Stuck on nextcloud and samba
Hi everyone,
my Turris omnia has been running happily now for a long time, although I think there was some initial tweaking to get it to run, though IPv6 isn’t running, which I blame on the provider but might be my fault after all.
I am in Germany, on a providers cable router that is set to bridge mode.
Now I wanted to become the hero of the family and get us a sharing network drive. Installing the ssd and going through the reforis storage-module was fun, but since that I have turned into an ill-tempered wretch. Maybe one of you can help me.
What I’ve failed at so far:
  • install nextcloud as suggested in the forums - can’t see the additional apps to install because of a curl error (61 I think it was, but I did not attempt to rebuild curl as suggested on https://github.com/nextcloud/server/issues/24136). But I fail to resolve the issue.
    Nextcloud is usable though, but there seems to be an issue. and we really just need a drive to have our files accessible from every computer in the flat. So instead of a half-broken nextcould, I went for my next fail:
  • set up samba as detailed in the forums - restarting the samba daemon generates the following error log:
    INTERNAL ERROR: open_sockets_smbd() failed in pid 25222 (4.18.8).
    smbclient -L localhost on the turris also returns a happy “no network interfaces found”
Usually I manage to solve my problems surfing the web and forums - thank you all. But this time I am so stuck, I am even having trouble catching all the forum addresses that I’ve visited.
And some of the posts seem relevant, but I am wondering whether following the hints for older samba-versions as in https://forum.turris.cz/t/failing-to-set-up-smb-samba/12862/17 would help
Does anyone have a hint towards how I could get the samba-share to work, or which settings I could’ve messed up on the way to my miconfiguration?
I am currently running TurrisOS 7.0.3.
Any thoughts are greatly appreciated
my approach will be … (and it is like try & error excercise)
  1. I would check from logs which machine act as master.
  • so i know which machine is responsible for sec.level, which dialect is used and such …
  • i would ensure that turris is the winner of election for samba master
  1. Then i would change the security level.
  • or even try guest access
  • or vice versa force to use some account
  1. You can change the min/max protocol version or dialect, to ensuire all clients are able to talk to samba master machine.
  • some clients are not able to use smb2 latest dialect.
  • while you can have some windows10/11 wining the election for master and they require lastest version/dialect to be used.
  • if there is windows machine acting as master, there might be need to
    – to change configuration in “sharing” section
    – to change some rules on firewall
Also when i was playing with this stuff, i found that after changing the smb.conf and restarting the service, time to time i found that new setup was not applied or was rejected (like actual master was still acting —> so in that case it is good to bounce also that client/server which is actual/acting samba master, just to ensure turris will won the election :D)
Not sure if this will helps, but you know samba implementation on non-win machines is not perfect. For me to even make it working in my network was pain-in-the-a** , that’s why i posted those notes, i know many users struggle with it.
