[SOLVED] TurrisOS 7.0.3 Internet speed on MOX 70Mbit/s, on Omnia 860Mbit/s over 1Gbit downlink
Dear Members,
Recently Google Meet started complaining about internet problems during meetings, so I started investigating.
I have two 1Gbit links on my computer, one to my Turris MOX router, and one to my Turris Omnia router. They both are connected to the same Vodafone 1Gbit internet subscription through a router belonging to the internet provider.
My routers both run version 7.0.3 of TurrisOS.
I observed the following. If I only connect to the MOX device, my speedtests only achieve about 70 Mbit/s downlink, and 860 Mbit/s if I connect via the Omnia only.
I tried restarting the MOX, and re-test, but the reported speed stayed the same.
Now I was told that MOX is somewhat less capable than Omnia, but not this much.
Anyone has any ideas?
Best Regards,
János
Check your cable to MOX. Maybe it has only 2 pairs and thus 100Mb only. Or maybe your ethernet adapter is 100Mb only
I installed the cables, and I only used good quality ones. Also, the network adapters and devices that are used are all 1Gbit/s.
But did you verify or is it something that you assume? That your cables are 4-pairs not 2-pair (whatever the quality)? Did you verify with ethtool that the speed negotiated between each interface is 1Gbps? And that your end adapter is for sure 1Gbps?
I have been using this unchanged setup for years, and the MOX router has produced at least 650 Mbit/s earlier. There haven’t been any changes in the cabling recently. And ethtool shows 1Gbit/s link speed everywhere along the network path.
Ok so it was working before. Make a snapshot of current state and try to roll back to some previous update and see if it helps.
Okay, I tried rolling back to several older snapshots, but the speeds were consistently low. I will try to debug things further.
had a similar problem with MOX
and the issue was the inner bus for connecting modules
cleaning the connectors helped sometimes
Thanks for the idea, I will try it when I’ll have some time, but right now, I’m pretty low on that, and also, people are using the router all the time during my active hours.
After some further testing I managed to identify the culprit: I have two USB4 ports on my laptop, and use one of them to charge my laptop, and at the same time drive two 4K displays via displayport alt mode, plus it also has a USB hub for devices, and also a USB-based ethernet adapter built-in.
Traffic was going through the USB-based ethernet adapter in the display, and probably the USB4 link got a bit congested with traffic, hence the slow throughput.
When I used a dedicated USB-based gigabit ethernet adapter, plugged to the second USB4, to connect to the switch leading to the MOX router, the transfer speeds returned to realistic levels.
