I need to shape traffic for OpenVPN clients. I’ve added new queue (Network -> SQM QoS) on tun0 (set upload/download 5000/5000), but clients have full bandwidth.
thanks
thanks
I assume you try to restart SQM service? check also /etc/config/sqm
Could you post the output of the following commands please:
cat /etc/config/sqm
tc -d qdisc
SQM_DEBUG=1 SQM_VERBOSITY_MAX=8 /etc/init.d/sqm stop ; SQM_DEBUG=1 SQM_VERBOSITY_MAX=8 /etc/init.d/sqm start
Thanks.
Sorry, thanks for your help, but I thought Save & Apply means Save & Apply in LuCI.
After /etc/init.d/sqm restart
it works!
It should and generally does. But if it works now you should be fine?
Best Regards
Yes, it works and I am fine thanks
