After upgrading to TurrisOS 4.0.3 on an Omnia NAS, transmission is no longer working. The LuCI config page looks ok, but the transmission daemon is not running at all. If I try to start it from the command line with /etc/init.d/transmission start, i get the following error in /var/log/messages:
Jan 13 15:50:22 asgard transmission: Starting with 1033992000 virt mem
Jan 13 15:50:22 asgard : jail: not root, aborting: No error information
Jan 13 15:50:22 asgard transmission-daemon[31937]: jail: not root, aborting: No error information
I tried to remove the config files and directory, and re-install. Transmission wouldn’t start either from the init script or LuCI, and the error (from init script) stays the same. Upon further investigation - the config directory gets created after starting the init script, and running transmission-daemon -g /tmp/transmission/ manually worked.
Finally, it turned out the problem was in the (experimental) seccomp hardening packages. I didn’t get far trying to solve the problem, and ended up removing the hardening packages (through Foris) - now transmission works.
Should I file a bug about the seccomp issue somewhere? (I’m on 4.0.3, HBS)
