I have a Turris Omnia router with automatic updates activated. I had to install few packages to get Omnia to connect at my bad fiber ISP here in france (Orange) including ip-full package.
For each update that router is doing it uninstalls that package (not the others one I had installed too): ip-full !! Why ? and how can I prevent that ? If router restarts without that package my Internet connection won’t work again !!
I looked in to this. And correct solution would be this for now:
Install("ip-full", {priority = 60})
Add this to file /etc/updater/user.lua
For long term solution I don’t see any reason why ip-full shouldn’t be installed out of the box so that will happen. And also I see now that every package we have in our lists should have lower than default 50 priority. So that will be in one of the future releases.
Adding it there I see little bit pointless as this will be obsoleted just with next minor release as I will do changes I described. For now having it on forum is enought I would say.
@cynerd Thanks for the help but unhappy it must have something wrong in your solution as when I applied it and run updater.sh it removed neardyl all packages of my router I had to cancel immediately the change and run updater again to get router back in a normal state
If it can help here is output after adding your solution in my router:
I couldn’t test it yesterday. I had no electric power at home. And I missed that ip-full doesn’t have field that it provides ip. Forcing ip-full installation this way causes all packages depending on ip to be uninstalled. I will fix that and I will push that to next fixup release. But because you have to wait for next fixup release I would suggest you to do your workaround, disable updater and watching forum for fixup release. I am sorry for this inconvenience but it’s a bug in OpenWRT package so we have to fix it in on our side.
Edit: Did you tried it without ip-full? I just encountered this commit https://gitlab.labs.nic.cz/turris/openwrt/commit/966912b2f369db23a4e278aa10ed6f4dbde9bbf2 during my investigation. It seems to me that you are trying to do something that one of my colleagues hacked year ago. Our package ip is same as ip-full so nobody uses ip-full. (Yes this is pretty nasty and I will change it but you shouldn’t have any problems with ip)
@cynerd No worries and I have done what you suggested. I have deactivated for now the automatic updater to prevent automatic removal of ip-full Any timeframe estimation when next fixup release will be done ? or way to know when it’ll be released ? so I know when I activate back automatic update
For ip package I prefer not to tweak too much system to avoid breaking my Internet connection too long time
I am not pressing fix to fixup because ip should be effectively ip-full at the moment so there should be no point in installing ip-full. But in next minor release (planned to be out to the end of this year) I will set ip-full as default package and ip will be renamed to ip-tiny. So because of that I would say you can try to play with it even now as I am sure that ip should be enough, there is no difference between those two packages effectively. And next fixup won’t change it for now.
@cynerd Sorry to go against you but these two packages are not the same !! If I remove ip-full from my router and reboot, my WAN access is no more working ! I put it back and reboot and voilà ! WAN back working So looks like my only option for now is to keep updates disabled to prevent router to remove package every six hours ?..
And if you are removing ip-full are you also reinstalling ip? Opkg is not checking commonly file collisions and this is common problem as ip executable is in both packages and removing ip-full removes that executable.
Thanks for clarification about how opkg orks So I removed ip-full package and force-reinstall of ip package, rebooted and voilà ! It works great so I got rid of ip-full package and reactivated data collection and statistics and automatic updates
