I’m trying to set up my TO again after a clean medkit install of 5.0.1 installation from scratch. My network setup is as described here:
https://openwrt.org/docs/guide-user/network/wifi/dumbap
Basically I’m using my ISPs router box for Internet access and DHCP. The TO should be a client in the LAN and a WIFI access point. Everything works fine after setting up the network bridge for wired clients. WLAN clients however do not get an IP assigned. Manually assigning one works. So the network bridge is forwarding packages.
Per the instructions I disabled the firewall, odhcp and dnsmasq services.
What am I missing here? This setup worked under TO 3.x before…
from /etc/config/network:
config interface 'lan'
option type 'bridge'
option proto 'static'
option bridge_empty '1'
option ipaddr '192.168.128.2'
option _turris_mode 'unmanaged'
option gateway '192.168.128.1'
list dns '192.168.128.1'
list ifname 'lan0'
list ifname 'lan1'
list ifname 'lan2'
list ifname 'lan3'
list ifname 'lan4'
and from /etc/config/wireless:
config wifi-device 'radio0'
option type 'mac80211'
option macaddr '04:f0:21:24:0e:6e'
option country 'DE'
option disabled '0'
option legacy_rates '0'
option hwmode '11a'
option htmode 'VHT40'
option channel 'auto'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'foobar'
option disabled '0'
option encryption 'psk2+ccmp'
option wpa_group_rekey '86400'
option key 'redacted'
