First, I’d like to thank you both for your answer!
I agree, this first message was all but ideal on that point, I just did not knew where to start with that.
I tried to focus on wifi related issues tonight, and get you some infos about that. I have some logs from /var/log, but was not able to get any from the foris interface, since this one is unreachable most of the time.
First here are some infos:
Informations:
- foris version: 100.7
- Device Turris Omnia
- Serial number 60129543419
- Turris OS version 4.0.5
- Turris OS branch hbs
- Kernel version 4.14.162
What I did:
- start the router
- login to foris
- try to setup a wifi 5ghz, radio0, 802.11ac, 40mhz, channel auto, wpa2-psk
Wifi does not show on any of my devices. Fiddle around the settings,
try 2Ghz, etc.
Ok, now, let’s check the luCI interface. Same behavior. So I go back to forris
and 500/503. (The index showing choice between foris and luCI is available).
logs at this point:
Feb 18 19:58:49 turris syslog-ng[2958]: syslog-ng starting up; version='3.21.1'
Feb 18 19:58:49 turris kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Feb 18 19:58:49 turris kernel: [ 0.000000] Linux version 4.14.162 (beast@slave10) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 ab9d1bf)) #0 SMP Thu Jan 16 14:01:27 2020
Feb 18 19:58:49 turris kernel: [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Feb 18 19:58:49 turris kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Feb 18 19:58:49 turris kernel: [ 0.000000] OF: fdt: Machine model: Turris Omnia
Feb 18 19:58:49 turris kernel: [ 0.000000] Memory policy: Data cache writealloc
Feb 18 19:58:49 turris kernel: [ 0.000000] On node 0 totalpages: 524288
Feb 18 19:58:49 turris kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0b3a1c0, node_mem_map eedf9000
Feb 18 19:58:49 turris kernel: [ 0.000000] Normal zone: 1728 pages used for memmap
Feb 18 19:58:49 turris kernel: [ 0.000000] Normal zone: 0 pages reserved
Feb 18 19:58:49 turris kernel: [ 0.000000] Normal zone: 196608 pages, LIFO batch:31
Feb 18 19:58:49 turris kernel: [ 0.000000] HighMem zone: 327680 pages, LIFO batch:31
Feb 18 19:58:49 turris kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x78/0x4a8 with crng_init=0
Feb 18 19:58:49 turris kernel: [ 0.000000] percpu: Embedded 11 pages/cpu s14476 r8192 d22388 u45056
Feb 18 19:58:49 turris kernel: [ 0.000000] pcpu-alloc: s14476 r8192 d22388 u45056 alloc=11*4096
Feb 18 19:58:49 turris kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Feb 18 19:58:49 turris kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
Feb 18 19:58:49 turris kernel: [ 0.000000] Kernel command line: earlyprintk rootwait console=ttyS0,115200 rootfstype=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rw cfg80211.freg=**
Feb 18 19:58:49 turris kernel: [ 0.000000] Bootloader command line not present
Feb 18 19:58:49 turris kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb 18 19:58:49 turris kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 18 19:58:49 turris kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 18 19:58:49 turris kernel: [ 0.000000] Memory: 2066956K/2097152K available (7168K kernel code, 234K rwdata, 1772K rodata, 1024K init, 269K bss, 30196K reserved, 0K cma-reserved, 1310720K highmem)
Feb 18 19:58:49 turris kernel: [ 0.000000] Virtual kernel memory layout:
Feb 18 19:58:49 turris kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Feb 18 19:58:49 turris kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Feb 18 19:58:49 turris kernel: [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
Feb 18 19:58:49 turris kernel: [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
Feb 18 19:58:49 turris kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
Feb 18 19:58:49 turris kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
Feb 18 19:58:49 turris kernel: [ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
Feb 18 19:58:49 turris kernel: [ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
Feb 18 19:58:49 turris kernel: [ 0.000000] .data : 0xc0b00000 - 0xc0b3aac0 ( 235 kB)
Feb 18 19:58:49 turris kernel: [ 0.000000] .bss : 0xc0b3aac0 - 0xc0b7e0b0 ( 270 kB)
Feb 18 19:58:49 turris kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Feb 18 19:58:49 turris kernel: [ 0.000000] Hierarchical RCU implementation.
Feb 18 19:58:49 turris kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Feb 18 19:58:49 turris kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Feb 18 19:58:49 turris kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Feb 18 19:58:49 turris kernel: [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
Feb 18 19:58:49 turris kernel: [ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
Feb 18 19:58:49 turris kernel: [ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
Feb 18 19:58:49 turris kernel: [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
Feb 18 19:58:49 turris kernel: [ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
Feb 18 19:58:49 turris kernel: [ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
Feb 18 19:58:49 turris kernel: [ 0.000007] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
Feb 18 19:58:49 turris kernel: [ 0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
Feb 18 19:58:49 turris kernel: [ 0.000031] Switching to timer-based delay loop, resolution 1ns
Feb 18 19:58:49 turris kernel: [ 0.000164] Ignoring duplicate/late registration of read_current_timer delay
Feb 18 19:58:49 turris kernel: [ 0.000171] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Feb 18 19:58:49 turris kernel: [ 0.000326] Console: colour dummy device 80x30
Feb 18 19:58:49 turris kernel: [ 0.000343] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
Feb 18 19:58:49 turris kernel: [ 0.000351] pid_max: default: 32768 minimum: 301
Feb 18 19:58:49 turris kernel: [ 0.000418] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 18 19:58:49 turris kernel: [ 0.000424] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 18 19:58:49 turris kernel: [ 0.000725] CPU: Testing write buffer coherency: ok
Feb 18 19:58:49 turris kernel: [ 0.000737] CPU0: Spectre v2: using BPIALL workaround
Feb 18 19:58:49 turris kernel: [ 0.000859] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Feb 18 19:58:49 turris kernel: [ 0.000982] Setting up static identity map for 0x100000 - 0x100060
Feb 18 19:58:49 turris kernel: [ 0.001059] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
Feb 18 19:58:49 turris kernel: [ 0.001139] mvebu-pmsu: Initializing Power Management Service Unit
Feb 18 19:58:49 turris kernel: [ 0.001188] Hierarchical SRCU implementation.
Feb 18 19:58:49 turris kernel: [ 0.001383] smp: Bringing up secondary CPUs ...
Feb 18 19:58:49 turris kernel: [ 0.001516] Booting CPU 1
Feb 18 19:58:49 turris kernel: [ 0.001696] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Feb 18 19:58:49 turris kernel: [ 0.001698] CPU1: Spectre v2: using BPIALL workaround
Feb 18 19:58:49 turris kernel: [ 0.001751] smp: Brought up 1 node, 2 CPUs
Feb 18 19:58:49 turris kernel: [ 0.001756] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
Feb 18 19:58:49 turris kernel: [ 0.001759] CPU: All CPU(s) started in SVC mode.
Feb 18 19:58:49 turris kernel: [ 0.002294] devtmpfs: initialized
Feb 18 19:58:49 turris kernel: [ 0.003928] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Feb 18 19:58:49 turris kernel: [ 0.003982] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 18 19:58:49 turris kernel: [ 0.003990] futex hash table entries: 512 (order: 3, 32768 bytes)
Feb 18 19:58:49 turris kernel: [ 0.004061] xor: measuring software checksum speed
Feb 18 19:58:49 turris kernel: [ 0.100069] arm4regs : 2379.200 MB/sec
Feb 18 19:58:49 turris kernel: [ 0.200069] 8regs : 1926.800 MB/sec
Feb 18 19:58:49 turris kernel: [ 0.300067] 32regs : 2040.400 MB/sec
Feb 18 19:58:49 turris kernel: [ 0.400067] neon : 1830.400 MB/sec
Feb 18 19:58:49 turris kernel: [ 0.400071] xor: using function: arm4regs (2379.200 MB/sec)
Feb 18 19:58:49 turris kernel: [ 0.400078] pinctrl core: initialized pinctrl subsystem
Feb 18 19:58:49 turris kernel: [ 0.400434] NET: Registered protocol family 16
Feb 18 19:58:49 turris kernel: [ 0.400991] DMA: preallocated 256 KiB pool for atomic coherent allocations
Feb 18 19:58:49 turris kernel: [ 0.401537] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
Feb 18 19:58:49 turris kernel: [ 0.401544] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
Feb 18 19:58:49 turris kernel: [ 0.570169] raid6: int32x1 gen() 171 MB/s
Feb 18 19:58:49 turris kernel: [ 0.740144] raid6: int32x1 xor() 243 MB/s
Feb 18 19:58:49 turris kernel: [ 0.910135] raid6: int32x2 gen() 255 MB/s
Feb 18 19:58:49 turris kernel: [ 1.080165] raid6: int32x2 xor() 288 MB/s
Feb 18 19:58:49 turris kernel: [ 1.250259] raid6: int32x4 gen() 305 MB/s
Feb 18 19:58:49 turris kernel: [ 1.420154] raid6: int32x4 xor() 252 MB/s
Feb 18 19:58:49 turris kernel: [ 1.590083] raid6: int32x8 gen() 330 MB/s
Feb 18 19:58:49 turris kernel: [ 1.760076] raid6: int32x8 xor() 229 MB/s
Feb 18 19:58:49 turris kernel: [ 1.930101] raid6: neonx1 gen() 1111 MB/s
Feb 18 19:58:49 turris kernel: [ 2.100079] raid6: neonx1 xor() 1058 MB/s
Feb 18 19:58:49 turris kernel: [ 2.270102] raid6: neonx2 gen() 1303 MB/s
Feb 18 19:58:49 turris kernel: [ 2.440071] raid6: neonx2 xor() 1350 MB/s
Feb 18 19:58:49 turris kernel: [ 2.610079] raid6: neonx4 gen() 1071 MB/s
Feb 18 19:58:49 turris kernel: [ 2.780076] raid6: neonx4 xor() 1307 MB/s
Feb 18 19:58:49 turris kernel: [ 2.950111] raid6: neonx8 gen() 1014 MB/s
Feb 18 19:58:49 turris kernel: [ 3.120099] raid6: neonx8 xor() 947 MB/s
Feb 18 19:58:49 turris kernel: [ 3.120103] raid6: using algorithm neonx2 gen() 1303 MB/s
Feb 18 19:58:49 turris kernel: [ 3.120106] raid6: .... xor() 1350 MB/s, rmw enabled
Feb 18 19:58:49 turris kernel: [ 3.120109] raid6: using neon recovery algorithm
Feb 18 19:58:49 turris kernel: [ 3.120391] SCSI subsystem initialized
Feb 18 19:58:49 turris kernel: [ 3.120481] libata version 3.00 loaded.
Feb 18 19:58:49 turris kernel: [ 3.120594] usbcore: registered new interface driver usbfs
Feb 18 19:58:49 turris kernel: [ 3.120617] usbcore: registered new interface driver hub
Feb 18 19:58:49 turris kernel: [ 3.120645] usbcore: registered new device driver usb
Feb 18 19:58:49 turris kernel: [ 3.121340] clocksource: Switched to clocksource arm_global_timer
Feb 18 19:58:49 turris kernel: [ 3.125102] NET: Registered protocol family 2
Feb 18 19:58:49 turris kernel: [ 3.125375] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Feb 18 19:58:49 turris kernel: [ 3.125415] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Feb 18 19:58:49 turris kernel: [ 3.125475] TCP: Hash tables configured (established 8192 bind 8192)
Feb 18 19:58:49 turris kernel: [ 3.125525] UDP hash table entries: 512 (order: 2, 16384 bytes)
Feb 18 19:58:49 turris kernel: [ 3.125552] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Feb 18 19:58:49 turris kernel: [ 3.125640] NET: Registered protocol family 1
Feb 18 19:58:49 turris kernel: [ 3.125811] RPC: Registered named UNIX socket transport module.
Feb 18 19:58:49 turris kernel: [ 3.125816] RPC: Registered udp transport module.
Feb 18 19:58:49 turris kernel: [ 3.125819] RPC: Registered tcp transport module.
Feb 18 19:58:49 turris kernel: [ 3.125822] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 18 19:58:49 turris kernel: [ 3.125827] PCI: CLS 0 bytes, default 64
Feb 18 19:58:49 turris kernel: [ 3.126623] Crashlog allocated RAM at address 0x3f00000
Feb 18 19:58:49 turris kernel: [ 3.126721] workingset: timestamp_bits=14 max_order=19 bucket_order=5
Feb 18 19:58:49 turris kernel: [ 3.128754] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Feb 18 19:58:49 turris kernel: [ 3.129207] NFS: Registering the id_resolver key type
Feb 18 19:58:49 turris kernel: [ 3.129223] Key type id_resolver registered
Feb 18 19:58:49 turris kernel: [ 3.129226] Key type id_legacy registered
Feb 18 19:58:49 turris kernel: [ 3.129244] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Feb 18 19:58:49 turris kernel: [ 3.130503] bounce: pool size: 64 pages
Feb 18 19:58:49 turris kernel: [ 3.130513] io scheduler noop registered
Feb 18 19:58:49 turris kernel: [ 3.130517] io scheduler deadline registered (default)
Feb 18 19:58:49 turris kernel: [ 3.130971] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
Feb 18 19:58:49 turris kernel: [ 3.133469] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
Feb 18 19:58:49 turris kernel: [ 3.133482] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
Feb 18 19:58:49 turris kernel: [ 3.133487] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
Feb 18 19:58:49 turris kernel: [ 3.133492] pci_bus 0000:00: root bus resource [bus 00-ff]
Feb 18 19:58:49 turris kernel: [ 3.133508] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
Feb 18 19:58:49 turris kernel: [ 3.133597] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
Feb 18 19:58:49 turris kernel: [ 3.133669] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
Feb 18 19:58:49 turris kernel: [ 3.133740] PCI: bus0: Fast back to back transfers disabled
Feb 18 19:58:49 turris kernel: [ 3.133747] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 18 19:58:49 turris kernel: [ 3.133753] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 18 19:58:49 turris kernel: [ 3.133759] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 18 19:58:49 turris kernel: [ 3.133808] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
Feb 18 19:58:49 turris kernel: [ 3.133835] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
Feb 18 19:58:49 turris kernel: [ 3.133921] pci 0000:01:00.0: supports D1
Feb 18 19:58:49 turris kernel: [ 3.133924] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
Feb 18 19:58:49 turris kernel: [ 3.133983] PCI: bus1: Fast back to back transfers disabled
Feb 18 19:58:49 turris kernel: [ 3.133991] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Feb 18 19:58:49 turris kernel: [ 3.134040] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
Feb 18 19:58:49 turris kernel: [ 3.134065] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Feb 18 19:58:49 turris kernel: [ 3.134090] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Feb 18 19:58:49 turris kernel: [ 3.134150] pci 0000:02:00.0: supports D1 D2
Feb 18 19:58:49 turris kernel: [ 3.134205] PCI: bus2: Fast back to back transfers disabled
Feb 18 19:58:49 turris kernel: [ 3.134211] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
Feb 18 19:58:49 turris kernel: [ 3.134244] PCI: bus3: Fast back to back transfers enabled
Feb 18 19:58:49 turris kernel: [ 3.134250] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Feb 18 19:58:49 turris kernel: [ 3.134268] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
Feb 18 19:58:49 turris kernel: [ 3.134274] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
Feb 18 19:58:49 turris kernel: [ 3.134281] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
Feb 18 19:58:49 turris kernel: [ 3.134291] pci 0000:00:01.0: PCI bridge to [bus 01]
Feb 18 19:58:49 turris kernel: [ 3.134297] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe00fffff]
Feb 18 19:58:49 turris kernel: [ 3.134304] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
Feb 18 19:58:49 turris kernel: [ 3.134314] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
Feb 18 19:58:49 turris kernel: [ 3.134319] pci 0000:00:02.0: PCI bridge to [bus 02]
Feb 18 19:58:49 turris kernel: [ 3.134323] pci 0000:00:02.0: bridge window [mem 0xe0200000-0xe04fffff]
Feb 18 19:58:49 turris kernel: [ 3.134328] pci 0000:00:03.0: PCI bridge to [bus 03]
Feb 18 19:58:49 turris kernel: [ 3.134560] mv_xor f1060800.xor: Marvell shared XOR driver
Feb 18 19:58:49 turris kernel: [ 3.191845] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Feb 18 19:58:49 turris kernel: [ 3.191956] mv_xor f1060900.xor: Marvell shared XOR driver
Feb 18 19:58:49 turris kernel: [ 3.251786] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Feb 18 19:58:49 turris kernel: [ 3.252009] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Feb 18 19:58:49 turris kernel: [ 3.253102] console [ttyS0] disabled
Feb 18 19:58:49 turris kernel: [ 3.273173] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
Feb 18 19:58:49 turris kernel: [ 4.160294] console [ttyS0] enabled
Feb 18 19:58:49 turris kernel: [ 4.184047] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
Feb 18 19:58:49 turris kernel: [ 4.194814] loop: module loaded
Feb 18 19:58:49 turris kernel: [ 4.198275] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
Feb 18 19:58:49 turris kernel: [ 4.207366] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
Feb 18 19:58:49 turris kernel: [ 4.216529] scsi host0: ahci-mvebu
Feb 18 19:58:49 turris kernel: [ 4.220079] scsi host1: ahci-mvebu
Feb 18 19:58:49 turris kernel: [ 4.223566] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
Feb 18 19:58:49 turris kernel: [ 4.231515] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
Feb 18 19:58:49 turris kernel: [ 4.240257] m25p80 spi0.0: found mx25l6405d, expected s25fl164k
Feb 18 19:58:49 turris kernel: [ 4.246238] m25p80 spi0.0: mx25l6405d (8192 Kbytes)
Feb 18 19:58:49 turris kernel: [ 4.251193] 2 fixed-partitions partitions found on MTD device spi0.0
Feb 18 19:58:49 turris kernel: [ 4.257578] Creating 2 MTD partitions on "spi0.0":
Feb 18 19:58:49 turris kernel: [ 4.262386] 0x000000000000-0x000000100000 : "U-Boot"
Feb 18 19:58:49 turris kernel: [ 4.267670] 0x000000100000-0x000000800000 : "Rescue system"
Feb 18 19:58:49 turris kernel: [ 4.273752] libphy: Fixed MDIO Bus: probed
Feb 18 19:58:49 turris kernel: [ 4.278170] libphy: orion_mdio_bus: probed
Feb 18 19:58:49 turris kernel: [ 4.282603] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Feb 18 19:58:49 turris kernel: [ 4.439813] libphy: mv88e6xxx SMI: probed
Feb 18 19:58:49 turris kernel: [ 4.447619] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:01:02:9d
Feb 18 19:58:49 turris kernel: [ 4.456385] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:01:02:9b
Feb 18 19:58:49 turris kernel: [ 4.465111] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:01:02:9c
Feb 18 19:58:49 turris kernel: [ 4.473298] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Feb 18 19:58:49 turris kernel: [ 4.479843] ehci-pci: EHCI PCI platform driver
Feb 18 19:58:49 turris kernel: [ 4.484331] ehci-platform: EHCI generic platform driver
Feb 18 19:58:49 turris kernel: [ 4.489633] ehci-orion: EHCI orion driver
Feb 18 19:58:49 turris kernel: [ 4.493750] orion-ehci f1058000.usb: EHCI Host Controller
Feb 18 19:58:49 turris kernel: [ 4.499171] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
Feb 18 19:58:49 turris kernel: [ 4.506810] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
Feb 18 19:58:49 turris kernel: [ 4.541349] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
Feb 18 19:58:49 turris kernel: [ 4.547580] hub 1-0:1.0: USB hub found
Feb 18 19:58:49 turris kernel: [ 4.551364] hub 1-0:1.0: 1 port detected
Feb 18 19:58:49 turris kernel: [ 4.555647] xhci-hcd f10f0000.usb3: xHCI Host Controller
Feb 18 19:58:49 turris kernel: [ 4.560979] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
Feb 18 19:58:49 turris kernel: [ 4.568553] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Feb 18 19:58:49 turris kernel: [ 4.572596] ata2: SATA link down (SStatus 0 SControl 300)
Feb 18 19:58:49 turris kernel: [ 4.577824] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
Feb 18 19:58:49 turris kernel: [ 4.583242] ata1: SATA link down (SStatus 0 SControl 300)
Feb 18 19:58:49 turris kernel: [ 4.594524] hub 2-0:1.0: USB hub found
Feb 18 19:58:49 turris kernel: [ 4.598296] hub 2-0:1.0: 1 port detected
Feb 18 19:58:49 turris kernel: [ 4.602336] xhci-hcd f10f0000.usb3: xHCI Host Controller
Feb 18 19:58:49 turris kernel: [ 4.607664] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
Feb 18 19:58:49 turris kernel: [ 4.615178] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
Feb 18 19:58:49 turris kernel: [ 4.621667] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
Feb 18 19:58:49 turris kernel: [ 4.629977] hub 3-0:1.0: USB hub found
Feb 18 19:58:49 turris kernel: [ 4.633756] hub 3-0:1.0: 1 port detected
Feb 18 19:58:49 turris kernel: [ 4.637844] xhci-hcd f10f8000.usb3: xHCI Host Controller
Feb 18 19:58:49 turris kernel: [ 4.643183] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
Feb 18 19:58:49 turris kernel: [ 4.650733] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Feb 18 19:58:49 turris kernel: [ 4.659996] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
Feb 18 19:58:49 turris kernel: [ 4.665996] hub 4-0:1.0: USB hub found
Feb 18 19:58:49 turris kernel: [ 4.669767] hub 4-0:1.0: 1 port detected
Feb 18 19:58:49 turris kernel: [ 4.673803] xhci-hcd f10f8000.usb3: xHCI Host Controller
Feb 18 19:58:49 turris kernel: [ 4.679131] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
Feb 18 19:58:49 turris kernel: [ 4.686645] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
Feb 18 19:58:49 turris kernel: [ 4.693130] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
Feb 18 19:58:49 turris kernel: [ 4.701437] hub 5-0:1.0: USB hub found
Feb 18 19:58:49 turris kernel: [ 4.705207] hub 5-0:1.0: 1 port detected
Feb 18 19:58:49 turris kernel: [ 4.709339] usbcore: registered new interface driver usb-storage
Feb 18 19:58:49 turris kernel: [ 4.715800] armada38x-rtc f10a3800.rtc: registered as rtc0
Feb 18 19:58:49 turris kernel: [ 4.721441] i2c /dev entries driver
Feb 18 19:58:49 turris kernel: [ 4.725689] i2c i2c-0: Added multiplexed i2c bus 1
Feb 18 19:58:49 turris kernel: [ 4.730561] i2c i2c-0: Added multiplexed i2c bus 2
Feb 18 19:58:49 turris kernel: [ 4.735446] i2c i2c-0: Added multiplexed i2c bus 3
Feb 18 19:58:49 turris kernel: [ 4.740309] i2c i2c-0: Added multiplexed i2c bus 4
Feb 18 19:58:49 turris kernel: [ 4.745213] i2c i2c-0: Added multiplexed i2c bus 5
Feb 18 19:58:49 turris kernel: [ 4.750079] i2c i2c-0: Added multiplexed i2c bus 6
Feb 18 19:58:49 turris kernel: [ 4.754961] i2c i2c-0: Added multiplexed i2c bus 7
Feb 18 19:58:49 turris kernel: [ 4.759942] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
Feb 18 19:58:49 turris kernel: [ 4.772504] i2c i2c-0: Added multiplexed i2c bus 8
Feb 18 19:58:49 turris kernel: [ 4.777308] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
Feb 18 19:58:49 turris kernel: [ 4.794890] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Feb 18 19:58:49 turris kernel: [ 4.807361] orion_wdt: Initial timeout 171 sec, nowayout
Feb 18 19:58:49 turris kernel: [ 4.812926] sdhci: Secure Digital Host Controller Interface driver
Feb 18 19:58:49 turris kernel: [ 4.819119] sdhci: Copyright(c) Pierre Ossman
Feb 18 19:58:49 turris kernel: [ 4.881343] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
Feb 18 19:58:49 turris kernel: [ 4.888840] sdhci-pltfm: SDHCI platform and OF driver helper
Feb 18 19:58:49 turris kernel: [ 4.909656] marvell-cesa f1090000.crypto: CESA device successfully registered
Feb 18 19:58:49 turris kernel: [ 4.917270] NET: Registered protocol family 10
Feb 18 19:58:49 turris kernel: [ 4.922284] Segment Routing with IPv6
Feb 18 19:58:49 turris kernel: [ 4.925983] NET: Registered protocol family 17
Feb 18 19:58:49 turris kernel: [ 4.930450] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Feb 18 19:58:49 turris kernel: [ 4.943600] 8021q: 802.1Q VLAN Support v1.8
Feb 18 19:58:49 turris kernel: [ 4.947817] Key type dns_resolver registered
Feb 18 19:58:49 turris kernel: [ 4.952185] Registering SWP/SWPB emulation handler
Feb 18 19:58:49 turris kernel: [ 4.957572] registered taskstats version 1
Feb 18 19:58:49 turris kernel: [ 4.962451] Btrfs loaded, crc32c=crc32c-generic
Feb 18 19:58:49 turris kernel: [ 4.967676] libphy: SFP I2C Bus: probed
Feb 18 19:58:49 turris kernel: [ 4.971861] mmc0: new high speed MMC card at address 0001
Feb 18 19:58:49 turris kernel: [ 4.977479] mmcblk0: mmc0:0001 008G30 7.28 GiB
Feb 18 19:58:49 turris kernel: [ 4.982114] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
Feb 18 19:58:49 turris kernel: [ 4.988105] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
Feb 18 19:58:49 turris kernel: [ 4.994190] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB
Feb 18 19:58:49 turris kernel: [ 5.000655] random: fast init done
Feb 18 19:58:49 turris kernel: [ 5.004121] mmcblk0: p1
Feb 18 19:58:49 turris kernel: [ 5.012082] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Feb 18 19:58:49 turris kernel: [ 5.171288] libphy: mv88e6xxx SMI: probed
Feb 18 19:58:49 turris kernel: [ 5.175367] DSA: switch 0 0 parsed
Feb 18 19:58:49 turris kernel: [ 5.178780] DSA: tree 0 parsed
Feb 18 19:58:49 turris kernel: [ 5.332640] sfp sfp: module FLEXOPTIX S.B1312.10.XDL rev A sn F78VGUA dc 12-02-19
Feb 18 19:58:49 turris kernel: [ 5.341977] sfp sfp: LC connector, encoding 8b10b, nominal bitrate 1.3Gbps +0% -0%
Feb 18 19:58:49 turris kernel: [ 5.349739] sfp sfp: 1000BaseSX- 1000BaseLX- 1000BaseCX- 1000BaseT- 100BaseTLX- 1000BaseFX- BaseBX10+ BasePX-
Feb 18 19:58:49 turris kernel: [ 5.359853] sfp sfp: 10GBaseSR- 10GBaseLR- 10GBaseLRM- 10GBaseER-
Feb 18 19:58:49 turris kernel: [ 5.366136] sfp sfp: Wavelength 1310nm, fiber lengths:
Feb 18 19:58:49 turris kernel: [ 5.371462] sfp sfp: 9µm SM : 10000m
Feb 18 19:58:49 turris kernel: [ 5.375739] sfp sfp: 62.5µm MM OM1: unsupported/unspecified
Feb 18 19:58:49 turris kernel: [ 5.381500] sfp sfp: 50µm MM OM2: unsupported/unspecified
Feb 18 19:58:49 turris kernel: [ 5.387257] sfp sfp: 50µm MM OM3: unsupported/unspecified
Feb 18 19:58:49 turris kernel: [ 5.393017] sfp sfp: 50µm MM OM4: unsupported/unspecified
Feb 18 19:58:49 turris kernel: [ 5.398777] sfp sfp: Options: txdisable, txfault, los+
Feb 18 19:58:49 turris kernel: [ 5.404103] sfp sfp: Diagnostics: ddm, intcal, rxpwravg
Feb 18 19:58:49 turris kernel: [ 5.409518] mvneta f1034000.ethernet eth2: switched to 802.3z/1000base-x link mode
Feb 18 19:58:49 turris kernel: [ 5.985431] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
Feb 18 19:58:49 turris kernel: [ 6.115431] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540]
Feb 18 19:58:49 turris kernel: [ 6.245431] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540]
Feb 18 19:58:49 turris kernel: [ 6.375431] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540]
Feb 18 19:58:49 turris kernel: [ 6.505430] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540]
Feb 18 19:58:49 turris kernel: [ 6.525230] armada38x-rtc f10a3800.rtc: setting system clock to 2020-02-18 18:58:29 UTC (1582052309)
Feb 18 19:58:49 turris kernel: [ 6.537843] BTRFS: device fsid 9614f959-c6d3-4443-a3c3-8fd35213f71b devid 1 transid 108 /dev/root
Feb 18 19:58:49 turris kernel: [ 6.548114] BTRFS info (device mmcblk0p1): disk space caching is enabled
Feb 18 19:58:49 turris kernel: [ 6.554841] BTRFS info (device mmcblk0p1): has skinny extents
Feb 18 19:58:49 turris kernel: [ 6.569245] BTRFS info (device mmcblk0p1): enabling ssd optimizations
Feb 18 19:58:49 turris kernel: [ 6.580085] VFS: Mounted root (btrfs filesystem) on device 0:13.
Feb 18 19:58:49 turris kernel: [ 6.587598] devtmpfs: mounted
Feb 18 19:58:49 turris kernel: [ 6.591136] Freeing unused kernel memory: 1024K
Feb 18 19:58:49 turris kernel: 6.661428] init: Console is alive
Feb 18 19:58:49 turris kernel: 6.664901] init: - watchdog -
Feb 18 19:58:49 turris kernel: 6.803704] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Feb 18 19:58:49 turris kernel: [ 6.815372] ledtrig_transient: no symbol version for module_layout
Feb 18 19:58:49 turris kernel: 6.821950] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Feb 18 19:58:49 turris kernel: 6.831761] init: - preinit -
Feb 18 19:58:49 turris kernel: [ 6.904901] random: jshn: uninitialized urandom read (4 bytes read)
Feb 18 19:58:49 turris kernel: [ 6.921142] random: jshn: uninitialized urandom read (4 bytes read)
Feb 18 19:58:49 turris kernel: [ 6.952731] random: jshn: uninitialized urandom read (4 bytes read)
Feb 18 19:58:49 turris kernel: 10.051832] mount_root: mounting /dev/root
Feb 18 19:58:49 turris kernel: [ 10.081964] BTRFS info (device mmcblk0p1): disk space caching is enabled
Feb 18 19:58:49 turris kernel: 10.277953] urandom-seed: Seeding with /etc/urandom.seed
Feb 18 19:58:49 turris kernel: 10.298288] procd: - early -
Feb 18 19:58:49 turris kernel: 10.301200] procd: - watchdog -
Feb 18 19:58:49 turris kernel: 10.901385] procd: - watchdog -
Feb 18 19:58:49 turris kernel: 10.904627] procd: - ubus -
Feb 18 19:58:49 turris kernel: [ 10.914725] urandom_read: 2 callbacks suppressed
Feb 18 19:58:49 turris kernel: [ 10.914727] random: ubusd: uninitialized urandom read (4 bytes read)
Feb 18 19:58:49 turris kernel: [ 10.956922] random: ubusd: uninitialized urandom read (4 bytes read)
Feb 18 19:58:49 turris kernel: [ 10.963409] random: ubusd: uninitialized urandom read (4 bytes read)
Feb 18 19:58:49 turris kernel: 10.970094] procd: - init -
Feb 18 19:58:49 turris kernel: 11.014021] kmodloader: loading kernel modules from /etc/modules.d/*
Feb 18 19:58:49 turris kernel: [ 11.024096] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Feb 18 19:58:49 turris kernel: [ 11.032961] ip6_tables: (C) 2000-2006 Netfilter Core Team
Feb 18 19:58:49 turris kernel: [ 11.041287] Netfilter messages via NETLINK v0.30.
Feb 18 19:58:49 turris kernel: [ 11.046902] ip_set: protocol 6
Feb 18 19:58:49 turris kernel: [ 11.063933] u32 classifier
Feb 18 19:58:49 turris kernel: [ 11.066653] input device check on
Feb 18 19:58:49 turris kernel: [ 11.070324] Actions configured
Feb 18 19:58:49 turris kernel: [ 11.074567] Mirror/redirect action on
Feb 18 19:58:49 turris kernel: [ 11.079027] sch_cake: loading out-of-tree module taints kernel.
Feb 18 19:58:49 turris kernel: [ 11.085153] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
Feb 18 19:58:49 turris kernel: [ 11.091538] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
Feb 18 19:58:49 turris kernel: [ 11.143458] Bridge firewalling registered
Feb 18 19:58:49 turris kernel: [ 11.147759] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180
Feb 18 19:58:49 turris kernel: [ 11.155800] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
Feb 18 19:58:49 turris kernel: [ 11.166165] Ebtables v2.0 registered
Feb 18 19:58:49 turris kernel: [ 11.170740] ip_tables: (C) 2000-2006 Netfilter Core Team
Feb 18 19:58:49 turris kernel: [ 11.180182] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Feb 18 19:58:49 turris kernel: [ 11.187956] ctnetlink v0.93: registering with nfnetlink.
Feb 18 19:58:49 turris kernel: [ 11.210049] usbcore: registered new interface driver usbserial
Feb 18 19:58:49 turris kernel: [ 11.215998] usbcore: registered new interface driver usbserial_generic
Feb 18 19:58:49 turris kernel: [ 11.222607] usbserial: USB Serial support registered for generic
Feb 18 19:58:49 turris kernel: [ 11.240038] xt_time: kernel timezone is -0000
Feb 18 19:58:49 turris kernel: [ 11.246041] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
Feb 18 19:58:49 turris kernel: [ 11.273425] PPP generic driver version 2.4.2
Feb 18 19:58:49 turris kernel: [ 11.278463] NET: Registered protocol family 24
Feb 18 19:58:49 turris kernel: [ 11.291296] pci 0000:00:02.0: enabling device (0140 -> 0142)
Feb 18 19:58:49 turris kernel: [ 11.297035] ath10k_pci 0000:02:00.0: enabling device (0140 -> 0142)
Feb 18 19:58:49 turris kernel: [ 11.303605] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Feb 18 19:58:49 turris kernel: [ 11.544099] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
Feb 18 19:58:49 turris kernel: [ 11.554854] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:58:49 turris kernel: [ 11.862055] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
Feb 18 19:58:49 turris kernel: [ 11.871150] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
Feb 18 19:58:49 turris kernel: [ 11.881537] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:58:49 turris kernel: [ 11.891714] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
Feb 18 19:58:49 turris kernel: [ 11.900528] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
Feb 18 19:58:49 turris kernel: [ 11.911263] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:58:49 turris kernel: [ 11.921462] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
Feb 18 19:58:49 turris kernel: [ 11.938695] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Feb 18 19:58:49 turris kernel: [ 11.947954] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
Feb 18 19:58:49 turris kernel: [ 11.957476] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00037 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 a4a52adb
Feb 18 19:58:49 turris kernel: [ 12.002247] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
Feb 18 19:58:49 turris kernel: [ 12.012714] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:58:49 turris kernel: [ 12.023243] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
Feb 18 19:58:49 turris kernel: [ 12.033258] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Feb 18 19:58:49 turris kernel: [ 13.169185] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Feb 18 19:58:49 turris kernel: [ 13.301821] ath: EEPROM regdomain: 0x0
Feb 18 19:58:49 turris kernel: [ 13.301823] ath: EEPROM indicates default country code should be used
Feb 18 19:58:49 turris kernel: [ 13.301825] ath: doing EEPROM country->regdmn map search
Feb 18 19:58:49 turris kernel: [ 13.301828] ath: country maps to regdmn code: 0x3a
Feb 18 19:58:49 turris kernel: [ 13.301830] ath: Country alpha2 being used: US
Feb 18 19:58:49 turris kernel: [ 13.301832] ath: Regpair used: 0x3a
Feb 18 19:58:49 turris kernel: [ 13.310251] usbcore: registered new interface driver qcserial
Feb 18 19:58:49 turris kernel: [ 13.316092] usbserial: USB Serial support registered for Qualcomm USB modem
Feb 18 19:58:49 turris kernel: [ 13.328083] pci 0000:00:01.0: enabling device (0140 -> 0142)
Feb 18 19:58:49 turris kernel: [ 13.333805] ath9k 0000:01:00.0: enabling device (0140 -> 0142)
Feb 18 19:58:49 turris kernel: [ 13.427286] ath: EEPROM regdomain: 0x0
Feb 18 19:58:49 turris kernel: [ 13.427292] ath: EEPROM indicates default country code should be used
Feb 18 19:58:49 turris kernel: [ 13.427294] ath: doing EEPROM country->regdmn map search
Feb 18 19:58:49 turris kernel: [ 13.427298] ath: country maps to regdmn code: 0x3a
Feb 18 19:58:49 turris kernel: [ 13.427303] ath: Country alpha2 being used: US
Feb 18 19:58:49 turris kernel: [ 13.427308] ath: Regpair used: 0x3a
Feb 18 19:58:49 turris kernel: [ 13.439173] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Feb 18 19:58:49 turris kernel: [ 13.440470] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf1010000, irq=82
Feb 18 19:58:49 turris kernel: 13.447580] kmodloader: done loading kernel modules from /etc/modules.d/*
Feb 18 19:58:49 turris kernel: [ 13.891214] random: crng init done
Feb 18 19:58:49 turris kernel: [ 13.894674] random: 2 urandom warning(s) missed due to ratelimiting
Feb 18 19:58:49 turris kernel: [ 17.261039] watchdog: watchdog0: nowayout prevents watchdog being stopped!
Feb 18 19:58:49 turris kernel: [ 17.267953] watchdog: watchdog0: watchdog did not stop!
Feb 18 19:58:49 turris kernel: [ 17.275439] watchdog: watchdog0: nowayout prevents watchdog being stopped!
Feb 18 19:58:49 turris kernel: [ 17.282348] watchdog: watchdog0: watchdog did not stop!
Feb 18 19:58:49 turris kernel: [ 17.488271] BTRFS warning (device mmcblk0p1): csum failed root 257 ino 5432 off 16384 csum 0x1a24d8b5 expected csum 0x88402eaa mirror 1
Feb 18 19:58:49 turris kernel: [ 18.683166] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Feb 18 19:58:49 turris kernel: [ 18.693491] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
Feb 18 19:58:49 turris kernel: [ 18.701499] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Feb 18 19:58:49 turris kernel: [ 18.707399] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Feb 18 19:58:49 turris kernel: [ 18.715471] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
Feb 18 19:58:49 turris kernel: [ 18.723285] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Feb 18 19:58:49 turris kernel: [ 18.729806] br-lan: port 1(lan0) entered blocking state
Feb 18 19:58:49 turris kernel: [ 18.735079] br-lan: port 1(lan0) entered disabled state
Feb 18 19:58:49 turris kernel: [ 18.746731] device lan0 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 18.751417] device eth1 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 18.808728] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
Feb 18 19:58:49 turris kernel: [ 18.828895] br-lan: port 2(lan1) entered blocking state
Feb 18 19:58:49 turris kernel: [ 18.834190] br-lan: port 2(lan1) entered disabled state
Feb 18 19:58:49 turris kernel: [ 18.850013] device lan1 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 18.912526] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
Feb 18 19:58:49 turris kernel: [ 18.921500] br-lan: port 3(lan2) entered blocking state
Feb 18 19:58:49 turris kernel: [ 18.926745] br-lan: port 3(lan2) entered disabled state
Feb 18 19:58:49 turris kernel: [ 18.937632] device lan2 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 18.982185] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
Feb 18 19:58:49 turris kernel: [ 19.006422] br-lan: port 4(lan3) entered blocking state
Feb 18 19:58:49 turris kernel: [ 19.011743] br-lan: port 4(lan3) entered disabled state
Feb 18 19:58:49 turris kernel: [ 19.022707] device lan3 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 19.080407] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
Feb 18 19:58:49 turris kernel: [ 19.088289] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 18 19:58:49 turris kernel: [ 19.094187] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Feb 18 19:58:49 turris kernel: [ 19.105756] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
Feb 18 19:58:49 turris kernel: [ 19.113557] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Feb 18 19:58:49 turris kernel: [ 19.120576] br-lan: port 5(lan4) entered blocking state
Feb 18 19:58:49 turris kernel: [ 19.125828] br-lan: port 5(lan4) entered disabled state
Feb 18 19:58:49 turris kernel: [ 19.141706] device lan4 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 19.146334] device eth0 entered promiscuous mode
Feb 18 19:58:49 turris kernel: [ 19.199227] mvneta f1034000.ethernet eth2: configuring for 802.3z/1000base-x link mode
Feb 18 19:58:49 turris kernel: [ 19.208462] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
Feb 18 19:58:49 turris kernel: [ 19.418680] ath: EEPROM regdomain: 0x82f4
Feb 18 19:58:49 turris kernel: [ 19.418683] ath: EEPROM indicates we should expect a country code
Feb 18 19:58:49 turris kernel: [ 19.418685] ath: doing EEPROM country->regdmn map search
Feb 18 19:58:49 turris kernel: [ 19.418688] ath: country maps to regdmn code: 0x37
Feb 18 19:58:49 turris kernel: [ 19.418690] ath: Country alpha2 being used: CH
Feb 18 19:58:49 turris kernel: [ 19.418691] ath: Regpair used: 0x37
Feb 18 19:58:49 turris kernel: [ 19.418693] ath: regdomain 0x82f4 dynamically updated by user
Feb 18 19:58:49 turris kernel: [ 19.418743] ath: EEPROM regdomain: 0x82f4
Feb 18 19:58:49 turris kernel: [ 19.418744] ath: EEPROM indicates we should expect a country code
Feb 18 19:58:49 turris kernel: [ 19.418747] ath: doing EEPROM country->regdmn map search
Feb 18 19:58:49 turris kernel: [ 19.418749] ath: country maps to regdmn code: 0x37
Feb 18 19:58:49 turris kernel: [ 19.418750] ath: Country alpha2 being used: CH
Feb 18 19:58:49 turris kernel: [ 19.418751] ath: Regpair used: 0x37
Feb 18 19:58:49 turris kernel: [ 19.418753] ath: regdomain 0x82f4 dynamically updated by user
Feb 18 19:58:49 turris kernel: [ 19.511401] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
Feb 18 19:58:49 turris kernel: [ 19.519797] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Feb 18 19:58:49 turris kernel: [ 22.009073] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
Feb 18 19:58:49 turris kernel: [ 22.017670] br-lan: port 1(lan0) entered blocking state
Feb 18 19:58:49 turris kernel: [ 22.022915] br-lan: port 1(lan0) entered forwarding state
Feb 18 19:58:49 turris kernel: [ 22.032995] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Feb 18 18:58:49 turris firewall: Reloading firewall due to ifup of wan6 (eth2)
Feb 18 18:58:49 turris odhcpd[2880]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
Feb 18 18:58:54 turris procd: /etc/rc.d/S80umdns: Command failed: Request timed out
Feb 18 18:58:54 turris procd: /etc/rc.d/S96led: setting up led wan
Feb 18 18:58:54 turris procd: /etc/rc.d/S96led: setting up led pci1
Feb 18 18:58:54 turris procd: /etc/rc.d/S96led: setting up led pci2
Feb 18 18:58:54 turris procd: /etc/rc.d/S96led: setting up led pci3
Feb 18 18:58:54 turris turris: Router Turris successfully started.
Feb 18 18:58:55 turris procd: /etc/rc.d/S99start-indicator: setting up led wan
Feb 18 18:58:55 turris procd: /etc/rc.d/S99start-indicator: setting up led pci1
Feb 18 18:58:55 turris procd: /etc/rc.d/S99start-indicator: setting up led pci2
Feb 18 18:58:55 turris procd: /etc/rc.d/S99start-indicator: setting up led pci3
Feb 18 18:58:55 turris procd: - init complete -
Feb 18 19:58:40 turris dnsmasq[2783]: started, version 2.80 DNS disabled
Feb 18 19:58:57 turris dnsmasq[2783]: overflow: 2 log entries lost
Feb 18 19:58:57 turris dnsmasq[4524]: started, version 2.80 DNS disabled
Feb 18 19:58:57 turris dnsmasq[4524]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Feb 18 19:58:57 turris dnsmasq-dhcp[4524]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Feb 18 19:58:57 turris dnsmasq-dhcp[4524]: read /etc/ethers - 0 addresses
Feb 18 18:58:59 turris kresd[4157]: [ ta ] key: 20326 state: Valid
Feb 18 18:58:59 turris kresd[4157]: [ ta ] next refresh for . in 22.642083333333 hours
Feb 18 18:59:01 turris /usr/sbin/cron[4544]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 18 19:59:06 turris dnsmasq-dhcp[4524]: DHCPDISCOVER(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e
Feb 18 19:59:06 turris dnsmasq-dhcp[4524]: DHCPOFFER(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e
Feb 18 19:59:06 turris dnsmasq-dhcp[4524]: DHCPREQUEST(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e
Feb 18 19:59:06 turris dnsmasq-dhcp[4524]: DHCPACK(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e Jyn
Feb 18 18:59:06 turris 99-dhcp_host_domain_ng.py: DHCP add new hostname [Jyn,192.168.1.133]
Feb 18 18:59:06 turris 99-dhcp_host_domain_ng.py: Refresh kresd leases
Feb 18 18:59:06 turris kresd[4157]: hints.add_hosts('/tmp/kresd/hints.tmp')
Feb 18 18:59:06 turris kresd[4157]: [result] => true
Feb 18 18:59:08 turris procd: Instance foris-controller::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Feb 18 18:59:09 turris procd: Instance umdns::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Feb 18 18:59:09 turris procd: Instance foris-ws::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Feb 18 19:00:01 turris /usr/sbin/cron[4626]: (root) CMD (/usr/bin/notifier)
Feb 18 19:00:01 turris /usr/sbin/cron[4630]: (root) CMD (/usr/bin/updater-supervisor -d --rand-sleep)
Feb 18 19:00:01 turris /usr/sbin/cron[4628]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 18 19:00:01 turris /usr/sbin/cron[4631]: (root) CMD (/usr/bin/get-api-crl)
Feb 18 19:01:01 turris /usr/sbin/cron[4754]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
try to go into the wifi page? Another error.
Then I tried to reboot again, to get some logs for the wifi part above,
but still, 500, this time on the main index, 192.168.1.1/
Let’s try again? Nope.
Factory reset (without reflash)
Feb 18 19:34:23 turris syslog-ng[2960]: syslog-ng starting up; version='3.21.1'
Feb 18 19:34:23 turris kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Feb 18 19:34:23 turris kernel: [ 0.000000] Linux version 4.14.162 (beast@slave10) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 ab9d1bf)) #0 SMP Thu Jan 16 14:01:27 2020
Feb 18 19:34:23 turris kernel: [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Feb 18 19:34:23 turris kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Feb 18 19:34:23 turris kernel: [ 0.000000] OF: fdt: Machine model: Turris Omnia
Feb 18 19:34:23 turris kernel: [ 0.000000] Memory policy: Data cache writealloc
Feb 18 19:34:23 turris kernel: [ 0.000000] On node 0 totalpages: 524288
Feb 18 19:34:23 turris kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0b3a1c0, node_mem_map eedf9000
Feb 18 19:34:23 turris kernel: [ 0.000000] Normal zone: 1728 pages used for memmap
Feb 18 19:34:23 turris kernel: [ 0.000000] Normal zone: 0 pages reserved
Feb 18 19:34:23 turris kernel: [ 0.000000] Normal zone: 196608 pages, LIFO batch:31
Feb 18 19:34:23 turris kernel: [ 0.000000] HighMem zone: 327680 pages, LIFO batch:31
Feb 18 19:34:23 turris kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x78/0x4a8 with crng_init=0
Feb 18 19:34:23 turris kernel: [ 0.000000] percpu: Embedded 11 pages/cpu s14476 r8192 d22388 u45056
Feb 18 19:34:23 turris kernel: [ 0.000000] pcpu-alloc: s14476 r8192 d22388 u45056 alloc=11*4096
Feb 18 19:34:23 turris kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Feb 18 19:34:23 turris kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
Feb 18 19:34:23 turris kernel: [ 0.000000] Kernel command line: earlyprintk rootwait console=ttyS0,115200 rootfstype=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rw cfg80211.freg=**
Feb 18 19:34:23 turris kernel: [ 0.000000] Bootloader command line not present
Feb 18 19:34:23 turris kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb 18 19:34:23 turris kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 18 19:34:23 turris kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 18 19:34:23 turris kernel: [ 0.000000] Memory: 2066956K/2097152K available (7168K kernel code, 234K rwdata, 1772K rodata, 1024K init, 269K bss, 30196K reserved, 0K cma-reserved, 1310720K highmem)
Feb 18 19:34:23 turris kernel: [ 0.000000] Virtual kernel memory layout:
Feb 18 19:34:23 turris kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Feb 18 19:34:23 turris kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Feb 18 19:34:23 turris kernel: [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
Feb 18 19:34:23 turris kernel: [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
Feb 18 19:34:23 turris kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
Feb 18 19:34:23 turris kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
Feb 18 19:34:23 turris kernel: [ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
Feb 18 19:34:23 turris kernel: [ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
Feb 18 19:34:23 turris kernel: [ 0.000000] .data : 0xc0b00000 - 0xc0b3aac0 ( 235 kB)
Feb 18 19:34:23 turris kernel: [ 0.000000] .bss : 0xc0b3aac0 - 0xc0b7e0b0 ( 270 kB)
Feb 18 19:34:23 turris kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Feb 18 19:34:23 turris kernel: [ 0.000000] Hierarchical RCU implementation.
Feb 18 19:34:23 turris kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Feb 18 19:34:23 turris kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Feb 18 19:34:23 turris kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Feb 18 19:34:23 turris kernel: [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
Feb 18 19:34:23 turris kernel: [ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
Feb 18 19:34:23 turris kernel: [ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
Feb 18 19:34:23 turris kernel: [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
Feb 18 19:34:23 turris kernel: [ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
Feb 18 19:34:23 turris kernel: [ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
Feb 18 19:34:23 turris kernel: [ 0.000007] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
Feb 18 19:34:23 turris kernel: [ 0.000018] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
Feb 18 19:34:23 turris kernel: [ 0.000032] Switching to timer-based delay loop, resolution 1ns
Feb 18 19:34:23 turris kernel: [ 0.000162] Ignoring duplicate/late registration of read_current_timer delay
Feb 18 19:34:23 turris kernel: [ 0.000169] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Feb 18 19:34:23 turris kernel: [ 0.000322] Console: colour dummy device 80x30
Feb 18 19:34:23 turris kernel: [ 0.000340] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
Feb 18 19:34:23 turris kernel: [ 0.000347] pid_max: default: 32768 minimum: 301
Feb 18 19:34:23 turris kernel: [ 0.000413] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 18 19:34:23 turris kernel: [ 0.000419] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 18 19:34:23 turris kernel: [ 0.000721] CPU: Testing write buffer coherency: ok
Feb 18 19:34:23 turris kernel: [ 0.000734] CPU0: Spectre v2: using BPIALL workaround
Feb 18 19:34:23 turris kernel: [ 0.000854] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Feb 18 19:34:23 turris kernel: [ 0.000978] Setting up static identity map for 0x100000 - 0x100060
Feb 18 19:34:23 turris kernel: [ 0.001054] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
Feb 18 19:34:23 turris kernel: [ 0.001133] mvebu-pmsu: Initializing Power Management Service Unit
Feb 18 19:34:23 turris kernel: [ 0.001182] Hierarchical SRCU implementation.
Feb 18 19:34:23 turris kernel: [ 0.001378] smp: Bringing up secondary CPUs ...
Feb 18 19:34:23 turris kernel: [ 0.001509] Booting CPU 1
Feb 18 19:34:23 turris kernel: [ 0.001689] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Feb 18 19:34:23 turris kernel: [ 0.001691] CPU1: Spectre v2: using BPIALL workaround
Feb 18 19:34:23 turris kernel: [ 0.001746] smp: Brought up 1 node, 2 CPUs
Feb 18 19:34:23 turris kernel: [ 0.001751] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
Feb 18 19:34:23 turris kernel: [ 0.001754] CPU: All CPU(s) started in SVC mode.
Feb 18 19:34:23 turris kernel: [ 0.002285] devtmpfs: initialized
Feb 18 19:34:23 turris kernel: [ 0.003927] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Feb 18 19:34:23 turris kernel: [ 0.003981] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 18 19:34:23 turris kernel: [ 0.003990] futex hash table entries: 512 (order: 3, 32768 bytes)
Feb 18 19:34:23 turris kernel: [ 0.004063] xor: measuring software checksum speed
Feb 18 19:34:23 turris kernel: [ 0.100067] arm4regs : 2392.800 MB/sec
Feb 18 19:34:23 turris kernel: [ 0.200067] 8regs : 1936.000 MB/sec
Feb 18 19:34:23 turris kernel: [ 0.300065] 32regs : 2050.800 MB/sec
Feb 18 19:34:23 turris kernel: [ 0.400066] neon : 1837.200 MB/sec
Feb 18 19:34:23 turris kernel: [ 0.400070] xor: using function: arm4regs (2392.800 MB/sec)
Feb 18 19:34:23 turris kernel: [ 0.400076] pinctrl core: initialized pinctrl subsystem
Feb 18 19:34:23 turris kernel: [ 0.400434] NET: Registered protocol family 16
Feb 18 19:34:23 turris kernel: [ 0.400969] DMA: preallocated 256 KiB pool for atomic coherent allocations
Feb 18 19:34:23 turris kernel: [ 0.401519] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
Feb 18 19:34:23 turris kernel: [ 0.401527] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
Feb 18 19:34:23 turris kernel: [ 0.570141] raid6: int32x1 gen() 171 MB/s
Feb 18 19:34:23 turris kernel: [ 0.740136] raid6: int32x1 xor() 243 MB/s
Feb 18 19:34:23 turris kernel: [ 0.910142] raid6: int32x2 gen() 255 MB/s
Feb 18 19:34:23 turris kernel: [ 1.080068] raid6: int32x2 xor() 287 MB/s
Feb 18 19:34:23 turris kernel: [ 1.250253] raid6: int32x4 gen() 305 MB/s
Feb 18 19:34:23 turris kernel: [ 1.420148] raid6: int32x4 xor() 252 MB/s
Feb 18 19:34:23 turris kernel: [ 1.590089] raid6: int32x8 gen() 330 MB/s
Feb 18 19:34:23 turris kernel: [ 1.760070] raid6: int32x8 xor() 229 MB/s
Feb 18 19:34:23 turris kernel: [ 1.930101] raid6: neonx1 gen() 1111 MB/s
Feb 18 19:34:23 turris kernel: [ 2.100071] raid6: neonx1 xor() 1058 MB/s
Feb 18 19:34:23 turris kernel: [ 2.270095] raid6: neonx2 gen() 1303 MB/s
Feb 18 19:34:23 turris kernel: [ 2.440088] raid6: neonx2 xor() 1350 MB/s
Feb 18 19:34:23 turris kernel: [ 2.610088] raid6: neonx4 gen() 1071 MB/s
Feb 18 19:34:23 turris kernel: [ 2.780084] raid6: neonx4 xor() 1307 MB/s
Feb 18 19:34:23 turris kernel: [ 2.950105] raid6: neonx8 gen() 1014 MB/s
Feb 18 19:34:23 turris kernel: [ 3.120067] raid6: neonx8 xor() 947 MB/s
Feb 18 19:34:23 turris kernel: [ 3.120071] raid6: using algorithm neonx2 gen() 1303 MB/s
Feb 18 19:34:23 turris kernel: [ 3.120074] raid6: .... xor() 1350 MB/s, rmw enabled
Feb 18 19:34:23 turris kernel: [ 3.120077] raid6: using neon recovery algorithm
Feb 18 19:34:23 turris kernel: [ 3.120360] SCSI subsystem initialized
Feb 18 19:34:23 turris kernel: [ 3.120488] libata version 3.00 loaded.
Feb 18 19:34:23 turris kernel: [ 3.120594] usbcore: registered new interface driver usbfs
Feb 18 19:34:23 turris kernel: [ 3.120621] usbcore: registered new interface driver hub
Feb 18 19:34:23 turris kernel: [ 3.120648] usbcore: registered new device driver usb
Feb 18 19:34:23 turris kernel: [ 3.121307] clocksource: Switched to clocksource arm_global_timer
Feb 18 19:34:23 turris kernel: [ 3.125029] NET: Registered protocol family 2
Feb 18 19:34:23 turris kernel: [ 3.125303] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Feb 18 19:34:23 turris kernel: [ 3.125342] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Feb 18 19:34:23 turris kernel: [ 3.125403] TCP: Hash tables configured (established 8192 bind 8192)
Feb 18 19:34:23 turris kernel: [ 3.125452] UDP hash table entries: 512 (order: 2, 16384 bytes)
Feb 18 19:34:23 turris kernel: [ 3.125479] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Feb 18 19:34:23 turris kernel: [ 3.125566] NET: Registered protocol family 1
Feb 18 19:34:23 turris kernel: [ 3.125730] RPC: Registered named UNIX socket transport module.
Feb 18 19:34:23 turris kernel: [ 3.125734] RPC: Registered udp transport module.
Feb 18 19:34:23 turris kernel: [ 3.125738] RPC: Registered tcp transport module.
Feb 18 19:34:23 turris kernel: [ 3.125740] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 18 19:34:23 turris kernel: [ 3.125746] PCI: CLS 0 bytes, default 64
Feb 18 19:34:23 turris kernel: [ 3.126545] Crashlog allocated RAM at address 0x3f00000
Feb 18 19:34:23 turris kernel: [ 3.126640] workingset: timestamp_bits=14 max_order=19 bucket_order=5
Feb 18 19:34:23 turris kernel: [ 3.128666] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Feb 18 19:34:23 turris kernel: [ 3.129170] NFS: Registering the id_resolver key type
Feb 18 19:34:23 turris kernel: [ 3.129184] Key type id_resolver registered
Feb 18 19:34:23 turris kernel: [ 3.129187] Key type id_legacy registered
Feb 18 19:34:23 turris kernel: [ 3.129204] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Feb 18 19:34:23 turris kernel: [ 3.130355] bounce: pool size: 64 pages
Feb 18 19:34:23 turris kernel: [ 3.130367] io scheduler noop registered
Feb 18 19:34:23 turris kernel: [ 3.130371] io scheduler deadline registered (default)
Feb 18 19:34:23 turris kernel: [ 3.130827] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
Feb 18 19:34:23 turris kernel: [ 3.133067] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
Feb 18 19:34:23 turris kernel: [ 3.133078] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
Feb 18 19:34:23 turris kernel: [ 3.133083] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
Feb 18 19:34:23 turris kernel: [ 3.133088] pci_bus 0000:00: root bus resource [bus 00-ff]
Feb 18 19:34:23 turris kernel: [ 3.133105] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
Feb 18 19:34:23 turris kernel: [ 3.133194] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
Feb 18 19:34:23 turris kernel: [ 3.133266] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
Feb 18 19:34:23 turris kernel: [ 3.133337] PCI: bus0: Fast back to back transfers disabled
Feb 18 19:34:23 turris kernel: [ 3.133344] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 18 19:34:23 turris kernel: [ 3.133350] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 18 19:34:23 turris kernel: [ 3.133356] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 18 19:34:23 turris kernel: [ 3.133410] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
Feb 18 19:34:23 turris kernel: [ 3.133437] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
Feb 18 19:34:23 turris kernel: [ 3.133522] pci 0000:01:00.0: supports D1
Feb 18 19:34:23 turris kernel: [ 3.133525] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
Feb 18 19:34:23 turris kernel: [ 3.133582] PCI: bus1: Fast back to back transfers disabled
Feb 18 19:34:23 turris kernel: [ 3.133589] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Feb 18 19:34:23 turris kernel: [ 3.133638] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
Feb 18 19:34:23 turris kernel: [ 3.133663] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Feb 18 19:34:23 turris kernel: [ 3.133687] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Feb 18 19:34:23 turris kernel: [ 3.133748] pci 0000:02:00.0: supports D1 D2
Feb 18 19:34:23 turris kernel: [ 3.133802] PCI: bus2: Fast back to back transfers disabled
Feb 18 19:34:23 turris kernel: [ 3.133808] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
Feb 18 19:34:23 turris kernel: [ 3.133840] PCI: bus3: Fast back to back transfers enabled
Feb 18 19:34:23 turris kernel: [ 3.133845] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Feb 18 19:34:23 turris kernel: [ 3.133865] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
Feb 18 19:34:23 turris kernel: [ 3.133871] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
Feb 18 19:34:23 turris kernel: [ 3.133877] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
Feb 18 19:34:23 turris kernel: [ 3.133888] pci 0000:00:01.0: PCI bridge to [bus 01]
Feb 18 19:34:23 turris kernel: [ 3.133894] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe00fffff]
Feb 18 19:34:23 turris kernel: [ 3.133901] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
Feb 18 19:34:23 turris kernel: [ 3.133911] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
Feb 18 19:34:23 turris kernel: [ 3.133916] pci 0000:00:02.0: PCI bridge to [bus 02]
Feb 18 19:34:23 turris kernel: [ 3.133921] pci 0000:00:02.0: bridge window [mem 0xe0200000-0xe04fffff]
Feb 18 19:34:23 turris kernel: [ 3.133926] pci 0000:00:03.0: PCI bridge to [bus 03]
Feb 18 19:34:23 turris kernel: [ 3.134163] mv_xor f1060800.xor: Marvell shared XOR driver
Feb 18 19:34:23 turris kernel: [ 3.191762] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Feb 18 19:34:23 turris kernel: [ 3.191875] mv_xor f1060900.xor: Marvell shared XOR driver
Feb 18 19:34:23 turris kernel: [ 3.251734] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Feb 18 19:34:23 turris kernel: [ 3.251938] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Feb 18 19:34:23 turris kernel: [ 3.253089] console [ttyS0] disabled
Feb 18 19:34:23 turris kernel: [ 3.273158] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
Feb 18 19:34:23 turris kernel: [ 4.160336] console [ttyS0] enabled
Feb 18 19:34:23 turris kernel: [ 4.184095] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
Feb 18 19:34:23 turris kernel: [ 4.194866] loop: module loaded
Feb 18 19:34:23 turris kernel: [ 4.198329] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
Feb 18 19:34:23 turris kernel: [ 4.207420] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
Feb 18 19:34:23 turris kernel: [ 4.216573] scsi host0: ahci-mvebu
Feb 18 19:34:23 turris kernel: [ 4.220126] scsi host1: ahci-mvebu
Feb 18 19:34:23 turris kernel: [ 4.223613] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
Feb 18 19:34:23 turris kernel: [ 4.231561] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
Feb 18 19:34:23 turris kernel: [ 4.240273] m25p80 spi0.0: found mx25l6405d, expected s25fl164k
Feb 18 19:34:23 turris kernel: [ 4.246260] m25p80 spi0.0: mx25l6405d (8192 Kbytes)
Feb 18 19:34:23 turris kernel: [ 4.251217] 2 fixed-partitions partitions found on MTD device spi0.0
Feb 18 19:34:23 turris kernel: [ 4.257602] Creating 2 MTD partitions on "spi0.0":
Feb 18 19:34:23 turris kernel: [ 4.262410] 0x000000000000-0x000000100000 : "U-Boot"
Feb 18 19:34:23 turris kernel: [ 4.267692] 0x000000100000-0x000000800000 : "Rescue system"
Feb 18 19:34:23 turris kernel: [ 4.273772] libphy: Fixed MDIO Bus: probed
Feb 18 19:34:23 turris kernel: [ 4.278195] libphy: orion_mdio_bus: probed
Feb 18 19:34:23 turris kernel: [ 4.282622] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Feb 18 19:34:23 turris kernel: [ 4.441240] libphy: mv88e6xxx SMI: probed
Feb 18 19:34:23 turris kernel: [ 4.449029] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:01:02:9d
Feb 18 19:34:23 turris kernel: [ 4.457790] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:01:02:9b
Feb 18 19:34:23 turris kernel: [ 4.466514] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:01:02:9c
Feb 18 19:34:23 turris kernel: [ 4.474698] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Feb 18 19:34:23 turris kernel: [ 4.481242] ehci-pci: EHCI PCI platform driver
Feb 18 19:34:23 turris kernel: [ 4.485732] ehci-platform: EHCI generic platform driver
Feb 18 19:34:23 turris kernel: [ 4.491035] ehci-orion: EHCI orion driver
Feb 18 19:34:23 turris kernel: [ 4.495152] orion-ehci f1058000.usb: EHCI Host Controller
Feb 18 19:34:23 turris kernel: [ 4.500572] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
Feb 18 19:34:23 turris kernel: [ 4.508210] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
Feb 18 19:34:23 turris kernel: [ 4.541293] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
Feb 18 19:34:23 turris kernel: [ 4.547521] hub 1-0:1.0: USB hub found
Feb 18 19:34:23 turris kernel: [ 4.551303] hub 1-0:1.0: 1 port detected
Feb 18 19:34:23 turris kernel: [ 4.555576] xhci-hcd f10f0000.usb3: xHCI Host Controller
Feb 18 19:34:23 turris kernel: [ 4.560908] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
Feb 18 19:34:23 turris kernel: [ 4.568481] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Feb 18 19:34:23 turris kernel: [ 4.572707] ata1: SATA link down (SStatus 0 SControl 300)
Feb 18 19:34:23 turris kernel: [ 4.577751] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
Feb 18 19:34:23 turris kernel: [ 4.583172] ata2: SATA link down (SStatus 0 SControl 300)
Feb 18 19:34:23 turris kernel: [ 4.594449] hub 2-0:1.0: USB hub found
Feb 18 19:34:23 turris kernel: [ 4.598220] hub 2-0:1.0: 1 port detected
Feb 18 19:34:23 turris kernel: [ 4.602257] xhci-hcd f10f0000.usb3: xHCI Host Controller
Feb 18 19:34:23 turris kernel: [ 4.607585] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
Feb 18 19:34:23 turris kernel: [ 4.615100] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
Feb 18 19:34:23 turris kernel: [ 4.621588] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
Feb 18 19:34:23 turris kernel: [ 4.629892] hub 3-0:1.0: USB hub found
Feb 18 19:34:23 turris kernel: [ 4.633671] hub 3-0:1.0: 1 port detected
Feb 18 19:34:23 turris kernel: [ 4.637764] xhci-hcd f10f8000.usb3: xHCI Host Controller
Feb 18 19:34:23 turris kernel: [ 4.643104] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
Feb 18 19:34:23 turris kernel: [ 4.650654] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Feb 18 19:34:23 turris kernel: [ 4.659918] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
Feb 18 19:34:23 turris kernel: [ 4.665918] hub 4-0:1.0: USB hub found
Feb 18 19:34:23 turris kernel: [ 4.669686] hub 4-0:1.0: 1 port detected
Feb 18 19:34:23 turris kernel: [ 4.673717] xhci-hcd f10f8000.usb3: xHCI Host Controller
Feb 18 19:34:23 turris kernel: [ 4.679045] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
Feb 18 19:34:23 turris kernel: [ 4.686559] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
Feb 18 19:34:23 turris kernel: [ 4.693051] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
Feb 18 19:34:23 turris kernel: [ 4.701362] hub 5-0:1.0: USB hub found
Feb 18 19:34:23 turris kernel: [ 4.705131] hub 5-0:1.0: 1 port detected
Feb 18 19:34:23 turris kernel: [ 4.709261] usbcore: registered new interface driver usb-storage
Feb 18 19:34:23 turris kernel: [ 4.715722] armada38x-rtc f10a3800.rtc: registered as rtc0
Feb 18 19:34:23 turris kernel: [ 4.721365] i2c /dev entries driver
Feb 18 19:34:23 turris kernel: [ 4.725605] i2c i2c-0: Added multiplexed i2c bus 1
Feb 18 19:34:23 turris kernel: [ 4.730477] i2c i2c-0: Added multiplexed i2c bus 2
Feb 18 19:34:23 turris kernel: [ 4.735361] i2c i2c-0: Added multiplexed i2c bus 3
Feb 18 19:34:23 turris kernel: [ 4.740224] i2c i2c-0: Added multiplexed i2c bus 4
Feb 18 19:34:23 turris kernel: [ 4.745119] i2c i2c-0: Added multiplexed i2c bus 5
Feb 18 19:34:23 turris kernel: [ 4.749989] i2c i2c-0: Added multiplexed i2c bus 6
Feb 18 19:34:23 turris kernel: [ 4.754871] i2c i2c-0: Added multiplexed i2c bus 7
Feb 18 19:34:23 turris kernel: [ 4.759851] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
Feb 18 19:34:23 turris kernel: [ 4.772417] i2c i2c-0: Added multiplexed i2c bus 8
Feb 18 19:34:23 turris kernel: [ 4.777220] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
Feb 18 19:34:23 turris kernel: [ 4.794807] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Feb 18 19:34:23 turris kernel: [ 4.807284] orion_wdt: Initial timeout 171 sec, nowayout
Feb 18 19:34:23 turris kernel: [ 4.812848] sdhci: Secure Digital Host Controller Interface driver
Feb 18 19:34:23 turris kernel: [ 4.819041] sdhci: Copyright(c) Pierre Ossman
Feb 18 19:34:23 turris kernel: [ 4.881288] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
Feb 18 19:34:23 turris kernel: [ 4.888787] sdhci-pltfm: SDHCI platform and OF driver helper
Feb 18 19:34:23 turris kernel: [ 4.909631] marvell-cesa f1090000.crypto: CESA device successfully registered
Feb 18 19:34:23 turris kernel: [ 4.917251] NET: Registered protocol family 10
Feb 18 19:34:23 turris kernel: [ 4.922270] Segment Routing with IPv6
Feb 18 19:34:23 turris kernel: [ 4.925969] NET: Registered protocol family 17
Feb 18 19:34:23 turris kernel: [ 4.930435] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Feb 18 19:34:23 turris kernel: [ 4.943587] 8021q: 802.1Q VLAN Support v1.8
Feb 18 19:34:23 turris kernel: [ 4.947806] Key type dns_resolver registered
Feb 18 19:34:23 turris kernel: [ 4.952174] Registering SWP/SWPB emulation handler
Feb 18 19:34:23 turris kernel: [ 4.957575] registered taskstats version 1
Feb 18 19:34:23 turris kernel: [ 4.962627] Btrfs loaded, crc32c=crc32c-generic
Feb 18 19:34:23 turris kernel: [ 4.967880] libphy: SFP I2C Bus: probed
Feb 18 19:34:23 turris kernel: [ 4.971866] mmc0: new high speed MMC card at address 0001
Feb 18 19:34:23 turris kernel: [ 4.977464] mmcblk0: mmc0:0001 008G30 7.28 GiB
Feb 18 19:34:23 turris kernel: [ 4.982095] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
Feb 18 19:34:23 turris kernel: [ 4.988088] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
Feb 18 19:34:23 turris kernel: [ 4.994134] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB
Feb 18 19:34:23 turris kernel: [ 5.000909] random: fast init done
Feb 18 19:34:23 turris kernel: [ 5.004376] mmcblk0: p1
Feb 18 19:34:23 turris kernel: [ 5.012325] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Feb 18 19:34:23 turris kernel: [ 5.167022] libphy: mv88e6xxx SMI: probed
Feb 18 19:34:23 turris kernel: [ 5.171095] DSA: switch 0 0 parsed
Feb 18 19:34:23 turris kernel: [ 5.174517] DSA: tree 0 parsed
Feb 18 19:34:23 turris kernel: [ 5.332585] sfp sfp: module FLEXOPTIX S.B1312.10.XDL rev A sn F78VGUA dc 12-02-19
Feb 18 19:34:23 turris kernel: [ 5.341921] sfp sfp: LC connector, encoding 8b10b, nominal bitrate 1.3Gbps +0% -0%
Feb 18 19:34:23 turris kernel: [ 5.349683] sfp sfp: 1000BaseSX- 1000BaseLX- 1000BaseCX- 1000BaseT- 100BaseTLX- 1000BaseFX- BaseBX10+ BasePX-
Feb 18 19:34:23 turris kernel: [ 5.359797] sfp sfp: 10GBaseSR- 10GBaseLR- 10GBaseLRM- 10GBaseER-
Feb 18 19:34:23 turris kernel: [ 5.366080] sfp sfp: Wavelength 1310nm, fiber lengths:
Feb 18 19:34:23 turris kernel: [ 5.371407] sfp sfp: 9µm SM : 10000m
Feb 18 19:34:23 turris kernel: [ 5.375684] sfp sfp: 62.5µm MM OM1: unsupported/unspecified
Feb 18 19:34:23 turris kernel: [ 5.381445] sfp sfp: 50µm MM OM2: unsupported/unspecified
Feb 18 19:34:23 turris kernel: [ 5.387203] sfp sfp: 50µm MM OM3: unsupported/unspecified
Feb 18 19:34:23 turris kernel: [ 5.392963] sfp sfp: 50µm MM OM4: unsupported/unspecified
Feb 18 19:34:23 turris kernel: [ 5.398722] sfp sfp: Options: txdisable, txfault, los+
Feb 18 19:34:23 turris kernel: [ 5.404049] sfp sfp: Diagnostics: ddm, intcal, rxpwravg
Feb 18 19:34:23 turris kernel: [ 5.409464] mvneta f1034000.ethernet eth2: switched to 802.3z/1000base-x link mode
Feb 18 19:34:23 turris kernel: [ 5.955377] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
Feb 18 19:34:23 turris kernel: [ 6.085385] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540]
Feb 18 19:34:23 turris kernel: [ 6.215378] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540]
Feb 18 19:34:23 turris kernel: [ 6.345377] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540]
Feb 18 19:34:23 turris kernel: [ 6.467611] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540]
Feb 18 19:34:23 turris kernel: [ 6.487425] armada38x-rtc f10a3800.rtc: setting system clock to 2020-02-18 18:34:04 UTC (1582050844)
Feb 18 19:34:23 turris kernel: [ 6.500114] BTRFS: device fsid 9614f959-c6d3-4443-a3c3-8fd35213f71b devid 1 transid 85 /dev/root
Feb 18 19:34:23 turris kernel: [ 6.510282] BTRFS info (device mmcblk0p1): disk space caching is enabled
Feb 18 19:34:23 turris kernel: [ 6.517009] BTRFS info (device mmcblk0p1): has skinny extents
Feb 18 19:34:23 turris kernel: [ 6.531256] BTRFS info (device mmcblk0p1): enabling ssd optimizations
Feb 18 19:34:23 turris kernel: [ 6.542087] VFS: Mounted root (btrfs filesystem) on device 0:13.
Feb 18 19:34:23 turris kernel: [ 6.549589] devtmpfs: mounted
Feb 18 19:34:23 turris kernel: [ 6.553137] Freeing unused kernel memory: 1024K
Feb 18 19:34:23 turris kernel: 6.631532] init: Console is alive
Feb 18 19:34:23 turris kernel: 6.635003] init: - watchdog -
Feb 18 19:34:23 turris kernel: 6.773465] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Feb 18 19:34:23 turris kernel: [ 6.785116] ledtrig_transient: no symbol version for module_layout
Feb 18 19:34:23 turris kernel: 6.791675] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Feb 18 19:34:23 turris kernel: 6.801502] init: - preinit -
Feb 18 19:34:23 turris kernel: [ 6.874449] random: jshn: uninitialized urandom read (4 bytes read)
Feb 18 19:34:23 turris kernel: [ 6.890735] random: jshn: uninitialized urandom read (4 bytes read)
Feb 18 19:34:23 turris kernel: [ 6.922611] random: jshn: uninitialized urandom read (4 bytes read)
Feb 18 19:34:23 turris kernel: 10.021641] mount_root: mounting /dev/root
Feb 18 19:34:23 turris kernel: [ 10.050192] BTRFS info (device mmcblk0p1): disk space caching is enabled
Feb 18 19:34:23 turris kernel: 10.237842] urandom-seed: Seeding with /etc/urandom.seed
Feb 18 19:34:23 turris kernel: 10.258149] procd: - early -
Feb 18 19:34:23 turris kernel: 10.261061] procd: - watchdog -
Feb 18 19:34:23 turris kernel: 10.861330] procd: - watchdog -
Feb 18 19:34:23 turris kernel: 10.864572] procd: - ubus -
Feb 18 19:34:23 turris kernel: [ 10.875503] urandom_read: 2 callbacks suppressed
Feb 18 19:34:23 turris kernel: [ 10.875505] random: ubusd: uninitialized urandom read (4 bytes read)
Feb 18 19:34:23 turris kernel: [ 10.916865] random: ubusd: uninitialized urandom read (4 bytes read)
Feb 18 19:34:23 turris kernel: [ 10.923326] random: ubusd: uninitialized urandom read (4 bytes read)
Feb 18 19:34:23 turris kernel: 10.929889] procd: - init -
Feb 18 19:34:23 turris kernel: 10.973842] kmodloader: loading kernel modules from /etc/modules.d/*
Feb 18 19:34:23 turris kernel: [ 10.983898] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Feb 18 19:34:23 turris kernel: [ 10.992805] ip6_tables: (C) 2000-2006 Netfilter Core Team
Feb 18 19:34:23 turris kernel: [ 11.001126] Netfilter messages via NETLINK v0.30.
Feb 18 19:34:23 turris kernel: [ 11.006832] ip_set: protocol 6
Feb 18 19:34:23 turris kernel: [ 11.023920] u32 classifier
Feb 18 19:34:23 turris kernel: [ 11.026641] input device check on
Feb 18 19:34:23 turris kernel: [ 11.030315] Actions configured
Feb 18 19:34:23 turris kernel: [ 11.034822] Mirror/redirect action on
Feb 18 19:34:23 turris kernel: [ 11.039200] sch_cake: loading out-of-tree module taints kernel.
Feb 18 19:34:23 turris kernel: [ 11.045380] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
Feb 18 19:34:23 turris kernel: [ 11.051706] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
Feb 18 19:34:23 turris kernel: [ 11.093366] Bridge firewalling registered
Feb 18 19:34:23 turris kernel: [ 11.097663] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180
Feb 18 19:34:23 turris kernel: [ 11.105718] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
Feb 18 19:34:23 turris kernel: [ 11.117812] Ebtables v2.0 registered
Feb 18 19:34:23 turris kernel: [ 11.122464] ip_tables: (C) 2000-2006 Netfilter Core Team
Feb 18 19:34:23 turris kernel: [ 11.131727] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Feb 18 19:34:23 turris kernel: [ 11.139360] ctnetlink v0.93: registering with nfnetlink.
Feb 18 19:34:23 turris kernel: [ 11.161559] usbcore: registered new interface driver usbserial
Feb 18 19:34:23 turris kernel: [ 11.167478] usbcore: registered new interface driver usbserial_generic
Feb 18 19:34:23 turris kernel: [ 11.174086] usbserial: USB Serial support registered for generic
Feb 18 19:34:23 turris kernel: [ 11.191567] xt_time: kernel timezone is -0000
Feb 18 19:34:23 turris kernel: [ 11.197592] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
Feb 18 19:34:23 turris kernel: [ 11.227404] PPP generic driver version 2.4.2
Feb 18 19:34:23 turris kernel: [ 11.232560] NET: Registered protocol family 24
Feb 18 19:34:23 turris kernel: [ 11.244924] pci 0000:00:02.0: enabling device (0140 -> 0142)
Feb 18 19:34:23 turris kernel: [ 11.250638] ath10k_pci 0000:02:00.0: enabling device (0140 -> 0142)
Feb 18 19:34:23 turris kernel: [ 11.257219] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Feb 18 19:34:23 turris kernel: [ 11.495195] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
Feb 18 19:34:23 turris kernel: [ 11.505946] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:34:23 turris kernel: [ 11.795354] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
Feb 18 19:34:23 turris kernel: [ 11.804513] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
Feb 18 19:34:23 turris kernel: [ 11.814897] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:34:23 turris kernel: [ 11.825347] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
Feb 18 19:34:23 turris kernel: [ 11.834138] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
Feb 18 19:34:23 turris kernel: [ 11.844874] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:34:23 turris kernel: [ 11.855270] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
Feb 18 19:34:23 turris kernel: [ 11.872495] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Feb 18 19:34:23 turris kernel: [ 11.881754] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
Feb 18 19:34:23 turris kernel: [ 11.891260] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00037 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 a4a52adb
Feb 18 19:34:23 turris kernel: [ 11.936056] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
Feb 18 19:34:23 turris kernel: [ 11.946522] ath10k_pci 0000:02:00.0: Falling back to user helper
Feb 18 19:34:23 turris kernel: [ 11.956926] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
Feb 18 19:34:23 turris kernel: [ 11.966959] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Feb 18 19:34:23 turris kernel: [ 13.102925] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Feb 18 19:34:23 turris kernel: [ 13.231761] ath: EEPROM regdomain: 0x0
Feb 18 19:34:23 turris kernel: [ 13.231764] ath: EEPROM indicates default country code should be used
Feb 18 19:34:23 turris kernel: [ 13.231765] ath: doing EEPROM country->regdmn map search
Feb 18 19:34:23 turris kernel: [ 13.231769] ath: country maps to regdmn code: 0x3a
Feb 18 19:34:23 turris kernel: [ 13.231771] ath: Country alpha2 being used: US
Feb 18 19:34:23 turris kernel: [ 13.231773] ath: Regpair used: 0x3a
Feb 18 19:34:23 turris kernel: [ 13.240117] usbcore: registered new interface driver qcserial
Feb 18 19:34:23 turris kernel: [ 13.245945] usbserial: USB Serial support registered for Qualcomm USB modem
Feb 18 19:34:23 turris kernel: [ 13.257736] pci 0000:00:01.0: enabling device (0140 -> 0142)
Feb 18 19:34:23 turris kernel: [ 13.263454] ath9k 0000:01:00.0: enabling device (0140 -> 0142)
Feb 18 19:34:23 turris kernel: [ 13.356855] ath: EEPROM regdomain: 0x0
Feb 18 19:34:23 turris kernel: [ 13.356862] ath: EEPROM indicates default country code should be used
Feb 18 19:34:23 turris kernel: [ 13.356865] ath: doing EEPROM country->regdmn map search
Feb 18 19:34:23 turris kernel: [ 13.356872] ath: country maps to regdmn code: 0x3a
Feb 18 19:34:23 turris kernel: [ 13.356877] ath: Country alpha2 being used: US
Feb 18 19:34:23 turris kernel: [ 13.356882] ath: Regpair used: 0x3a
Feb 18 19:34:23 turris kernel: [ 13.368851] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Feb 18 19:34:23 turris kernel: [ 13.372246] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf1010000, irq=82
Feb 18 19:34:23 turris kernel: 13.379369] kmodloader: done loading kernel modules from /etc/modules.d/*
Feb 18 19:34:23 turris kernel: [ 13.831215] random: crng init done
Feb 18 19:34:23 turris kernel: [ 13.834723] random: 2 urandom warning(s) missed due to ratelimiting
Feb 18 19:34:23 turris kernel: [ 17.202187] watchdog: watchdog0: nowayout prevents watchdog being stopped!
Feb 18 19:34:23 turris kernel: [ 17.209082] watchdog: watchdog0: watchdog did not stop!
Feb 18 19:34:23 turris kernel: [ 17.216886] watchdog: watchdog0: nowayout prevents watchdog being stopped!
Feb 18 19:34:23 turris kernel: [ 17.223841] watchdog: watchdog0: watchdog did not stop!
Feb 18 19:34:23 turris kernel: [ 18.646382] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Feb 18 19:34:23 turris kernel: [ 18.655999] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
Feb 18 19:34:23 turris kernel: [ 18.664038] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Feb 18 19:34:23 turris kernel: [ 18.669948] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Feb 18 19:34:23 turris kernel: [ 18.678059] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Feb 18 19:34:23 turris kernel: [ 18.688439] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
Feb 18 19:34:23 turris kernel: [ 18.700845] br-lan: port 1(lan0) entered blocking state
Feb 18 19:34:23 turris kernel: [ 18.706129] br-lan: port 1(lan0) entered disabled state
Feb 18 19:34:23 turris kernel: [ 18.717150] device lan0 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 18.721834] device eth1 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 18.780012] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
Feb 18 19:34:23 turris kernel: [ 18.799722] br-lan: port 2(lan1) entered blocking state
Feb 18 19:34:23 turris kernel: [ 18.805010] br-lan: port 2(lan1) entered disabled state
Feb 18 19:34:23 turris kernel: [ 18.813992] device lan1 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 18.859580] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
Feb 18 19:34:23 turris kernel: [ 18.886308] br-lan: port 3(lan2) entered blocking state
Feb 18 19:34:23 turris kernel: [ 18.891572] br-lan: port 3(lan2) entered disabled state
Feb 18 19:34:23 turris kernel: [ 18.902238] device lan2 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 18.949050] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
Feb 18 19:34:23 turris kernel: [ 18.966872] br-lan: port 4(lan3) entered blocking state
Feb 18 19:34:23 turris kernel: [ 18.972133] br-lan: port 4(lan3) entered disabled state
Feb 18 19:34:23 turris kernel: [ 18.983082] device lan3 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 19.033814] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
Feb 18 19:34:23 turris kernel: [ 19.041686] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 18 19:34:23 turris kernel: [ 19.047675] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Feb 18 19:34:23 turris kernel: [ 19.057150] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
Feb 18 19:34:23 turris kernel: [ 19.064926] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Feb 18 19:34:23 turris kernel: [ 19.071325] br-lan: port 5(lan4) entered blocking state
Feb 18 19:34:23 turris kernel: [ 19.076569] br-lan: port 5(lan4) entered disabled state
Feb 18 19:34:23 turris kernel: [ 19.089101] device lan4 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 19.093747] device eth0 entered promiscuous mode
Feb 18 19:34:23 turris kernel: [ 19.147751] mvneta f1034000.ethernet eth2: configuring for 802.3z/1000base-x link mode
Feb 18 19:34:23 turris kernel: [ 19.156980] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
Feb 18 19:34:23 turris kernel: [ 19.368694] ath: EEPROM regdomain: 0x82f4
Feb 18 19:34:23 turris kernel: [ 19.368697] ath: EEPROM indicates we should expect a country code
Feb 18 19:34:23 turris kernel: [ 19.368699] ath: doing EEPROM country->regdmn map search
Feb 18 19:34:23 turris kernel: [ 19.368702] ath: country maps to regdmn code: 0x37
Feb 18 19:34:23 turris kernel: [ 19.368704] ath: Country alpha2 being used: CH
Feb 18 19:34:23 turris kernel: [ 19.368705] ath: Regpair used: 0x37
Feb 18 19:34:23 turris kernel: [ 19.368708] ath: regdomain 0x82f4 dynamically updated by user
Feb 18 19:34:23 turris kernel: [ 19.368756] ath: EEPROM regdomain: 0x82f4
Feb 18 19:34:23 turris kernel: [ 19.368757] ath: EEPROM indicates we should expect a country code
Feb 18 19:34:23 turris kernel: [ 19.368759] ath: doing EEPROM country->regdmn map search
Feb 18 19:34:23 turris kernel: [ 19.368761] ath: country maps to regdmn code: 0x37
Feb 18 19:34:23 turris kernel: [ 19.368763] ath: Country alpha2 being used: CH
Feb 18 19:34:23 turris kernel: [ 19.368764] ath: Regpair used: 0x37
Feb 18 19:34:23 turris kernel: [ 19.368766] ath: regdomain 0x82f4 dynamically updated by user
Feb 18 19:34:23 turris kernel: [ 19.461305] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
Feb 18 19:34:23 turris kernel: [ 19.469342] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Feb 18 19:34:23 turris kernel: [ 21.927601] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
Feb 18 19:34:23 turris kernel: [ 21.939172] br-lan: port 1(lan0) entered blocking state
Feb 18 19:34:23 turris kernel: [ 21.944436] br-lan: port 1(lan0) entered forwarding state
Feb 18 19:34:23 turris kernel: [ 21.972790] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Feb 18 18:34:23 turris firewall: Reloading firewall due to ifup of wan6 (eth2)
Feb 18 18:34:23 turris odhcpd[2878]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
Feb 18 18:34:28 turris procd: /etc/rc.d/S80umdns: Command failed: Request timed out
Feb 18 18:34:28 turris procd: /etc/rc.d/S96led: setting up led wan
Feb 18 18:34:28 turris procd: /etc/rc.d/S96led: setting up led pci1
Feb 18 18:34:28 turris procd: /etc/rc.d/S96led: setting up led pci2
Feb 18 18:34:28 turris procd: /etc/rc.d/S96led: setting up led pci3
Feb 18 18:34:28 turris turris: Router Turris successfully started.
Feb 18 18:34:29 turris procd: /etc/rc.d/S99start-indicator: setting up led wan
Feb 18 18:34:29 turris procd: /etc/rc.d/S99start-indicator: setting up led pci1
Feb 18 18:34:29 turris procd: /etc/rc.d/S99start-indicator: setting up led pci2
Feb 18 18:34:29 turris procd: /etc/rc.d/S99start-indicator: setting up led pci3
Feb 18 18:34:29 turris procd: - init complete -
Feb 18 19:34:14 turris dnsmasq[2783]: started, version 2.80 DNS disabled
Feb 18 19:34:32 turris dnsmasq[2783]: overflow: 2 log entries lost
Feb 18 19:34:32 turris dnsmasq[4740]: started, version 2.80 DNS disabled
Feb 18 19:34:32 turris dnsmasq[4740]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Feb 18 19:34:32 turris dnsmasq-dhcp[4740]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Feb 18 19:34:32 turris dnsmasq-dhcp[4740]: read /etc/ethers - 0 addresses
Feb 18 18:34:35 turris kresd[4394]: [ ta ] key: 20326 state: Valid
Feb 18 18:34:35 turris kresd[4394]: [ ta ] next refresh for . in 22.642083333333 hours
Feb 18 19:34:42 turris dnsmasq-dhcp[4740]: DHCPDISCOVER(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e
Feb 18 19:34:42 turris dnsmasq-dhcp[4740]: DHCPOFFER(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e
Feb 18 19:34:42 turris dnsmasq-dhcp[4740]: DHCPREQUEST(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e
Feb 18 19:34:42 turris dnsmasq-dhcp[4740]: DHCPACK(br-lan) 192.168.1.133 68:f7:28:fa:ae:3e Jyn
Feb 18 18:34:42 turris 99-dhcp_host_domain_ng.py: DHCP add new hostname [Jyn,192.168.1.133]
Feb 18 18:34:42 turris 99-dhcp_host_domain_ng.py: Refresh kresd leases
Feb 18 18:34:42 turris kresd[4394]: hints.add_hosts('/tmp/kresd/hints.tmp')
Feb 18 18:34:42 turris kresd[4394]: [result] => true
Feb 18 18:34:45 turris procd: Instance umdns::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Feb 18 18:34:47 turris procd: Instance foris-controller::instance1 s in a crash loop 6 crashes, 1 seconds since last crash
Feb 18 18:35:03 turris /usr/sbin/cron[4802]: (root) CMD (/usr/bin/notifier)
Feb 18 18:35:03 turris /usr/sbin/cron[4803]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
What I have in /var/log/lighttpd/error.log is
2020-02-18 20:02:18: (gw_backend.c.331) child signalled: 11
2020-02-18 20:02:19: (gw_backend.c.468) unlink /tmp/fastcgi.foris-config.socket-0 after connect failed: Connection refused
For the wifi issue, here are the logs just after trying to setup a wifi
network.
Feb 18 19:02:01 turris /usr/sbin/cron[5293]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 18 19:02:37 turris netifd: radio0 (6083): ./mac80211.sh: eval: line 1: hostapd_conf_file}/var/run/hostapd-phy0.conf: not found
Feb 18 19:02:37 turris mac80211: Failed command: iw phy phy0 set antenna all all
Feb 18 19:03:01 turris /usr/sbin/cron[9767]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 18 19:03:02 turris netifd: radio0 (10023): ./mac80211.sh: eval: line 1: hostapd_conf_file}/var/run/hostapd-phy0.conf: not found
Feb 18 19:03:02 turris mac80211: Failed command: iw phy phy0 set antenna all all
Feb 18 19:03:02 turris netifd: radio0 (10023): ./mac80211.sh: eval: line 1: can't create : nonexistent directory
Feb 18 19:03:02 turris hostapd: Configuration file:
Feb 18 19:03:02 turris hostapd: Could not open configuration file '' for reading.
Feb 18 19:03:02 turris hostapd: Failed to set up interface with
Feb 18 19:03:02 turris hostapd: Failed to initialize interface
Feb 18 19:03:02 turris netifd: radio0 (10023): cat: can't open '/var/run/wifi-phy0.pid': No such file or directory
Feb 18 19:03:02 turris netifd: radio0 (10023): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process path ()
Feb 18 19:03:02 turris netifd: radio0 (10023): Command failed: Invalid argument
Feb 18 19:03:02 turris netifd: radio0 (10023): Device setup failed: HOSTAPD_START_FAILED
Once gain, thank you for the answers.
