Hello together,
with my previous router I had the ability to SSH from one network client to another while simply addressing its hostname.
Example:
$ ssh username@hostname
However, since using the Omnia this does not work anymore. It seems I am now forced to use the IP address of the target client instead of simply using its hostname:
$ ssh username@192.168.1.222
Is there an option to enable SSH via hostnames again? Even accessing the Omnia itself does not work with its hostname:
$ ssh root@turris
Instead I have to use…
$ ssh root@192.168.1.1
Can I change this behavior, so I can use hostnames again?
