I’m getting email notifications of this error on my Turris Omni 5.3.0 router.
Error notifications
Updater failed:
[string "transaction"]:327: [string "transaction"]:151: Collisions:
• /usr/sbin/tcpdump: tcpdump-mini (existing-file), tcpdump (new-file)
Good question. I didn’t do anything to install it. Just started getting the emails out of the blue. No updates shows up on the web UI either.
Is there something I can run via SSH to remove the package or list what dependency is causing it to get installed?
yes, in Luci. goto system > software > update lists > search for tcpdump-mini > go to ‘installed’ and remove it ?
btw, me think this tcpdump-mini was used for adblock, but does work without.
I think you are right. I may have recently removed the Adblock LuCI extension. Perhaps that is the root cause of the bug. A dangling dependency?
Ok, removed tcpdump-mini
version 4.9.3-2 using the LuCI package manager. I’ll report back if I get any more update error email notifications.
system
Closed
7
