I deployed Omnia at my home in default configuration and I immediately noticed that DNS lookups are substantially slower. When I visit a page for the first time, I can clearly see browser waiting for DNS resolution.
Sometimes I also experience that resolution fails when the host is apparently correctly spelled (and it is resolved by upstream server or 8.8.8.8). I tried to turn off DNSSEC, but with no help.
I am not using WAN interface at the moment, I use Omnia as DHCP/DNS/TFTP server and planning to connect fibre SFP later next year, but I don’t think this is relevant.
How do I fix this or remove Knot DNS from my Omnia?
You could try to turn off all other resolvers than dnsmasq, together with DNSSEC. Thats the standard situation in OpenWRT, and then compare, if slowness will be still there.
Thats also my plan to do, when I will setup Omnia, as I dont feel good about X resolvers there…
I know, technically you are right. And maybe I was wrong, when I think that kresd and knot are two different resolvers. But I mean, unbound, kresd, dnsmasq, all are there if I am not wrong?
Personally I dont know if Izaps delay is only because DNSSEC, but considering my assumption above, I think its good to try it.
Knot DNS is an authoritative DNS server, not resolver, those orthogonal functions are separated in different software projects (unlike say BIND, which combines both functions in one binary).
You are right that there is unbound installed as well, even though it’s not running in the default config. I guess it’s just a residue from the previous Turris generation.
To the slower resolution, I guess the reason is not the DNSSEC but doing the full recursion on the router. This could be fixed by configuring some upstream DNS servers and enabling DNS forwarding.
Thanks for explanation, I am learning something new whole life I would propose then get rid of unbound to prevent such misleading thinking.
I would closelly follow this topic, as I am interesting on your guessing solution (in case I will face the same problem). If I understand you correctly, there are need some knot configuration to give him better performance, as dnsmasq would have, if it would be used for DNS resolving, correct?
How do I set upstream servers and enable DNS forwarding in knot please? I can’t find a good documentation on that topic, particularly in the OpenWRT environment.
Ok I found out, since my WAN was not activated, I had no resolv.conf.auto file which is the source for Knot to enable forwarding. Therefore I created and enabled little script that deploys the missing file:
root@turris:~# cat /etc/init.d/google-resolver
#!/bin/sh /etc/rc.common
# REMOVE ME once WAN is activated
START=59
STOP=15
start() {
cat >/tmp/resolv.conf.auto <<EOF
domain home.lan
nameserver 8.8.8.8
nameserver 8.8.4.4
EOF
stop() {
true
You should put your upstream DNS servers instead 8.8.8.8 and 8.8.4.4, just in case someone do not get this.
Thanks, I edited the file, rebooted and “/tmp/resolv.conf.auto” is still empty. I see the entry in LuCI, tried to apply configuration without any success. What can be causing this?
@lzap I would be definitely interested in seeing kresd logs when run with -v and the resolution is slow - if you have a tad bit time to help debug this issue, this would be much appreciated.
Reproduced! Was scratching my head when Knot was still forwarding to my upstream DNS until I realized the config is generated by the init script. Here is the session:
www.fifa.com was loading a bit slow, it was like a second of “Resolving host…” browser message until it finally appeared.
Hope it helps. Big fat warning - in my case my WAN interface is DOWN, I use Turris as a DNS/DHCP/TFTP server for now. Also my version is 2GB - No Wifi, if that makes any difference. Other than that, no special configuration at the moment AFAIK.
Edit: Oh one more thing, I have added “hint” from /tmp/hosts/dhcp where I have 5 entries (gw.home.lan, turris.home.lan and few others).
Edit 2: My provider does not have IPv6 AFAIK, so this does not get routed properly. My laptop is Fedora 24 and it received IPv6 address properly, well I can ping turris via IPv6 but that’s all I am capable doing at the moment. Shame on me, I am not IPv6 early adopter.
Hmm, this is a problem we though we already solved (the fast timeout on IPv6 addresses when IPv6 is available only locally), but it seems that your setup triggers it again.
Adding net.ipv6=false to the config file should make the resolution to not try IPv6 first.
