i have about 100 static leases. Since they are not sorted by ip adr, but shown in the order i added them,it is confusing when adding a new dataset because i can not see at a glance if a ip addr. is already used.
Is there is possiblity to sort the static leases by IP addr.?
Sure it is.
You need to login via SSH and adjust /etc/config/dhcp to your needs.
But best option is to just assign the IP-address statically that has already been assigned dynamically from DHCP. As you do that IP-assigning only once and you afterwards don’t need to care about what IP has been assigned.
It only gets critical if you would need more than 254 static leases - in that case you would need IPv6
