Ano, to projde.
U-Boot 2015.04-04654-gbcfb33e-dirty (Jun 26 2015 - 12:50:49)
CPU0: P2020E, Version: 2.1, (0x80ea0021)
Core: e500, Version: 5.1, (0x80211051)
Clock Configuration:
CPU0:1200 MHz, CPU1:1200 MHz,
CCB:600 MHz,
DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:37.500 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
wdt status 00000005 reset
Watchdog enabled
Board: TURRIS CPLD: V4.1 PCBA: V4.0
Error, wrong i2c adapter 2 max 2 possible
in: 56
out: 0
io_config: 255
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C: Error, wrong i2c adapter 2 max 2 possible
ready
SPI: ready
DRAM: Error, wrong i2c adapter 2 max 2 possible
Detected UDIMM 9905428-181.A00LF
WARNING: Calling __hwconfig without a buffer and before environment is ready
2 GiB (DDR3, 64-bit, CL=6, ECC off)
Flash: 16 MiB
L2: 512 KiB enabled
NAND: 256 MiB
MMC: FSL_SDHC: 0
PCIe1: Root Complex of mini PCIe SLOT, no link, regs @ 0xffe0a000
PCIe1: Bus 00 - 00
PCIe2: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe09000
02:00.0 - 168c:0030 - Network controller
PCIe2: Bus 01 - 02
PCIe3: Root Complex of PCIe SLOT, no link, regs @ 0xffe08000
PCIe3: Bus 03 - 03
In: serial
Out: serial
Err: serial
Net: Phy 5 not found
PHY reset timed out
eTSEC1
Error: eTSEC1 address not set.
, eTSEC2
Error: eTSEC2 address not set.
, eTSEC3 [PRIME]
Error: eTSEC3 address not set.
Hit any key to stop autoboot: 1 0
=>run mmcboot
wdt status 00000003
reading fdt
12945 bytes read in 14 ms (902.3 KiB/s)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 02100000 ...
Image Name: Linux-4.4.199-f90a52a6230ecb072f
Created: 2021-01-29 18:42:35 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 3319917 Bytes = 3.2 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 03ff9000, end 03fff290 ... OK
WARNING: could not find compatible node fsl-usb2-dr
[ 0.000000] Using P2020 RDB machine description
[ 0.000000] Memory CAM mapping: 256/256 Mb, residual: 1536Mb
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.199-f90a52a6230ecb072f657fce5aebd444-1 (beast@build) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r47055) ) #1 SMP Fri Jan 29 19:42:29 CET 2021
[ 0.000000] CPU maps initialized for 1 thread per core
[ 0.000000] bootconsole [udbg0] enabled
setup_arch: initmem
mpc85xx_rdb_setup_arch()
[ 0.000000] mpc85xx_qe_init: Could not find Quicc Engine node
[ 0.000000] MPC85xx RDB board from Freescale Semiconductor
arch: exit
[ 0.000000] barrier-nospec: using isync; sync as speculation barrier
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000020000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[ 0.000000] PERCPU: Embedded 10 pages/cpu @dedc2000 s9420 r8192 d23348 u40960
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523136
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rw rootfstype=btrfs rootflags=subvol=@,commit=5 console=ttyS0,115200
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Sorting __ex_table...
[ 0.000000] Memory: 2005324K/2097152K available (5048K kernel code, 180K rwdata, 1100K rodata, 200K init, 244K bss, 91828K reserved, 0K cma-reserved, 1572856K highmem)
[ 0.000000] Kernel virtual memory layout:
[ 0.000000] * 0xfffbf000..0xfffff000 : fixmap
[ 0.000000] * 0xffc00000..0xffe00000 : highmem PTEs
[ 0.000000] * 0xffbfd000..0xffc00000 : early ioremap
[ 0.000000] * 0xe1000000..0xffbfd000 : vmalloc & ioremap
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:512 nr_irqs:512 16
[ 0.000000] mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs
[ 0.000000] mpic: ISU size: 256, shift: 8, mask: ff
[ 0.000000] mpic: Initializing for 256 sources
[ 0.000000] mpc85xx_rdb_pic_init: Could not find qe-ic node
[ 0.000008] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114c1bade8, max_idle_ns: 440795203839 ns
[ 0.010276] clocksource: timebase mult[d555555] shift[24] registered
[ 0.016657] pid_max: default: 32768 minimum: 301
[ 0.021305] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.027843] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.035252] Initializing cgroup subsys io
[ 0.039188] Initializing cgroup subsys memory
[ 0.043540] Initializing cgroup subsys devices
[ 0.047962] Initializing cgroup subsys freezer
[ 0.052394] Initializing cgroup subsys net_cls
[ 0.056827] Initializing cgroup subsys pids
[ 0.061145] mpic: requesting IPIs...
[ 0.065662] Brought up 2 CPUs
[ 0.070674] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.080352] futex hash table entries: 512 (order: 2, 16384 bytes)
[ 0.086527] xor: measuring software checksum speed
[ 0.101287] 8regs : 1472.000 MB/sec
[ 0.115425] 8regs_prefetch: 1312.000 MB/sec
[ 0.129908] 32regs : 1472.000 MB/sec
[ 0.144044] 32regs_prefetch: 1356.000 MB/sec
[ 0.148576] xor: using function: 32regs (1472.000 MB/sec)
[ 0.154296] NET: Registered protocol family 16
[ 0.163700] cpuidle: using governor ladder
[ 0.173963] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus number: 0->0
[ 0.181813] PCI host bridge /pcie@ffe08000 (primary) ranges:
[ 0.187460] MEM 0x00000000c0000000..0x00000000dfffffff -> 0x00000000c0000000
[ 0.194673] IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000
[ 0.201811] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
[ 0.206581] setup_pci_atmu: end of DRAM 80000000
[ 0.211447] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->1
[ 0.219290] PCI host bridge /pcie@ffe09000 ranges:
[ 0.224157] MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
[ 0.231371] IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
[ 0.238507] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
[ 0.243279] setup_pci_atmu: end of DRAM 80000000
[ 0.248136] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->0
[ 0.255978] PCI host bridge /pcie@ffe0a000 ranges:
[ 0.260846] MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
[ 0.268059] IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
[ 0.275195] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
[ 0.279968] setup_pci_atmu: end of DRAM 80000000
[ 0.293320] PCI: Probing PCI hardware
[ 0.297053] fsl-pci ffe08000.pcie: PCI host bridge to bus 0000:00
[ 0.303074] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.309240] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff]
[ 0.316109] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.321882] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.329901] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.335243] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
[ 0.341265] pci_bus 0001:02: root bus resource [io 0x20000-0x2ffff] (bus address [0x0000-0xffff])
[ 0.350213] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
[ 0.357081] pci_bus 0001:02: root bus resource [bus 02-ff]
[ 0.362801] pci 0001:02:00.0: Primary bus is hard wired to 0
[ 0.368384] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[ 0.378404] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.383762] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0002:04
[ 0.389788] pci_bus 0002:04: root bus resource [io 0x40000-0x4ffff] (bus address [0x0000-0xffff])
[ 0.398732] pci_bus 0002:04: root bus resource [mem 0x80000000-0x9fffffff]
[ 0.405599] pci_bus 0002:04: root bus resource [bus 04-ff]
[ 0.411329] pci 0002:04:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.419345] pci 0002:04:00.0: PCI bridge to [bus 05-ff]
[ 0.424580] PCI: Cannot allocate resource region 0 of PCI bridge 1, will remap
[ 0.431732] PCI: Cannot allocate resource region 0 of device 0000:00:00.0, will remap
[ 0.439551] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, will remap
[ 0.447375] PCI: Cannot allocate resource region 0 of device 0002:04:00.0, will remap
[ 0.455230] pci 0000:00:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.461804] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.468758] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.473713] pci 0000:00:00.0: bridge window [mem 0xc0000000-0xdfffffff]
[ 0.480494] pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.489565] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.496142] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.503100] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref]
[ 0.510316] pci 0001:02:00.0: PCI bridge to [bus 03]
[ 0.515267] pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
[ 0.521526] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xbfffffff]
[ 0.528307] pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.537386] pci 0002:04:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.543955] pci 0002:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.550909] pci 0002:04:00.0: PCI bridge to [bus 05]
[ 0.555864] pci 0002:04:00.0: bridge window [io 0x40000-0x4ffff]
[ 0.562124] pci 0002:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
[ 0.568905] pci_bus 0002:04: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.578229] mpic-msgr ffe41400.message: Found 0 message registers
[ 0.584247] mpic-msgr ffe41400.message: Of-device full name /soc@ffe00000/message@41400
[ 0.592250] mpic-msgr ffe41400.message: Failed to find message register block alias
[ 0.624741] raid6: int32x1 gen() 171 MB/s
[ 0.646126] raid6: int32x1 xor() 220 MB/s
[ 0.667440] raid6: int32x2 gen() 300 MB/s
[ 0.688809] raid6: int32x2 xor() 261 MB/s
[ 0.710111] raid6: int32x4 gen() 398 MB/s
[ 0.731414] raid6: int32x4 xor() 283 MB/s
[ 0.752776] raid6: int32x8 gen() 378 MB/s
[ 0.774111] raid6: int32x8 xor() 253 MB/s
[ 0.778296] raid6: using algorithm int32x4 gen() 398 MB/s
[ 0.783684] raid6: .... xor() 283 MB/s, rmw enabled
[ 0.788553] raid6: using intx1 recovery algorithm
[ 0.794521] clocksource: Switched to clocksource timebase
[ 0.800661] NET: Registered protocol family 2
[ 0.805355] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.812367] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.818800] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.825167] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.830947] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.837331] NET: Registered protocol family 1
[ 0.848010] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.853941] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.866459] bounce: pool size: 64 pages
[ 0.870272] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.877609] io scheduler noop registered
[ 0.881516] io scheduler deadline registered (default)
[ 0.886937] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
[ 0.893106] pcieport 0002:04:00.0: enabling device (0106 -> 0107)
[ 0.899442] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.906362] pcieport 0001:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.913282] pci 0001:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.919840] pcieport 0002:04:00.0: Signaling PME through PCIe PME interrupt
[ 0.952744] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.961249] console [ttyS0] disabled
[ 0.964778] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550A
[ 0.973454] console [ttyS0] enabled
[ 0.980399] bootconsole [udbg0] disabled
[ 0.988641] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550A
[ 0.997921] console [ttyS0] disabled
[ 1.001540] console [ttyS0] enabled
[ 1.005440] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
[ 1.021507] brd: module loaded
[ 1.025309] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
[ 1.035333] Amd/Fujitsu Extended Query Table at 0x0040
[ 1.040502] Amd/Fujitsu Extended Query version 1.3.
[ 1.045560] number of CFI chips: 1
[ 1.049203] 6 ofpart partitions found on MTD device ef000000.nor
[ 1.055224] Creating 6 MTD partitions on "ef000000.nor":
[ 1.060543] 0x000000000000-0x000000020000 : "NOR (RO) DTB Image"
[ 1.067156] 0x000000020000-0x0000001c0000 : "NOR (RO) Linux Kernel Image"
[ 1.074530] 0x0000001c0000-0x000000340000 : "NOR (RO) JFFS2 Root File System"
[ 1.082211] 0x000000340000-0x000000e40000 : "NOR (RO) NAND FW backup"
[ 1.089191] 0x000000e40000-0x000000f00000 : "NOR (RW) Cert backup"
[ 1.095893] 0x000000f00000-0x000001000000 : "NOR (RO) U-Boot Image"
[ 1.103243] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.109616] nand: Micron MT29F2G08ABAEAWP
[ 1.113632] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.122544] Bad block table found at page 131008, version 0x01
[ 1.129139] Bad block table found at page 130944, version 0x01
[ 1.135557] 4 ofpart partitions found on MTD device ff800000.flash
[ 1.141750] Creating 4 MTD partitions on "ff800000.flash":
[ 1.147242] 0x000000000000-0x000000200000 : "NAND (RW) DTB Image"
[ 1.153895] 0x000000200000-0x000000700000 : "NAND (RW) Linux Kernel Image"
[ 1.161310] 0x000000700000-0x000010000000 : "NAND (RW) JFFS2 Root File System"
[ 1.169281] 0x000000000000-0x000010000000 : "rootfs-ubifs"
[ 1.175512] eLBC NAND device at 0xff800000, bank 1
[ 1.180744] fsl_espi ffe07000.spi: cs=0, init_csmode=0x100008
[ 1.186511] fsl_espi ffe07000.spi: cs=1, init_csmode=0x100008
[ 1.192273] fsl_espi ffe07000.spi: cs=2, init_csmode=0x100008
[ 1.198029] fsl_espi ffe07000.spi: cs=3, init_csmode=0x100008
[ 1.204835] fsl_espi ffe07000.spi: at 0xe11c0000 (irq = 59)
[ 1.210844] libphy: Fixed MDIO Bus: probed
[ 1.215153] libphy: Freescale PowerQUICC MII Bus: probed
[ 1.223004] switch0: Atheros AR8337 rev. 2 switch registered on mdio@ffe24520
[ 1.274214] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.292151] fsl-gianfar ffe24000.ethernet eth0: mac: 00:00:00:00:00:00
[ 1.298691] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
[ 1.305487] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
[ 1.312631] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
[ 1.320058] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.337935] fsl-gianfar ffe25000.ethernet eth1: mac: 00:00:00:00:00:00
[ 1.344477] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
[ 1.351273] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
[ 1.358416] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
[ 1.365637] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.383503] fsl-gianfar ffe26000.ethernet eth2: mac: 00:00:00:00:00:00
[ 1.390050] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
[ 1.396848] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
[ 1.403991] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
[ 1.411225] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
[ 1.417343] i2c /dev entries driver
[ 1.420974] mpc-i2c ffe03000.i2c: timeout 1000000 us
[ 1.428453] rtc-ds1307 0-006f: rtc core: registered mcp7940x as rtc0
[ 1.434833] rtc-ds1307 0-006f: 64 bytes nvram
[ 1.439371] mpc-i2c ffe03100.i2c: timeout 1000000 us
[ 1.444616] booke_wdt: powerpc book-e watchdog driver loaded
[ 1.450460] sdhci: Secure Digital Host Controller Interface driver
[ 1.456650] sdhci: Copyright(c) Pierre Ossman
[ 1.461011] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.466857] sdhci-esdhc ffe2e000.sdhc: No vmmc regulator found
[ 1.472701] sdhci-esdhc ffe2e000.sdhc: No vqmmc regulator found
[ 1.501031] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
[ 1.508887] NET: Registered protocol family 10
[ 1.513954] NET: Registered protocol family 17
[ 1.518460] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.531118] Bridge firewalling registered
[ 1.535148] 8021q: 802.1Q VLAN Support v1.8
[ 1.540167] BTRFS: using crc32c-generic for crc32c
[ 1.546298] Btrfs loaded, integrity-checker=on
[ 1.552230] rtc-ds1307 0-006f: setting system clock to 2022-05-09 09:00:06 UTC (1652086806)
[ 1.561181] Waiting for root device /dev/mmcblk0p2...
[ 1.575986] mmc0: new high speed SDHC card at address b368
[ 1.581827] mmcblk0: mmc0:b368 SD 29.9 GiB
[ 1.587471] mmcblk0: p1 p2
[ 1.668200] BTRFS: device fsid fbab6df4-4aaf-4038-92f1-6a1a137ae841 devid 1 transid 29 /dev/root
[ 1.678866] BTRFS info (device mmcblk0p2): disk space caching is enabled
[ 1.685583] BTRFS: has skinny extents
[ 1.707339] BTRFS: detected SSD devices, enabling SSD mode
[ 1.725054] VFS: Mounted root (btrfs filesystem) on device 0:13.
[ 1.731307] Freeing unused kernel memory: 200K
[ 1.864891] init: Console is alive
[ 1.868415] init: - watchdog -
[ 2.320696] usbcore: registered new interface driver usbfs
[ 2.326245] usbcore: registered new interface driver hub
[ 2.331615] usbcore: registered new device driver usb
[ 2.338339] Button Hotplug driver version 0.4.1
[ 2.344715] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.351659] ehci-platform: EHCI generic platform driver
[ 2.357428] ehci-fsl: Freescale EHCI Host controller driver
[ 2.363086] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[ 2.369737] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[ 2.377036] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
[ 2.388030] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[ 2.394044] hub 1-0:1.0: USB hub found
[ 2.397825] hub 1-0:1.0: 1 port detected
[ 2.403103] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.703035] usb 1-1: new high-speed USB device number 2 using fsl-ehci
[ 2.823771] hub 1-1:1.0: USB hub found
[ 2.827666] hub 1-1:1.0: 2 ports detected
[ 2.871874] init: - preinit -
ifconfig: SIOCSIFFLAGS: Cannot assign requested address
sendto(): Network is unrea[ 3.548785] random: mktemp: uninitialized urandom read (6 bytes read, 63 bits of entropy available)
chable
[ 3.559958] random: mktemp: uninitialized urandom read (6 bytes read, 63 bits of entropy available)
[ 3.570968] random: mktemp: uninitialized urandom read (6 bytes read, 63 bits of entropy available)
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 6.613581] mount_root: mounting /dev/root
[ 6.618631] BTRFS info (device mmcblk0p2): disk space caching is enabled
ifconfig: SIOCSIFFLAGS: Cannot assig[ 6.632909] procd: - early -
n [ 6.635948] procd: - watchdog -
requested address
[ 6.790587] random: jshn: uninitialized urandom read (4 bytes read, 80 bits of entropy available)
Failed to connect to ubus
[ 6.829505] random: jshn: uninitialized urandom read (4 bytes read, 80 bits of entropy available)
[ 6.883164] random: jshn: uninitialized urandom read (4 bytes read, 82 bits of entropy available)
[ 6.918585] random: jshn: uninitialized urandom read (4 bytes read, 83 bits of entropy available)
[ 7.283767] procd: - ubus -
[ 8.286365] random: ubusd: uninitialized urandom read (4 bytes read, 115 bits of entropy available)
[ 8.303117] random: ubusd: uninitialized urandom read (4 bytes read, 115 bits of entropy available)
[ 8.327037] random: ubusd: uninitialized urandom read (4 bytes read, 115 bits of entropy available)
[ 8.343474] procd: - init -
Please press Enter to activate this console.
[ 8.427051] Netfilter messages via NETLINK v0.30.
[ 8.435324] NET: Registered protocol family 8
[ 8.439729] NET: Registered protocol family 20
[ 8.458119] tun: Universal TUN/TAP device driver, 1.6
[ 8.463199] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 8.474388] sit: IPv6 over IPv4 tunneling driver
[ 8.481634] gre: GRE over IPv4 demultiplexor driver
[ 8.487425] ip_gre: GRE over IPv4 tunneling driver
[ 8.495315] PPP generic driver version 2.4.2
[ 8.501451] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 8.513652] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 8.626465] ip_set: protocol 6
[ 8.668628] random: nonblocking pool is initialized
[ 9.090551] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[ 9.098589] Backport generated by backports.git backports-20160324-13-g24da7d3c
[ 9.400635] u32 classifier
[ 9.403371] input device check on
[ 9.407038] Actions configured
[ 9.466536] Mirror/redirect action on
[ 9.582462] GACT probability on
[ 10.081549] netem: version 1.3
[ 10.295755] usbcore: registered new interface driver cdc_wdm
[ 10.306418] Ebtables v2.0 registered
[ 10.313641] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.326031] ctnetlink v0.93: registering with nfnetlink.
[ 10.367215] nfnl_acct: registering with nfnetlink.
[ 10.373486] PPP MPPE Compression module registered
[ 10.379173] NET: Registered protocol family 24
[ 10.390587] usbcore: registered new interface driver usbserial
[ 10.396519] usbcore: registered new interface driver usbserial_generic
[ 10.403120] usbserial: USB Serial support registered for generic
[ 10.425102] xt_time: kernel timezone is -0000
[ 10.433580] usbcore: registered new interface driver cdc_ether
[ 10.449325] usbcore: registered new interface driver qmi_wwan
[ 10.456760] usbcore: registered new interface driver rndis_host
[ 10.599532] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xe3140000, irq=27
[ 10.608920] usbcore: registered new interface driver option
[ 10.614602] usbserial: USB Serial support registered for GSM modem (1-port)
May 9 11:00:19 haveged: haveged starting up
May 9 11:00:19 haveged: haveged: ver: 1.9.13; arch: ppc; vend: ; build: (gcc 4.8.3 V); collect: 128K
May 9 11:00:19 haveged: haveged: cpu: (); data: 32K (P); inst: 32K (P); idx: 15/40; sz: 30904/80288
May 9 11:00:19 haveged: haveged: fills: 0, generated: 0
[ 18.339710] mmcblk0: r/w command failed, status = 0x80000900
Router Turris successfully started.
BusyBox v1.29.3 () built-in shell (ash)
_______ _ _ _____ _____ _____ _____
|__ __|| | | || __ \ | __ \ |_ _| / ____|
| | | | | || |__) || |__) | | | | (___
| | | | | || _ / | _ / | | \___ \
| | | |__| || | \ \ | | \ \ _| |_ ____) |
|_| \____/ |_| \_\|_| \_\|_____||_____/
root@turris:/# mount
/dev/mmcblk0p2 on / type btrfs (rw,noatime,ssd,space_cache,commit=5,subvolid=257,subvol=/@)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
none on /sys/fs/cgroup type cgroup (rw,relatime,cpuset,cpu,cpuacct,blkio,memory,devices,freezer,net_cls,pids)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
root@turris:/# df -h
Filesystem Size Used Available Use% Mounted on
/dev/mmcblk0p2 29.8G 279.4M 29.3G 1% /
tmpfs 1011.5M 1.0M 1010.4M 0% /tmp
tmpfs 512.0K 0 512.0K 0% /dev
Zajímavé je, že když teď udělám reboot, tak už se to načítá správně a nemusím ten proces přerušovat. Jako kdyby ten run mmcboot
to spravil a od té doby to funguje.
