Hello all,
after update to 3.10.1 I cannot run pkgupdate. I have this error message:
root@turris:~# pkgupdate
WARN:Couldn’t read the status file: [string “backend”]:1172: [string “backend”]:1163: Failed to lock the lock file //var/lock/opkg.lock: Resource temporarily unavailable
line not found
line not found
line not found
ERROR:
root@turris:~#
in LUCI is the same:
Collected errors:
opkg_conf_load: Could not lock /var/lock/opkg.lock: Resource temporarily unavailable.
Restart does not help, some services are not working (NAS, OpenVPN server, Sending of uCollect data, Sending of firewall logs, Cloud backup), access to internet (router + switch) is working
It means that update is in progress, it should resolve itself after a while. Reboot doesn’t help as with reboot you interrupt the update and once your router boots up, it starts updating again.
Thanks @bdeblier, I just stopped ddns service, killed pkgupdate and run it manually. It finished successfully, after reboot everything is running correctly.
The update remains blocked executing ddns-scripts's post-installation scripts until the ddns service is stopped manually as @bdeblier suggests, at least for 10 minutes (when I ran out of patience), perhaps indefinetly. When ddns is stopped the updater process immediately resumes the remaining operations. Hard to believe this is expected behaviour.
It is expected behavior as updater is waiting for script to do its thing. It would be killed in the end but timeout to termination is 100 minutes so 10 minutes is really short time compared to it. It is not updater’s fault that script is not terminating, it is fault of author of that script.
