Turris 1.0 https web not works
Hello.
My url https://192.168.1.1 not works. Web page returns “connection error”. Ssh acces thru port 22 is enabled and working. I thing that problem is in ssh certificate check. When running “chrome.exe” --ignore-certificate-errors, still not works.
How i can detect where is a error?
tail /var/log/lighttpd/error.log
return
2022-02-14 17:39:56: (server.c.1488) server started (lighttpd/1.4.55)
Update return:
root@turris:~# updater.sh
updater.sh is obsoleted. Please use pkgupdate directly instead.
root@turris:~# pkgupdate
WARN:Couldn't read the status file: [string "backend"]:1195: [string "backend"]:1186: Failed to lock the lock file /var/lock/opkg.lock: Resource temporarily unavailable
There is not minimum 400MB of free storage to allow migration.
line not found
line not found
line not found
ERROR:
root@turris:~# There is not minimum 400MB of free storage to allow migration.
I guess you are running the blue Turris with TOS3.11.x? As the support for TOS3 has ended, you should migrate to TOS5.
Please read the Btrfs migration - Turris Documentation
Thx for reply. I’ll try upgrade to 5.0. But why unsupported version = malfunction?
If any user cannot upgrade, then last function state shoul be maintained. I haven’t needed to change router settings last year. And now when I need to make a change, I’m surprised where the basic interface has gone :-).
You see it wrong. unsupported version != malfunction
I mean unsupported version = nobody will help you and you are on your own.
:slight_smile:
I would expect the interface to work with some warning - “you are using an unsupported version”.
But that the whole interface going to the bucket?
Ok. Going upgrade to the 5.0
Actualy
root@turris:~# btrfs_migrate
1.1 firmware required!
I’m continuing in search of “how to”
Where did you got the idea that the interface got broken just because of unsupported version?
Can you verify your filesystems? Is it UBI or JFFS? In case it is JFFS, you need to perform the factory reset to migrate the filesystem from JFFS to UBI and then perform the step to migrate to btrfs.
As an alternative, you can follow Obnova systému a zavaděče z microSD karty [Turris wiki]
After the initial setup, you need to let it upgrade to the latest TOS 3.11.23 (by connecting over SSH and issuing the pkgupdate command) and then you can go through the btrfs_migrate
Ok. I am on turris os 5,0 now. Thaks for your help.
