Trunk between Omina and MOX
I have recently bought Turris Omnia and Turris MOX devices and I tam not able to configure them for my purposes.
I want to have two bridge interfaces on both devices - LAN brigde and TV bridge. I was trying to create trunk port (lan1 port on Omnia and eth0 and MOX ). I tried multiple configuration from OpenWrt forums but every time port on MOX do not went up. My wish is to avoid bridging VLANs. Do you have any tips?
Could you share your firewall and network configs?
I am using 5 different firewall zones/VLANs on different trunk ports since years without issues.
Yes, sure. Here are configuration which I tried to implement.
Turris Omina
Network
config interface 'loopback'
	option device 'lo'
	option proto 'static'
	option ipaddr '127.0.0.1'
	option netmask '255.0.0.0'
config globals 'globals'
	option ula_prefix 'fd45:6486:874d::/48'
# LAN
config device
	option name 'lan1.99'
	option type '8021q'
	list ports 'lan1'
	option vid '99'
config interface 'lan'
	option ip6assign '60'
	option ip6ifaceid 'eui64'
	option _turris_mode 'managed'
	list ipaddr '192.168.99.1/24'
	option device 'br-lan'
config device 'br_lan'
	option name 'br-lan'
	option type 'bridge'
	list ports 'lan1.99'
	list ports 'lan2'
	list ports 'lan3'
# WAN
config interface 'wan'
	option device 'eth2'
	option proto 'dhcp'
	option ipv6 '0'
config interface 'wan6'
	option device '@wan'
	option proto 'none'
config device 'dev_wan'
	option name 'eth2'
# IOT
config interface 'iot'
	option ipaddr '192.168.88.1'
	option device 'br-iot'
config device
	option name 'lan0'
	option mtu '1500'
config device
	option name 'br-iot'
	option mtu '1500'
	option bridge_empty '1'
	option ipv6 '0'
	list ports 'lan0'
# TV
config device
	option name 'lan1.15'
	option type '8021q'
	option vid '15'
	list ports 'lan1'
config interface 'TV'
	option proto 'none'
	option device 'br-tv'
config device
	option name 'br-tv'
	list ports 'lan4'
	list ports 'lan1.15'
and firewall
config defaults
	option input 'ACCEPT'
	option output 'ACCEPT'
	option forward 'REJECT'
	option synflood_protect '1'
config zone
	option name 'lan'
	option forward 'ACCEPT'
	list network 'lan'
config zone
	option name 'wan'
	option input 'REJECT'
	option masq '1'
	option mtu_fix '1'
	option sentinel_fwlogs '1'
	list network 'wan'
	list network 'wan6'
config forwarding
	option src 'lan'
	option dest 'wan'
config rule
	option name 'Allow-DHCP-Renew'
	option src 'wan'
	option proto 'udp'
	option dest_port '68'
	option target 'ACCEPT'
	option family 'ipv4'
config rule
	option name 'Allow-Ping'
	option src 'wan'
	option proto 'icmp'
	option icmp_type 'echo-request'
config rule
	option name 'Allow-IGMP'
	option src 'wan'
	option proto 'igmp'
config rule
	option name 'Allow-DHCPv6'
	option src 'wan'
	option proto 'udp'
	option dest_port '546'
	option family 'ipv6'
config rule
	option name 'Allow-MLD'
	option src 'wan'
	option proto 'icmp'
	option src_ip 'fe80::/10'
	list icmp_type '130/0'
	list icmp_type '131/0'
	list icmp_type '132/0'
	list icmp_type '143/0'
config rule
	option name 'Allow-ICMPv6-Input'
	option src 'wan'
	option proto 'icmp'
	list icmp_type 'echo-request'
	list icmp_type 'echo-reply'
	list icmp_type 'destination-unreachable'
	list icmp_type 'packet-too-big'
	list icmp_type 'time-exceeded'
	list icmp_type 'bad-header'
	list icmp_type 'unknown-header-type'
	list icmp_type 'router-solicitation'
	list icmp_type 'neighbour-solicitation'
	list icmp_type 'router-advertisement'
	list icmp_type 'neighbour-advertisement'
	option limit '1000/sec'
config rule
	option name 'Allow-ICMPv6-Forward'
	option src 'wan'
	option dest '*'
	option proto 'icmp'
config rule
	option name 'Allow-IPSec-ESP'
	option src 'wan'
	option dest 'lan'
	option proto 'esp'
config rule
	option name 'Allow-ISAKMP'
	option src 'wan'
	option dest 'lan'
	option dest_port '500'
	option proto 'udp'
config rule 'wan_ssh_turris_rule'
	option name 'wan_ssh_turris_rule'
	option enabled '0'
	option dest_port '22'
	option proto 'tcp'
	option src 'wan'
config rule 'wan_http_turris_rule'
	option name 'wan_http_turris_rule'
	option enabled '0'
	option dest_port '80'
	option proto 'tcp'
	option src 'wan'
config rule 'wan_https_turris_rule'
	option name 'wan_https_turris_rule'
	option enabled '0'
	option dest_port '443'
	option proto 'tcp'
	option src 'wan'
config rule 'turris_wan_6in4_rule'
	option enabled '0'
config rule 'turris_wan_6to4_rule'
	option enabled '0'
config zone
	option name 'iot'
	list device 'lan0'
	list network 'iot'
config forwarding
	option dest 'lan'
	option src 'iot'
config forwarding
	option dest 'wan'
	option src 'iot'
config forwarding
	option dest 'iot'
	option src 'lan'
config include 'sentinel_firewall'
	option type 'script'
	option path '/usr/libexec/sentinel/firewall.sh'
And here is Turris MOX
Network
	option device 'lo'
	option ula_prefix 'fd92:3810:cb8d::/48'
# LAN
config device
	option name 'eth0.99'
	option type '8021q'
	option ifname 'eth0'
	option vid '99'
config device
	list ports 'eth0.99'
	list ports 'lan1'
	list ports 'lan2'
	list ports 'lan3'
	option ipaddr '192.168.99.2'
	option gateway '192.168.99.1'
# TV
config device
	option name 'eth0.15'
	option type '8021q'
	option vid '15'
	option proto 'none'
and firewall
config defaults
config include
	option path '/etc/firewall.user'
	option enabled '0'
	option enabled '0'
Without going into details and just from having a quick look: delete all those config parts:
config device
	option type '8021q'
	list ports 'lan1'
	option vid '99'
It is enough to define the VID implicitly in the bridge via
Due to some unsolved DSA bug the traffic will go anyways via CPU and therefore there will be no hardware offloading (for which any additional config details might be needed).
Apply this to all of your config and you should be fine.
Regarding non-lan interfaces: you will need some traffic rules that allow access to dhcp (ports 67-68) on lan interface.
Regarding MOX: do you use it as dump access point? If yes, you may disable firewall (+dnsmasq + odhcp) as Omnia is doing all those already.
It works! Thanks for your advice :wink:
