I cannot ssh into the router.
I’ve tried resetting the router. I have the root password setup. I’ve deleted /etc/ssh
and restarted the sshd
. This is the output from ssh root@192.168.1.1 -v
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n 7 Dec 2017
debug1: Reading configuration data /home/naturgewalt/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 192.168.1.1 [192.168.1.1] port 22.
debug1: Connection established.
debug1: identity file /home/naturgewalt/.ssh/id_rsa type 0
debug1: key_load_public: No such file or directory
debug1: identity file /home/naturgewalt/.ssh/id_rsa-cert type -1
debug1: identity file /home/naturgewalt/.ssh/id_dsa type -1
debug1: identity file /home/naturgewalt/.ssh/id_dsa-cert type -1
debug1: identity file /home/naturgewalt/.ssh/id_ecdsa type -1
debug1: identity file /home/naturgewalt/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/naturgewalt/.ssh/id_ed25519 type 3
debug1: identity file /home/naturgewalt/.ssh/id_ed25519-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.9
debug1: match: OpenSSH_7.9 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.1.1:22 as 'root'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:MXTTEcEAmhZ3IdJ3jZAp2o0Lpugc5UloORljx5+seVk
The authenticity of host '192.168.1.1 (192.168.1.1)' can't be established.
ECDSA key fingerprint is SHA256:MXTTEcEAmhZ3IdJ3jZAp2o0Lpugc5UloORljx5+seVk.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.1' (ECDSA) to the list of known hosts.
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password,keyboard-interactive
debug1: Next authentication method: publickey
debug1: Offering public key: ED25519 SHA256:WgZq6Wlgl2JWVbmSxWA3SpyRV5yEi6qcLUi5GgJrJZ8 /home/naturgewalt/.ssh/id_ed25519
debug1: Offering public key: RSA SHA256:krFlr06pGf+h/gCkFxqUjD7Rt32cw3DJFw9+kPhmoVk /home/naturgewalt/.ssh/id_rsa
debug1: Offering public key: ED25519 SHA256:yEo5KrJgMxeyWg6LNYb8SPwgc0pnf/CVN95muK9fRh4 jan-jan.vandervyver@nearform.com
debug1: Offering public key: RSA SHA256:uhs4RUHB3ny2K5p30c4dS6TZrsU6ThnYXnKIeVRfmGc iibtrih@Jan-Jans-MacBook-Pro.local
debug1: Offering public key: RSA SHA256:zcj4/mXUQ/k25zZSdWvq1loVnsYYTrcUZS6OdEou+RA jan-jan@jan-jans-mbp.parallel
debug1: Trying private key: /home/naturgewalt/.ssh/id_dsa
debug1: Trying private key: /home/naturgewalt/.ssh/id_ecdsa
debug1: Next authentication method: keyboard-interactive
Received disconnect from 192.168.1.1 port 22:2: Too many authentication failures
Disconnected from 192.168.1.1 port 22
