does anyone managed to setup aiccu to tunnel all IPv6 traffic of the internal network over the aiccu tunnel? Somehow I can’t get it working.
Here is my config for the wan6 interface:
config interface 'wan6'
option _orig_ifname '@wan'
option _orig_bridge 'false'
option proto 'aiccu'
option username 'M*****-SIXXS' #sixxs username
option password '*******' #sixxs password
option tunnelid 'T*****' # tunnelid
option ip6prefix '2001:6f8:900:XXXX::/64'
option heartbeat '0'
option ip6addr '2001:6f8:900:YYY::2'
option nat '1'
Ping6 from the omnia to sixxs.net and ipv6.google.com is working.
When trying to ping ipv6.google.com from a client behind the omnia I get a timeout.
Here is an tcpdump from the omnia when I try to ping ipv6.google.com(shown as muc03s14-in-x0e.1e100.net) from a client (has 2001:6f8:900:903d:5999:ac85:6d72:a945 assigned by the omnia, which is in the ipv6 subnet of the tunnel). At the same time some other connection are also tried to established.
root@turris:~# tcpdump -i aiccu-wan6
tcpdump: WARNING: aiccu-wan6: no IPv4 address assigned
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on aiccu-wan6, link-type RAW (Raw IP), capture size 65535 bytes
02:30:47.692583 IP6 www.turris.cz.443 > 2001:6f8:900:903d:5999:ac85:6d72:a945.12899: Flags [.], ack 16584, win 1439, length 0
02:30:47.876875 IP6 2001:6f8:900:903d:5999:ac85:6d72:a945 > muc03s14-in-x0e.1e100.net: HBH ICMP6, echo request, seq 47, length 40
02:30:52.395740 IP6 2001:6f8:900:903d:5999:ac85:6d72:a945 > muc03s14-in-x0e.1e100.net: HBH ICMP6, echo request, seq 48, length 40
02:30:57.393909 IP6 2001:6f8:900:903d:5999:ac85:6d72:a945 > muc03s14-in-x0e.1e100.net: HBH ICMP6, echo request, seq 49, length 40
02:30:57.983752 IP6 2001:6f8:900:903d:5999:ac85:6d72:a945.4907 > wb-in-xbc.1e100.net.5228: Flags [.], seq 0:1, ack 1, win 253, length 1
02:30:58.057278 IP6 wb-in-xbc.1e100.net.5228 > 2001:6f8:900:903d:5999:ac85:6d72:a945.4907: Flags [.], ack 1, win 357, options [nop,nop,sack 1 {0:1}], length 0
As you can see the ipv6 ping packets from the client get to omnia but the omnia somehow does not receive the responses.
The same ping from the omnia shows this:
02:28:21.564752 IP6 cl-4158.ham-01.de.sixxs.net > muc03s14-in-x0e.1e100.net: ICMP6, echo request, seq 0, length 64
02:28:21.624460 IP6 muc03s14-in-x0e.1e100.net > cl-4158.ham-01.de.sixxs.net: ICMP6, echo reply, seq 0, length 64
02:28:22.564844 IP6 cl-4158.ham-01.de.sixxs.net > muc03s14-in-x0e.1e100.net: ICMP6, echo request, seq 1, length 64
02:28:22.624381 IP6 muc03s14-in-x0e.1e100.net > cl-4158.ham-01.de.sixxs.net: ICMP6, echo reply, seq 1, length 64
02:28:23.564993 IP6 cl-4158.ham-01.de.sixxs.net > muc03s14-in-x0e.1e100.net: ICMP6, echo request, seq 2, length 64
02:28:23.624391 IP6 muc03s14-in-x0e.1e100.net > cl-4158.ham-01.de.sixxs.net: ICMP6, echo reply, seq 2, length 64
As you can see here the omnia receives the response.
Edit: cleaned up output of the tcpdump and added tcpdump for successful ping from omnia.
