(Solved) Turris OS 7.0 Packet manager not working anymore
Hello all,
I am new to Turris OS, I bought a used Turris Omnia with a 256 GB MSATA
and two WiFi cards pre-installed. The first owner was so friendly and installed
Turris OS 7.0 fresh for me on the mSATA and set up that the Turris Omnia is
booting only from there. I was running through the “first install process” without
any issues and/or errors. In short all is running fine. I was able to look over the
Paket manager and saw something around 7000ish available packets in th repo.
But now after a while when I hit the refresh button (update list) I get an error
I can´t workaround and/or solve alone. Below are two images from the system
I run and from the error message. Perhaps someone can help me to get rid
of this error? It is in my eyes pointed to the signature files from the repo´s
or the repos itself are not matching to my (7.0) system, could this be?
  • How can I ensure to use the right matching repo´s according to my Turris OS 7.0?
  • How can I eventually renew or reload the signatures (or keys)?
Thanks in advance for your taken time and help
Here is the screenshot of the system I am running, perhaps this helps.
Solved, I was able to solve the problem, by setting up the new repo´s (HBS)
so it was easy to realise.
src/gz turrisos_core https://repo.turris.cz/**hbl**/omnia/packages/core
was changed against the following;
src/gz turrisos_core https://repo.turris.cz/**hbs**/omnia/packages/core
Known problem Opkg in stable 7.0.0 uses hbl instead of hbs
@bakuka
But was it wrong to use here the HBS? I am not using a mox I mean, I am using a
Turris Omnia and there fore it should be the HBS I thought, or am I wrong with
that thinking here? Would you be so friendly and enlighten me once more again.
I think I don´t got it really.
HBS is the general default (most stable). Docs: Early access - Turris Documentation
From there I have the info about HBS pr better owed on this documentation I was
changing against the HBL because I got there the shown above error message.
All in all can I use the HBS instead of the HBL without harming my system?
I’m quite sure that none of the branches should “harm” your system. They’re just a range of options between newest and most time-tested.
Ahhh, ok now I can sleep a bit better, thank you very much for clarifying this for me.
I got even errors and was not really sure about to swap over to this repository.
But from there it installs very fast and without any error.
  • fail2ban
  • CrowdSec
  • Netify Agent (netifyd)
It was running false free and will be configured this afternoon., together with Sentinel it is enough for my home network. Once more again to you both @bakuka and @vcunat thank you very much for the fast and accurate help here.
