I want to use the Turris Omnia 2GB as a NAS/switch and application server (IOT, VPN, …) instead as a router. I’m unsuccessful in configuring the switch/VLAN and interfaces. What I tried so far:
WAN/WAN6 deleted
br-LAN DHCP-client mode or static mode:
IPv4-address: 192.168.100.2
IPv4-Gateway: 192.168.100.1
IPv4-DNS-Server: 192.168.100.1
IPv4-broadcast: 192.168.100.255
disable VLAN, eth0 only for LAN
disable VLAN, eth0 + eth1 for br-LAN
delete VLAN2, add untagged PORT4 to VLAN 1, use eth0.1 and eth1 for br-LAN
In static mode the IP-address is not reachable. In DHCP-client mode there is no DHCP-request to the router (AVM Fritz!Box 7490).
The goal is to have a 6-port switch with a IPv4/IPv6 bridge-interface with static IP-adresses. Eventually I’ll add tap devices for encapsulation and VPN.
I tried to configure the Turris Omnia about 20 times with different VLAN/switch/Interface settings but couldn’t get it working as 6-port switch. Every time I did a ‘Rollback to factory reset’ before (reset with 3 LEDs active).
TurrisOS is MedKit latest downloaded on thursday.
I also selected “Disable DHCP server on network device” as DHCP is provided by the Fritz!Box.
Does TurrisOS do any filtering in the bridge device?
Hello I have a multiple link(two Cable connect on flat switch…i want to separate one of the link connection to avoid looping of traffic…i want to use vlan on the switch that can communicate from one switch to another switch without affecting the other link…purpose of this is failover…please need help
If your switches support the Spanning Tree protocol, you can connect everything as you like and the Spanning Tree protocol will make sure there are no loops. It has to be enabled on all ports in your wiring with possible loops.
