# Required information
* Distribution: Gentoo
* Distribution version: roll…ing/latest
* The output of
* `lxc-start --version`
`4.0.10`
* `lxc-checkconfig`
LXC version 4.0.10
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup namespace: enabled
Cgroup v1 mount points:
/sys/fs/cgroup/openrc
/sys/fs/cgroup/cpuset
/sys/fs/cgroup/cpu
/sys/fs/cgroup/cpuacct
/sys/fs/cgroup/blkio
/sys/fs/cgroup/memory
/sys/fs/cgroup/devices
/sys/fs/cgroup/freezer
/sys/fs/cgroup/net_cls
/sys/fs/cgroup/perf_event
/sys/fs/cgroup/net_prio
/sys/fs/cgroup/hugetlb
/sys/fs/cgroup/pids
/sys/fs/cgroup/rdma
Cgroup v2 mount points:
/sys/fs/cgroup/unified
Cgroup v1 systemd controller: missing
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup memory controller: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled, loaded
Macvlan: enabled, not loaded
Vlan: enabled, loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, loaded
CONFIG_NF_NAT_IPV4: missing
CONFIG_NF_NAT_IPV6: missing
CONFIG_IP_NF_TARGET_MASQUERADE: enabled, not loaded
CONFIG_IP6_NF_TARGET_MASQUERADE: enabled, not loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
CONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, not loaded
FUSE (for use with lxcfs): enabled, not loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:
Note : Before booting a new kernel, you can check its configuration
usage : CONFIG=/path/to/config /usr/bin/lxc-checkconfig
* `uname -a`
`Linux ###### 5.10.52-gentoo-x86_64 #3 SMP Sat Jul 31 17:53:47 EDT 2021 x86_64 Intel(R) Core(TM) i7-8559U CPU @ 2.70GHz GenuineIntel GNU/Linux`
* `cat /proc/self/cgroup`
14:rdma:/
13:pids:/
12:hugetlb:/
11:net_prio:/
10:perf_event:/
9:net_cls:/
8:freezer:/
7:devices:/
6:memory:/
5:blkio:/
4:cpuacct:/
3:cpu:/
2:cpuset:/
1:name=openrc:/sshd
0::/sshd
* `cat /proc/1/mounts`
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
devtmpfs /dev devtmpfs rw,nosuid,size=10240k,nr_inodes=4090858,mode=755,inode64 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev,noexec,inode64 0 0
tmpfs /run tmpfs rw,nosuid,nodev,noexec,mode=755,inode64 0 0
/dev/sdb2 / btrfs rw,noatime,compress=lzo,ssd,space_cache,autodefrag,subvolid=5,subvol=/ 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
selinuxfs /sys/fs/selinux selinuxfs rw,relatime 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
efivarfs /sys/firmware/efi/efivars efivarfs rw,nosuid,nodev,noexec,relatime 0 0
cgroup_root /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,relatime,size=10240k,mode=755,inode64 0 0
openrc /sys/fs/cgroup/openrc cgroup rw,nosuid,nodev,noexec,relatime,release_agent=/lib/rc/sh/cgroup-release-agent.sh,name=openrc 0 0
none /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0
cpuset /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
cpu /sys/fs/cgroup/cpu cgroup rw,nosuid,nodev,noexec,relatime,cpu 0 0
cpuacct /sys/fs/cgroup/cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct 0 0
blkio /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
memory /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
devices /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
freezer /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
net_cls /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0
perf_event /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
net_prio /sys/fs/cgroup/net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_prio 0 0
hugetlb /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0
pids /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
rdma /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0
mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
# Issue description
$ lxc-start dev --foreground
lxc-start: dev: utils.c: safe_mount: 1198 Operation not permitted - Failed to mount "(null)" onto "/var/lib/lxc/rootfs/sys/devices/virtual/net"
lxc-start: dev: conf.c: lxc_mount_auto_mounts: 801 Operation not permitted - Failed to mount "(null)" on "/var/lib/lxc/rootfs/sys/devices/virtual/net" with flags 46
lxc-start: dev: conf.c: lxc_setup: 4094 Failed to setup first automatic mounts
lxc-start: dev: start.c: do_start: 1291 Failed to setup container "dev"
lxc-start: dev: sync.c: sync_wait: 36 An error occurred in another process (expected sequence number 3)
lxc-start: dev: start.c: __lxc_start: 2053 Failed to spawn container "dev"
lxc-start: dev: tools/lxc_start.c: main: 308 The container failed to start
lxc-start: dev: tools/lxc_start.c: main: 313 Additional information can be obtained by setting the --logfile and --logpriority options
# Steps to reproduce
1. Upgrading Gentoo package `app-emulation/lxc` from version `4.0.9-r1` to `4.0.10`
2. `lxc-start dev --foreground`
3. See the console output
# Information to attach
- [ ] any relevant kernel output (`dmesg`)
- [ ] container log (The <log> file from running `lxc-start -n <c> -l TRACE -o <logfile> `)
- [ ] the containers configuration file
