Hello together,
I am currently configuring my new Turris Omnia Wifi 6 in the same way as my previous OpenWRT router.
The Turris reForis GUI is completely new to me. So far I have only been using Luci in the past in OpenWRT.
The following points are not quite clear to me at the moment:
DHCP:
In OpenWRT (Luci) I have an option “DNS forwardings”. I cannot find this in Turris OS in the Luci GUI. But I guess this is the same as in reForis GUI under DNS right?
DNSSEC:
DNSSEC is apparently activated in reForis. If I look in Luci under “DCHPC and DNS” on the “DNSSEC” tab, no checkmark is activated there. Does this check mark have to be set additionally or does it have no function?
WAN Interface:
I had previously configured “Use custom DNS servers” in the WAN interface. Is this also still necessary in Turris via Luci or is this also maintained via reForis under “DNS Settings”?
It’s just not clear to me yet what should be maintained in reForis and what in Luci or Shell.
As far as the points mentioned are concerned, it is simply important to me that DNSSEC is configured correctly and that the Turris OS itself uses the DNS servers I want and not those of the provider.
Ok one last question just to be sure
My point DHCP and DNSSEC I think this is more clearer for me now. The third point “WAN”. This is as I aspected or? This option is better to set about reForis “DNS” right?
Yes, in reForis “DNS” tab. Though I think in its WAN tab you can also override what your ISP’s DNS resolvers are and then choose in “DNS” tab to use those. But in the DNS tab you can choose whatever anyway.
