There’s some significant CPU usage in softirqs when the test is running with SQM enabled (up to 40%). Not sure if it’s related or not. The rest is mostly idle.
First: PEBKAC, though, because the WAN interface changed in 5.x, it is now eth2
instead of eth1
. After changing that it is better, but I still go down to ~500Mbps from ~900.
Reports with SQM disabled : Bufferbloat Test by Waveform
Reports with SQM enabled: Bufferbloat Test by Waveform
ifstatus wan
"up": true,
"pending": false,
"available": true,
"autostart": true,
"dynamic": false,
"uptime": 10069,
"l3_device": "eth2",
"proto": "dhcp",
"device": "eth2",
"updated": [
"addresses",
"routes",
"data"
"metric": 0,
"dns_metric": 0,
"delegation": true,
"ipv4-address": [
"address": "192.168.1.138",
"mask": 24
"ipv6-address": [
"ipv6-prefix": [
"ipv6-prefix-assignment": [
"route": [
"target": "0.0.0.0",
"mask": 0,
"nexthop": "192.168.1.254",
"source": "192.168.1.138/32"
"dns-server": [
"192.168.1.254"
"dns-search": [
"neighbors": [
"inactive": {
"ipv4-address": [
"ipv6-address": [
"route": [
"dns-server": [
"dns-search": [
"neighbors": [
"data": {
"leasetime": 86400
tc -s qdisc
qdisc noqueue 0: dev lo root refcnt 2
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
qdisc mq 0: dev eth0 root
Sent 826 bytes 7 pkt (dropped 0, overlimits 0 requeues 0)
qdisc fq_codel 0: dev eth0 parent :8 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
maxpacket 0 drop_overlimit 0 new_flow_count 0 ecn_mark 0
new_flows_len 0 old_flows_len 0
qdisc fq_codel 0: dev eth0 parent :7 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :6 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :5 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc mq 0: dev eth1 root
Sent 9399397671 bytes 9158632 pkt (dropped 1, overlimits 0 requeues 14832)
backlog 0b 0p requeues 14832
qdisc fq_codel 0: dev eth1 parent :8 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :7 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :6 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :5 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
maxpacket 27396 drop_overlimit 0 new_flow_count 44604 ecn_mark 0
qdisc cake 801d: dev eth2 root refcnt 9 bandwidth 190Mbit besteffort dual-srchost nat nowash no-ack-filter split-gso rtt 100.0ms raw overhead 0
Sent 738197840 bytes 1042889 pkt (dropped 239, overlimits 1428895 requeues 44)
backlog 0b 0p requeues 44
memory used: 365056b of 9500000b
capacity estimate: 190Mbit
min/max network layer size: 42 / 1514
min/max overhead-adjusted size: 42 / 1514
average network hdr offset: 14
Tin 0
thresh 190Mbit
target 5.0ms
interval 100.0ms
pk_delay 44us
av_delay 31us
sp_delay 1us
backlog 0b
pkts 1043128
bytes 738545346
way_inds 1122
way_miss 170
way_cols 0
drops 239
marks 0
ack_drop 0
sp_flows 6
bk_flows 1
un_flows 0
max_len 1514
quantum 1514
qdisc ingress ffff: dev eth2 parent ffff:fff1 ----------------
Sent 2455180997 bytes 1861059 pkt (dropped 0, overlimits 0 requeues 0)
qdisc noqueue 0: dev lan0 root refcnt 2
qdisc noqueue 0: dev lan1 root refcnt 2
qdisc noqueue 0: dev lan2 root refcnt 2
qdisc noqueue 0: dev lan3 root refcnt 2
qdisc noqueue 0: dev lan4 root refcnt 2
qdisc noqueue 0: dev br-lan root refcnt 2
qdisc noqueue 0: dev wg0 root refcnt 2
qdisc noqueue 0: dev wg1 root refcnt 2
qdisc cake 801e: dev ifb4eth2 root refcnt 2 bandwidth 9500Mbit besteffort dual-dsthost nat wash no-ack-filter split-gso rtt 100.0ms raw overhead 0
Sent 2460654766 bytes 1821196 pkt (dropped 39863, overlimits 0 requeues 0)
memory used: 6998092b of 15140Kb
capacity estimate: 9500Mbit
min/max network layer size: 60 / 1514
min/max overhead-adjusted size: 60 / 1514
Tin 0
thresh 9500Mbit
target 5.0ms
interval 100.0ms
pk_delay 10us
av_delay 3us
sp_delay 2us
backlog 0b
pkts 1861059
bytes 2520990591
way_inds 1304
way_miss 167
way_cols 0
drops 39863
marks 0
ack_drop 0
sp_flows 5
bk_flows 1
un_flows 0
max_len 60560
quantum 1514
