: [86439.219215] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:36:38 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:38 turris netifd: VLAN 'eth2.37' link is up
Aug 29 08:36:38 turris kernel: [86439.245102] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:38 turris kernel: [86439.251685] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:38 turris insmod: module is already loaded - slhc
Aug 29 06:36:38 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:38 turris insmod: module is already loaded - pppox
Aug 29 06:36:38 turris insmod: module is already loaded - pppoe
Aug 29 06:36:38 turris netifd: wan (1740): ppp: warning: Sleeping for '10' seconds
Aug 29 08:36:38 turris dnsmasq-dhcp[4959]: DHCPREQUEST(br-guest-turris) 10.111.222.244 000000000000000
Aug 29 08:36:38 turris dnsmasq-dhcp[4959]: DHCPACK(br-guest-turris) 10.111.222.244 000000000000000 000000000000000
Aug 29 06:36:39 turris netifd: Interface 'wan' is now down
Aug 29 08:36:39 turris kernel: [86440.420741] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:39 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:39 turris kernel: [86440.445617] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:39 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:39 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:39 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:39 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:39 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:39 turris kernel: [86440.489337] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:39 turris kernel: [86440.500915] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:39 turris kernel: [86440.507579] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:39 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:39 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:39 turris insmod: module is already loaded - slhc
Aug 29 06:36:39 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:39 turris insmod: module is already loaded - pppox
Aug 29 06:36:39 turris insmod: module is already loaded - pppoe
Aug 29 06:36:39 turris netifd: wan (1923): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:39 turris ddns-scripts[7536]: afraid_org: PID '7536' terminated by 'SIGTERM' at 2024-08-29 08:36
Aug 29 06:36:40 turris netifd: Interface 'wan' is now down
Aug 29 06:36:40 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:40 turris kernel: [86441.640779] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 08:36:40 turris kernel: [86441.653720] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:40 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:40 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:40 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:40 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:40 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:40 turris kernel: [86441.697218] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:40 turris kernel: [86441.705126] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:40 turris kernel: [86441.711698] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:40 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:40 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:40 turris insmod: module is already loaded - slhc
Aug 29 06:36:40 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:40 turris insmod: module is already loaded - pppox
Aug 29 06:36:40 turris insmod: module is already loaded - pppoe
Aug 29 06:36:40 turris netifd: wan (2047): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:41 turris netifd: Interface 'wan' is now down
Aug 29 08:36:42 turris kernel: [86442.950756] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:42 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:42 turris kernel: [86442.983794] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:42 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:42 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:42 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:42 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:42 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:42 turris kernel: [86443.027236] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:36:42 turris netifd: Network device 'eth2' link is up
Aug 29 08:36:42 turris kernel: [86443.045845] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:42 turris kernel: [86443.052501] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:42 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:42 turris insmod: module is already loaded - slhc
Aug 29 06:36:42 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:42 turris insmod: module is already loaded - pppox
Aug 29 06:36:42 turris insmod: module is already loaded - pppoe
Aug 29 06:36:42 turris netifd: wan (2205): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:43 turris netifd: Interface 'wan' is now down
Aug 29 08:36:43 turris kernel: [86444.160496] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:43 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:43 turris kernel: [86444.189126] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:43 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:43 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:43 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:43 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:43 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:43 turris kernel: [86444.232239] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:43 turris kernel: [86444.240286] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:43 turris kernel: [86444.246886] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:43 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:43 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:43 turris insmod: module is already loaded - slhc
Aug 29 06:36:43 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:43 turris insmod: module is already loaded - pppox
Aug 29 06:36:43 turris insmod: module is already loaded - pppoe
Aug 29 06:36:43 turris netifd: wan (2387): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:44 turris netifd: Interface 'wan' is now down
Aug 29 08:36:44 turris kernel: [86445.380549] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:44 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:44 turris kernel: [86445.404108] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:44 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:44 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:44 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:44 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:44 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:44 turris kernel: [86445.447235] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:44 turris kernel: [86445.455141] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:44 turris kernel: [86445.461852] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:44 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:44 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:44 turris insmod: module is already loaded - slhc
Aug 29 06:36:44 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:44 turris insmod: module is already loaded - pppox
Aug 29 06:36:44 turris insmod: module is already loaded - pppoe
Aug 29 06:36:44 turris netifd: wan (2540): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:45 turris netifd: Interface 'wan' is now down
Aug 29 08:36:45 turris kernel: [86446.610656] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:45 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:45 turris kernel: [86446.634504] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:45 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:45 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:45 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:45 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:45 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:45 turris kernel: [86446.678251] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:45 turris kernel: [86446.687092] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:45 turris kernel: [86446.693633] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:45 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:45 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:45 turris insmod: module is already loaded - slhc
Aug 29 06:36:45 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:45 turris insmod: module is already loaded - pppox
Aug 29 06:36:45 turris insmod: module is already loaded - pppoe
Aug 29 06:36:45 turris netifd: wan (2709): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:46 turris netifd: Interface 'wan' is now down
Aug 29 08:36:46 turris kernel: [86447.830248] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:46 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:46 turris kernel: [86447.853673] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:46 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:46 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:46 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:46 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:46 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:46 turris kernel: [86447.897248] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:46 turris kernel: [86447.905135] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:46 turris kernel: [86447.911713] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:46 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:46 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:47 turris insmod: module is already loaded - slhc
Aug 29 06:36:47 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:47 turris insmod: module is already loaded - pppox
Aug 29 06:36:47 turris insmod: module is already loaded - pppoe
Aug 29 06:36:47 turris netifd: wan (2879): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:48 turris netifd: Interface 'wan' is now down
Aug 29 08:36:48 turris kernel: [86449.090172] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:48 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:48 turris kernel: [86449.132501] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:48 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:48 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:48 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:48 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:48 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:48 turris kernel: [86449.176325] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:48 turris kernel: [86449.184205] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:48 turris kernel: [86449.190802] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:48 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:48 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:48 turris insmod: module is already loaded - slhc
Aug 29 06:36:48 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:48 turris insmod: module is already loaded - pppox
Aug 29 06:36:48 turris insmod: module is already loaded - pppoe
Aug 29 06:36:48 turris netifd: wan (2967): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:49 turris netifd: Interface 'wan' is now down
Aug 29 08:36:49 turris kernel: [86450.270113] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:49 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:49 turris kernel: [86450.287491] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:49 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:49 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:49 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:49 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:49 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:49 turris kernel: [86450.331261] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:36:49 turris insmod: module is already loaded - slhc
Aug 29 06:36:49 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:49 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:49 turris insmod: module is already loaded - pppox
Aug 29 08:36:49 turris kernel: [86450.352935] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:49 turris kernel: [86450.359543] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:49 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:49 turris insmod: module is already loaded - pppoe
Aug 29 06:36:49 turris netifd: wan (3205): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:50 turris netifd: Interface 'wan' is now down
Aug 29 08:36:50 turris kernel: [86451.509970] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:50 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:50 turris kernel: [86451.542598] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:50 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:50 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:50 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:50 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:50 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:50 turris kernel: [86451.586258] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:50 turris kernel: [86451.594165] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:50 turris kernel: [86451.600742] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:50 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:50 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:50 turris insmod: module is already loaded - slhc
Aug 29 06:36:50 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:50 turris insmod: module is already loaded - pppox
Aug 29 06:36:50 turris insmod: module is already loaded - pppoe
Aug 29 06:36:50 turris netifd: wan (3311): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:51 turris netifd: Interface 'wan' is now down
Aug 29 08:36:51 turris kernel: [86452.739984] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:51 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:51 turris kernel: [86452.761910] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:51 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:51 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:51 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:51 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:51 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:51 turris kernel: [86452.805254] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:51 turris kernel: [86452.813155] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:51 turris kernel: [86452.819719] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:51 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:51 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:51 turris insmod: module is already loaded - slhc
Aug 29 06:36:51 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:51 turris insmod: module is already loaded - pppox
Aug 29 06:36:51 turris insmod: module is already loaded - pppoe
Aug 29 06:36:51 turris netifd: wan (3467): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:52 turris netifd: Interface 'wan' is now down
Aug 29 08:36:52 turris kernel: [86453.864383] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:52 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:52 turris kernel: [86453.881752] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:52 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:52 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:52 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:52 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:52 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:53 turris kernel: [86453.925263] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:36:53 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:53 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:53 turris netifd: Interface 'wan' has link connectivity
Aug 29 08:36:53 turris kernel: [86453.940368] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:53 turris kernel: [86453.946956] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:53 turris insmod: module is already loaded - slhc
Aug 29 06:36:53 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:53 turris insmod: module is already loaded - pppox
Aug 29 06:36:53 turris insmod: module is already loaded - pppoe
Aug 29 06:36:53 turris netifd: wan (3590): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:54 turris netifd: Interface 'wan' is now down
Aug 29 08:36:54 turris kernel: [86455.029671] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:54 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:54 turris kernel: [86455.050118] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:54 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:54 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:54 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:54 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:54 turris netifd: Network device 'eth2' link is down
Aug 29 06:36:54 turris insmod: module is already loaded - slhc
Aug 29 06:36:54 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:54 turris insmod: module is already loaded - pppox
Aug 29 08:36:54 turris kernel: [86455.093284] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:54 turris kernel: [86455.103804] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:54 turris kernel: [86455.110409] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:54 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:54 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:54 turris insmod: module is already loaded - pppoe
Aug 29 06:36:54 turris netifd: wan (3770): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:55 turris netifd: Interface 'wan' is now down
Aug 29 08:36:55 turris kernel: [86456.179517] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:55 turris netifd: Interface 'wan' is disabled
Aug 29 06:36:55 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:55 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:55 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:55 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:55 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:55 turris kernel: [86456.199190] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 08:36:55 turris kernel: [86456.242279] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:55 turris kernel: [86456.256051] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:55 turris kernel: [86456.262650] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:55 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:55 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:55 turris insmod: module is already loaded - slhc
Aug 29 06:36:55 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:55 turris insmod: module is already loaded - pppox
Aug 29 06:36:55 turris insmod: module is already loaded - pppoe
Aug 29 06:36:55 turris netifd: wan (3954): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:56 turris netifd: Interface 'wan' is now down
Aug 29 08:36:56 turris kernel: [86457.339525] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:56 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:56 turris kernel: [86457.372555] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:56 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:56 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:56 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:56 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:56 turris netifd: Network device 'eth2' link is down
Aug 29 06:36:56 turris insmod: module is already loaded - slhc
Aug 29 08:36:56 turris kernel: [86457.416288] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:36:56 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:56 turris insmod: module is already loaded - pppox
Aug 29 06:36:56 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:56 turris insmod: module is already loaded - pppoe
Aug 29 08:36:56 turris kernel: [86457.434421] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:56 turris kernel: [86457.441096] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:56 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:56 turris netifd: wan (4118): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:57 turris netifd: Interface 'wan' is now down
Aug 29 06:36:57 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:57 turris kernel: [86458.469431] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 08:36:57 turris kernel: [86458.483022] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:57 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:57 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:57 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:57 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:57 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:57 turris kernel: [86458.530868] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:57 turris kernel: [86458.539388] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:57 turris kernel: [86458.545974] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:57 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:57 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:57 turris insmod: module is already loaded - slhc
Aug 29 06:36:57 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:57 turris insmod: module is already loaded - pppox
Aug 29 06:36:57 turris insmod: module is already loaded - pppoe
Aug 29 06:36:57 turris netifd: wan (4281): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:58 turris netifd: Interface 'wan' is now down
Aug 29 08:36:58 turris kernel: [86459.589406] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:58 turris netifd: Interface 'wan' is disabled
Aug 29 08:36:58 turris kernel: [86459.621717] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:58 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:58 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:58 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:58 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:58 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:58 turris kernel: [86459.665297] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:36:58 turris insmod: module is already loaded - slhc
Aug 29 06:36:58 turris insmod: module is already loaded - ppp_generic
Aug 29 06:36:58 turris insmod: module is already loaded - pppox
Aug 29 08:36:58 turris kernel: [86459.694542] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:58 turris kernel: [86459.701084] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:58 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:58 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:58 turris insmod: module is already loaded - pppoe
Aug 29 06:36:58 turris netifd: wan (4450): ppp: warning: Sleeping for '10' seconds
Aug 29 06:36:59 turris netifd: Interface 'wan' is now down
Aug 29 08:36:59 turris kernel: [86460.729184] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:36:59 turris netifd: Interface 'wan' is disabled
Aug 29 06:36:59 turris netifd: Interface 'wan' is enabled
Aug 29 06:36:59 turris netifd: Interface 'wan' is setting up now
Aug 29 06:36:59 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:36:59 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:36:59 turris netifd: Network device 'eth2' link is down
Aug 29 08:36:59 turris kernel: [86460.749085] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:36:59 turris insmod: module is already loaded - slhc
Aug 29 06:36:59 turris insmod: module is already loaded - ppp_generic
Aug 29 08:36:59 turris kernel: [86460.792296] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:36:59 turris kernel: [86460.801547] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:36:59 turris kernel: [86460.808136] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:36:59 turris netifd: Network device 'eth2' link is up
Aug 29 06:36:59 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:36:59 turris insmod: module is already loaded - pppox
Aug 29 06:36:59 turris insmod: module is already loaded - pppoe
Aug 29 06:36:59 turris netifd: wan (4604): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:00 turris netifd: Interface 'wan' is now down
Aug 29 08:37:00 turris kernel: [86461.849202] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:00 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:00 turris kernel: [86461.873566] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:00 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:00 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:00 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:00 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:00 turris netifd: Network device 'eth2' link is down
Aug 29 06:37:00 turris insmod: module is already loaded - slhc
Aug 29 08:37:01 turris kernel: [86461.917307] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:01 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:01 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:01 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:01 turris netifd: Interface 'wan' has link connectivity
Aug 29 08:37:01 turris kernel: [86461.936825] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:01 turris kernel: [86461.943365] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:01 turris insmod: module is already loaded - pppox
Aug 29 06:37:01 turris insmod: module is already loaded - pppoe
Aug 29 06:37:01 turris netifd: wan (4732): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:02 turris netifd: Interface 'wan' is now down
Aug 29 06:37:02 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:02 turris kernel: [86463.019070] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 08:37:02 turris kernel: [86463.034760] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:02 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:02 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:02 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:02 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:02 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:02 turris kernel: [86463.078313] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:02 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:02 turris netifd: VLAN 'eth2.37' link is up
Aug 29 08:37:02 turris kernel: [86463.099060] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:02 turris kernel: [86463.105599] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:02 turris insmod: module is already loaded - slhc
Aug 29 06:37:02 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:02 turris insmod: module is already loaded - pppox
Aug 29 06:37:02 turris insmod: module is already loaded - pppoe
Aug 29 06:37:02 turris netifd: wan (4919): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:03 turris netifd: Interface 'wan' is now down
Aug 29 08:37:03 turris kernel: [86464.208845] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:03 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:03 turris kernel: [86464.226767] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:03 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:03 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:03 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:03 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:03 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:03 turris kernel: [86464.270312] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:03 turris kernel: [86464.278276] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:03 turris kernel: [86464.284873] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:03 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:03 turris insmod: module is already loaded - slhc
Aug 29 06:37:03 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:03 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:03 turris insmod: module is already loaded - pppox
Aug 29 06:37:03 turris insmod: module is already loaded - pppoe
Aug 29 06:37:03 turris netifd: wan (5078): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:04 turris netifd: Interface 'wan' is now down
Aug 29 08:37:04 turris kernel: [86465.378846] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:04 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:04 turris kernel: [86465.402340] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:04 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:04 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:04 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:04 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:04 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:04 turris kernel: [86465.446316] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:04 turris kernel: [86465.464084] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 06:37:04 turris netifd: Network device 'eth2' link is up
Aug 29 08:37:04 turris kernel: [86465.470643] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:04 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:04 turris insmod: module is already loaded - slhc
Aug 29 06:37:04 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:04 turris insmod: module is already loaded - pppox
Aug 29 06:37:04 turris insmod: module is already loaded - pppoe
Aug 29 06:37:04 turris netifd: wan (5252): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:05 turris netifd: Interface 'wan' is now down
Aug 29 08:37:05 turris kernel: [86466.498854] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:05 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:05 turris kernel: [86466.520412] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:05 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:05 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:05 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:05 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:05 turris netifd: Network device 'eth2' link is down
Aug 29 06:37:05 turris insmod: module is already loaded - slhc
Aug 29 06:37:05 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:05 turris insmod: module is already loaded - pppox
Aug 29 08:37:05 turris kernel: [86466.564555] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:05 turris insmod: module is already loaded - pppoe
Aug 29 06:37:05 turris netifd: wan (5415): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:05 turris netifd: Network device 'eth2' link is up
Aug 29 08:37:05 turris kernel: [86466.580571] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:05 turris kernel: [86466.587164] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:05 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:06 turris netifd: Interface 'wan' is now down
Aug 29 08:37:06 turris kernel: [86467.678606] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:06 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:06 turris kernel: [86467.701577] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:06 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:06 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:06 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:06 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:06 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:06 turris kernel: [86467.745325] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:06 turris kernel: [86467.753391] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:06 turris kernel: [86467.760076] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:06 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:06 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:06 turris insmod: module is already loaded - slhc
Aug 29 06:37:06 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:06 turris insmod: module is already loaded - pppox
Aug 29 06:37:06 turris insmod: module is already loaded - pppoe
Aug 29 06:37:06 turris netifd: wan (5605): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:07 turris netifd: Interface 'wan' is now down
Aug 29 08:37:07 turris kernel: [86468.798594] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:07 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:07 turris kernel: [86468.821388] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:07 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:07 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:07 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:07 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:07 turris netifd: Network device 'eth2' link is down
Aug 29 06:37:07 turris insmod: module is already loaded - slhc
Aug 29 08:37:07 turris kernel: [86468.865337] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:07 turris kernel: [86468.873306] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:07 turris kernel: [86468.879884] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:07 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:07 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:07 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:07 turris insmod: module is already loaded - pppox
Aug 29 06:37:07 turris insmod: module is already loaded - pppoe
Aug 29 06:37:07 turris netifd: wan (5762): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:08 turris netifd: Interface 'wan' is now down
Aug 29 08:37:09 turris kernel: [86469.918643] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:09 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:09 turris kernel: [86469.942226] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:09 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:09 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:09 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:09 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:09 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:09 turris kernel: [86469.985335] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:09 turris kernel: [86469.993224] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:09 turris kernel: [86469.999946] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:09 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:09 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:09 turris insmod: module is already loaded - slhc
Aug 29 06:37:09 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:09 turris insmod: module is already loaded - pppox
Aug 29 06:37:09 turris insmod: module is already loaded - pppoe
Aug 29 06:37:09 turris netifd: wan (5929): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:10 turris netifd: Interface 'wan' is now down
Aug 29 08:37:10 turris kernel: [86471.038522] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:10 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:10 turris kernel: [86471.065585] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:10 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:10 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:10 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:10 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:10 turris netifd: Network device 'eth2' link is down
Aug 29 06:37:10 turris insmod: module is already loaded - slhc
Aug 29 06:37:10 turris insmod: module is already loaded - ppp_generic
Aug 29 08:37:10 turris kernel: [86471.109365] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:10 turris kernel: [86471.119593] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:10 turris kernel: [86471.126240] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:10 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:10 turris insmod: module is already loaded - pppox
Aug 29 06:37:10 turris insmod: module is already loaded - pppoe
Aug 29 06:37:10 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:10 turris netifd: wan (6103): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:11 turris netifd: Interface 'wan' is now down
Aug 29 08:37:11 turris kernel: [86472.258634] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:11 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:11 turris kernel: [86472.284932] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:11 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:11 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:11 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:11 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:11 turris netifd: Network device 'eth2' link is down
Aug 29 06:37:11 turris insmod: module is already loaded - slhc
Aug 29 06:37:11 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:11 turris insmod: module is already loaded - pppox
Aug 29 06:37:11 turris insmod: module is already loaded - pppoe
Aug 29 06:37:11 turris netifd: wan (6317): ppp: warning: Sleeping for '10' seconds
Aug 29 08:37:11 turris kernel: [86472.328346] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:11 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:11 turris netifd: VLAN 'eth2.37' link is up
Aug 29 08:37:11 turris kernel: [86472.344113] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:11 turris kernel: [86472.350717] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:12 turris netifd: Interface 'wan' is now down
Aug 29 06:37:12 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:12 turris kernel: [86473.408206] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 08:37:12 turris kernel: [86473.420885] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:12 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:12 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:12 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:12 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:12 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:12 turris kernel: [86473.464348] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:12 turris kernel: [86473.472239] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:12 turris kernel: [86473.478798] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:12 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:12 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:12 turris insmod: module is already loaded - slhc
Aug 29 06:37:12 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:12 turris insmod: module is already loaded - pppox
Aug 29 06:37:12 turris insmod: module is already loaded - pppoe
Aug 29 06:37:12 turris netifd: wan (6443): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:13 turris netifd: Interface 'wan' is now down
Aug 29 08:37:13 turris kernel: [86474.537989] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:13 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:13 turris kernel: [86474.576262] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:13 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:13 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:13 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:13 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:13 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:13 turris kernel: [86474.619406] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:13 turris kernel: [86474.627458] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:13 turris kernel: [86474.634118] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:13 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:13 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:13 turris insmod: module is already loaded - slhc
Aug 29 06:37:13 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:13 turris insmod: module is already loaded - pppox
Aug 29 06:37:13 turris insmod: module is already loaded - pppoe
Aug 29 06:37:13 turris netifd: wan (6624): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:14 turris netifd: Interface 'wan' is now down
Aug 29 08:37:14 turris kernel: [86475.727976] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:14 turris netifd: Interface 'wan' is disabled
Aug 29 06:37:14 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:14 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:14 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:14 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:14 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:14 turris kernel: [86475.747669] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:14 turris insmod: module is already loaded - slhc
Aug 29 08:37:14 turris kernel: [86475.791362] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:14 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:14 turris insmod: module is already loaded - pppox
Aug 29 06:37:14 turris insmod: module is already loaded - pppoe
Aug 29 06:37:14 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:14 turris netifd: wan (6782): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:14 turris netifd: VLAN 'eth2.37' link is up
Aug 29 08:37:14 turris kernel: [86475.807558] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:14 turris kernel: [86475.814143] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:15 turris netifd: Interface 'wan' is now down
Aug 29 08:37:15 turris kernel: [86476.868014] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:15 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:15 turris kernel: [86476.891814] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:15 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:15 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:15 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:15 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:15 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:16 turris kernel: [86476.935359] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:16 turris netifd: Network device 'eth2' link is up
Aug 29 08:37:16 turris kernel: [86476.955049] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:16 turris kernel: [86476.961660] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:16 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:16 turris netifd: Interface 'wan' has link connectivity
Aug 29 06:37:16 turris netifd: Interface 'wan' is now down
Aug 29 08:37:16 turris kernel: [86477.080510] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:16 turris netifd: Interface 'wan' is disabled
Aug 29 06:37:16 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:16 turris netifd: Interface 'wan' is setting up now
Aug 29 08:37:16 turris kernel: [86477.106646] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:16 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:16 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:16 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:16 turris kernel: [86477.150359] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:16 turris kernel: [86477.163176] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:16 turris kernel: [86477.170705] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:16 turris insmod: module is already loaded - slhc
Aug 29 06:37:16 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:16 turris insmod: module is already loaded - pppox
Aug 29 06:37:16 turris insmod: module is already loaded - pppoe
Aug 29 06:37:16 turris netifd: wan (7039): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:17 turris netifd: Interface 'wan' is now down
Aug 29 08:37:17 turris kernel: [86478.187890] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:17 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:17 turris kernel: [86478.211991] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:17 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:17 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:17 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:17 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:17 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:17 turris kernel: [86478.255384] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:17 turris kernel: [86478.267814] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:17 turris kernel: [86478.274450] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:17 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:17 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:17 turris insmod: module is already loaded - slhc
Aug 29 06:37:17 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:17 turris insmod: module is already loaded - pppox
Aug 29 06:37:17 turris insmod: module is already loaded - pppoe
Aug 29 06:37:17 turris netifd: wan (7163): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:18 turris netifd: Interface 'wan' is now down
Aug 29 08:37:18 turris kernel: [86479.317675] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:18 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:18 turris kernel: [86479.336722] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:18 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:18 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:18 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:18 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:18 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:18 turris kernel: [86479.380379] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:18 turris kernel: [86479.388765] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:18 turris kernel: [86479.395382] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:18 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:18 turris insmod: module is already loaded - slhc
Aug 29 06:37:18 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:18 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:18 turris insmod: module is already loaded - pppox
Aug 29 06:37:18 turris insmod: module is already loaded - pppoe
Aug 29 06:37:18 turris netifd: wan (7341): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:19 turris netifd: Interface 'wan' is now down
Aug 29 08:37:19 turris kernel: [86480.457533] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:19 turris netifd: Interface 'wan' is disabled
Aug 29 06:37:19 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:19 turris netifd: Interface 'wan' is setting up now
Aug 29 06:37:19 turris netifd: VLAN 'eth2.37' link is down
Aug 29 06:37:19 turris netifd: Interface 'wan' has link connectivity loss
Aug 29 06:37:19 turris netifd: Network device 'eth2' link is down
Aug 29 08:37:19 turris kernel: [86480.477095] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:19 turris insmod: module is already loaded - slhc
Aug 29 06:37:19 turris netifd: Network device 'eth2' link is up
Aug 29 06:37:19 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:19 turris insmod: module is already loaded - pppox
Aug 29 06:37:19 turris insmod: module is already loaded - pppoe
Aug 29 08:37:19 turris kernel: [86480.520377] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 08:37:19 turris kernel: [86480.529426] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Aug 29 08:37:19 turris kernel: [86480.536065] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.37: link becomes ready
Aug 29 06:37:19 turris netifd: VLAN 'eth2.37' link is up
Aug 29 06:37:19 turris netifd: wan (7508): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:20 turris netifd: Interface 'wan' is now down
Aug 29 08:37:20 turris kernel: [86481.637772] mvneta f1034000.ethernet eth2: Link is Down
Aug 29 06:37:20 turris netifd: Interface 'wan' is disabled
Aug 29 08:37:20 turris kernel: [86481.659209] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
Aug 29 06:37:20 turris netifd: Interface 'wan' is enabled
Aug 29 06:37:20 turris netifd: Interface 'wan' is setting up now
Aug 29 08:37:20 turris kernel: [86481.702392] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Aug 29 06:37:20 turris insmod: module is already loaded - slhc
Aug 29 06:37:20 turris insmod: module is already loaded - ppp_generic
Aug 29 06:37:20 turris insmod: module is already loaded - pppox
Aug 29 06:37:20 turris insmod: module is already loaded - pppoe
Aug 29 06:37:20 turris netifd: wan (7726): ppp: warning: Sleeping for '10' seconds
Aug 29 06:37:25 turris adblock-4.1.5[7937]: adblock instance started ::: action: start, priority: 0, pid: 7937
Aug 29 06:37:30 turris pppd[8094]: Plugin pppoe.so loaded.
Aug 29 06:37:30 turris pppd[8094]: PPPoE plugin from pppd 2.4.9
Aug 29 06:37:31 turris pppd[8094]: pppd 2.4.9 started by root, uid 0
Aug 29 06:37:36 turris pppd[8094]: PPP session is 37454
Aug 29 06:37:36 turris pppd[8094]: Connected to 000000000000000 via interface eth2.37
Aug 29 08:37:36 turris kernel: [86497.142060] pppoe-wan: renamed from ppp0
Aug 29 06:37:36 turris pppd[8094]: Renamed interface ppp0 to pppoe-wan
Aug 29 06:37:36 turris pppd[8094]: Using interface pppoe-wan
Aug 29 06:37:36 turris pppd[8094]: Connect: pppoe-wan <--> eth2.37
Aug 29 06:37:36 turris pppd[8094]: CHAP authentication succeeded: Authentication Successful,Welcome!
Aug 29 06:37:36 turris pppd[8094]: peer from calling number 000000000000000 authorized
Aug 29 06:37:36 turris pppd[8094]: local  IP address 212.86.63.237
Aug 29 06:37:36 turris pppd[8094]: remote IP address 212.86.62.1
Aug 29 06:37:36 turris pppd[8094]: primary   DNS address 1.1.1.1
Aug 29 06:37:36 turris pppd[8094]: secondary DNS address 8.8.8.8
Aug 29 06:37:36 turris netifd: Network device 'pppoe-wan' link is up
Aug 29 06:37:36 turris netifd: Interface 'wan6' is enabled
Aug 29 06:37:36 turris netifd: Network alias 'pppoe-wan' link is up
Aug 29 06:37:36 turris netifd: Interface 'wan6' has link connectivity
Aug 29 06:37:36 turris netifd: Interface 'wan6' is setting up now
Aug 29 06:37:36 turris netifd: Interface 'wan' is now up
Aug 29 06:37:36 turris odhcp6c[8292]: Failed to send RS (Network unreachable)
Aug 29 06:37:36 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:37:36 turris firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Aug 29 06:37:37 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:37:40 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:37:40 turris odhcp6c[8292]: Failed to send RS (Network unreachable)
Aug 29 06:37:40 turris ddns-scripts[8773]: afraid_org: PID '8773' started at 2024-08-29 08:37
Aug 29 06:37:40 turris ddns-scripts[8772]: myddns_ipv4: PID '8772' started at 2024-08-29 08:37
Aug 29 06:37:40 turris ddns-scripts[8772]: myddns_ipv4: Service section disabled! - TERMINATE
Aug 29 06:37:41 turris ddns-scripts[8772]: myddns_ipv4: PID '8772' exit WITH ERROR '1' at 2024-08-29 08:37
Aug 29 06:37:44 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:37:44 turris odhcp6c[8292]: Failed to send RS (Network unreachable)
Aug 29 06:37:47 turris hostapd: wlan0: STA 000000000000000 WPA: group key handshake completed (RSN)
Aug 29 06:37:48 turris odhcp6c[8292]: Failed to send RS (Network unreachable)
Aug 29 06:37:53 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:38:10 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Aug 29 06:38:45 turris odhcp6c[8292]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Any ideas?
Interestingly the omnia didn’t hung up for nearly one weak. But today it happened again.
PS: Of course it was the indiegogo campaign :face_with_hand_over_mouth:.
Post the output of dmesg after the problem appeared
dmedg-output can be seen in the first post. Unfortunately sometimes the omnia hang up complete so I can’t reach it even via ssh.
