Zmigroval se mi T 1.0. Vse vypada ze jede krome 5GHz AC site na Qualcomm Atheros QCA9880 802.11bgnac
Device mi pise not active, restart nepomaha, zkusil jsem sit smazat a vytvorit znova, ale bez uspechu.
Log (je nomalni,ze kernel je o hodinu posunuty?)
Jan 17 20:04:46 turris hostapd: Configuration file: /var/run/hostapd-phy0.conf
Jan 17 21:04:47 turris kernel: [1164259.084080] ath10k_pci a000:05:00.0: pdev param 0 not supported by firmware
Jan 17 21:04:47 turris kernel: [1164259.105302] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 17 20:04:47 turris hostapd: wlan0: INTERFACE-ENABLED
Jan 17 20:04:47 turris hostapd: wlan0: INTERFACE-DISABLED
Jan 17 20:04:47 turris hostapd: nl80211: Could not configure driver mode
Jan 17 20:04:47 turris hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Jan 17 20:04:47 turris hostapd: nl80211 driver initialization failed.
Jan 17 20:04:47 turris hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Jan 17 20:04:47 turris hostapd: wlan0: AP-DISABLED
Jan 17 20:04:47 turris hostapd: wlan0: CTRL-EVENT-TERMINATING
Jan 17 20:04:47 turris hostapd: hostapd_free_hapd_data: Interface wlan0 wasnât started
Jan 17 20:04:47 turris netifd: radio2 (30227): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 9870 path ()
Jan 17 20:04:47 turris netifd: radio2 (30227): Device setup failed: HOSTAPD_START_FAILED
driver=nl80211
logger_syslog=127
logger_syslog_level=2
logger_stdout=127
logger_stdout_level=2
hw_mode=a
beacon_int=100
channel=100tx_queue_data2_burst=2.0
ieee80211n=1
ht_coex=0
ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-79 35][DSSS_CCK-40]
vht_oper_chwidth=1
vht_oper_centr_freq_seg0_idx=106
ieee80211ac=1
vht_capab=[RXLDPC][SHORT-GI-80][TX-STBC-2BY1][RX-ANTENNA-PATTERN][TX-ANTENNA-PAT TERN][RX-STBC-1][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7]interface=wlan0
ctrl_interface=/var/run/hostapd
ap_isolate=1
bss_load_update_period=60
chan_util_avg_period=600
disassoc_low_ack=1
preamble=1
wmm_enabled=1
ignore_broadcast_ssid=0
uapsd_advertisement_enabled=1
utf8_ssid=1
multi_ap=0
wpa_passphrase=HESLO_SITE
auth_algs=1
wpa=2
wpa_pairwise=CCMP
ssid=JMENO_SITE
bridge=br-lan
wpa_disable_eapol_key_retries=0
wpa_key_mgmt=WPA-PSK
okc=0
disable_pmksa_caching=1
bssid=xx:xx:xxâŠ
/etc/config/wireless
config wifi-device âradio0â
option type âmac80211â
option path âffe09000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0â
list ht_capab âLDPCâ
list ht_capab âSHORT-GI-20â
list ht_capab âSHORT-GI-40â
list ht_capab âTX-STBCâ
list ht_capab âRX-STBC1â
list ht_capab âDSSS_CCK-40â
option country âCZâ
option disabled â0â
option hwmode â11aâ
option htmode âVHT80â
option channel â120âconfig wifi-device âradio1â
option country âCZâ
option hwmode â11gâ
option txpower â18â
option htmode âHT40â
option disabled â0â
option channel â11â
option macaddr â60:02:b4:7d:88:95âconfig wifi-iface âwifinet1â
option device âradio1â
option network âlanâ
option mode âapâ
option ssid âJINA_SITâ
option key âJINY_HESLOâ
option disabled â0â
option encryption âpsk2+tkip+aesâconfig wifi-device âradio2â
option hwmode â11aâ
option channel â100â
option macaddr â04:f0:21:22:8f:21â
option legacy_rates â0â
option country âCZâconfig wifi-iface âguest_iface_0â
option disabled â1âconfig wifi-iface âguest_iface_1â
option disabled â1âconfig wifi-iface âwifinet3â
option ssid âJMENO_SITEâ
option encryption âpsk2â
option device âradio2â
option mode âapâ
option key âHESLO_SITEâ
