TOS container DCHP from host?
In the container set
config interface 'lan'
	option ifname 'eth0 eth2'
	option force_link '1'
	option type 'bridge'
	option proto 'dhcp'
is not producing an ip for the container but this
notice netifd[]: test (655): udhcpc: sending discover
warning kernel[]: [11808.281144] br-lan: received packet on eth0 with own address as source address
What I am missing?
It is rather odd that the TOS guest comes with the exact same mac and ip as the host, as in vanilla.
And since lxc.network.hwaddr = in the container config is not honoured it will naturally cause issues in the network department.
Since the network file in /etc/conf is not present prior the first boot of the guest the settings can thus only be altered thereafter, assuming that also any attempt of placing a file prior would be futile as being overwritten by the guest’s boot script.
Those settings in the guest then got the connectivity working.
	option proto 'dhcp'
	option macaddr 'D8:58:D7:00:87:5A'
	# option ipaddr '192.168.1.1'
	# option netmask '255.255.255.0'
	# option ip6assign '60'
