Hello, I did a factory reset on omni 2020. After restart it upgraded to TurrisOS 6.2.4 kernel 5.15.94
I set IP for LAN as ‘computer’, otherwise, I can’t set de default gateway to my existing router.
With this fresh install, I wanted to set-up VLANs and I experienced issues.
In the Luci → network → Interfaces → Devices tab, I selected ‘br-lan’ ‘configure’ then tab ‘Bridge Valn filtering’
I selected ‘enable vlan filtering’ and I added a Vlan.
I then had the 1st issue: when selecting ‘save’ nothing occurred on screen / no confirmation, no error mentioned, and the configuration window stayed in front
The only way to return to original menu is to click ‘dismiss’
Then the 2nd issue occurred: the little bar on the top right indicated ‘refreshing’ (as we would expect when no change is save) and when clicking ‘save and apply’ nothing happened (as exped). But, when I clicked ‘reset’ on the device, many changes then appeared in the top right little bar, and looking into it, I can see the provision for the creation of the VLAN as many times as I clicked save when I was in the device configuration window!
So changes were stored somewhere but not available and then made available…
Then 3rd issue appeared: if I click ‘save and apply’, the VLAN is created but the ‘br-lan’ is reset (not unexpected given that I clicked on ‘reset’ to make the changes appeared).
Such confg is off course unstable and I had to reset to do a hard factory reset again…
I tried multiple times, with similar results (unable to create VLAN and had to do factory reset again).
Why is my initial ‘save’ doing such a weird behavior?
Am I doing something wrong and/or is it a bug?
If it is a feature, such behaviour is so counterintuitive…
