I have two Omnia routers, two networks. I want to keep their settings in sync? When I change something in one of them, it will change on another one as well. Or maybe one-way sync would be enough.
Any suggestions? Thanks.
Funny - we both had similiar idea in same time-span … have seen your thread just today, when I posted my little “general-password” idea.
isn’t that excelent usecase for Ansible?
Any working examples please? Or is someone willing to share his setup with me? Thanks.
at your workstation, install ansible:
pip3 install --user ansible
create some play
$ cat helloworld.yaml
- name: HelloWorld
hosts: turris
tasks:
- name: Create a file
copy:
content: hello worldn
dest: /tmp/testfile.txt
create inventory with your routers:
$ cat inventory.yaml
all:
children:
infrastructure:
hosts:
turris:
ansible_python_interpreter: /usr/bin/python
run the play with the given inventory
$ ansible-playbook -i ./inventory.yaml ./helloworld.yaml
PLAY [HelloWorld] *****************************************************************************************************************************************************************************************************************************************************************************************************
TASK [Gathering Facts] ************************************************************************************************************************************************************************************************************************************************************************************************
ok: [turris]
TASK [Create a file] **************************************************************************************************************************************************************************************************************************************************************************************************
ok: [turris]
PLAY RECAP ************************************************************************************************************************************************************************************************************************************************************************************************************
turris : ok=2 changed=0 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
I qlso thought about ansible. But I think writing playbooks for changing one setting with ad-hoc commands is a big overkill. Unless you want to have your setup stored in a way so its easily replicable from scratch.
I also have two Omnias and I use ansible but not for configuring routers. Overkill. Maybe when ansible gets more developed and will support openwrt with some modules it woukd make more sense to use it.
