I have a problem that after a reboot 2 of my firewall rules that redirect incoming traffic on port 80 & 443 to nginx are not loaded (dunno why, seems to be a bug in the firewall)
I tried with a simple “/etc/init.d/firewall restart” after booting but that doesn’t help. I have to go to luci and have to disable the rules. Then save&apply. Enable the rules and again glick on save&apply then the rules start working.
so I started scripting this like this:
#/bin/bash
uci set firewall.wan_http_turris_rule.enabled='0'
uci set firewall.wan_https_turris_rule.enabled='0'
uci commit firewall
/etc/init.d/firewall restart >/dev/null
sleep 1
uci set firewall.wan_http_turris_rule.enabled='1'
uci set firewall.wan_https_turris_rule.enabled='1'
uci commit firewall
But that does not do the trick. The rules are still not working.
I can confirm that disabling & enabling the rules works I I execute just the uci commands and check their status in luci.
But “save&apply” does not seems to a simple combination of “uci commit” and “/etc/init.d/firewall restart” there must be something different that is beeing done in luci that I’m missing.
Does anbody maybe the devs know what exactly “save&apply” is doing in terms of shell commands as I’m out of ideas why the script does not have the same effect.
