I tried to configure VLANs using DSA but failed in a state where my bridge in in an unstable state and surely miss something important (being new to VLANs, I assume the problem is between the keyboard and the chair)
I got to this state 3 times, each time starting back from a fresh rollback to the post upgrade status thanks to schnapps, so maybe someone more knowledgeable will point me to the right direction.
What I try to achieve as a test scenario (simpler than my future config) :
- having LAN2 serve VLANs 11 et 12 both tagged (will go to a managed switch)
- having LAN4 serve VLAN 11 as untagged (and PVID)
How I tested :
- I configured a bridge (br-vlans) with LAN2 and LAN4 in it, and configured VLANs through luci as described (result in /etc/config/network hereunder)
- I added 2 interfaces with their own firewall zone and dhcp server (10.95.vlan_id.1/24)
- before playing with the switch, I just plug a Linux laptop in LAN4 and define VLANs on it with
ip link add link enp0s3 name enp0s3.11 type vlan id 11
ip link add link enp0s3 name enp0s3.12 type vlan id 12
ip link set dev enp0s3.11 up
ip link set dev enp0s3.12 up
The results I managed to get and errors I encountered :
At first it was working with the laptop, and event with the switch. I played a bit with the tagged / untagged / PVID to to understand how the switch would choose its ip and in my tests had to reboot …
after reboot, bridge does not seem to work anymore
NB : On the Omnia, my standard LAN (br-lan) is untouched and working, as access to WAN and WG connection
in dmesg, lots of lines like
[ 689.222379] mv88e6085 f1072004.mdio-mii:10: port 2 failed to delete 26:f8:91:81:a9:7f vid 12 from fdb: -2 [ 689.232089] mv88e6085 f1072004.mdio-mii:10: port 2 failed to delete 26:f8:91:81:a9:7f vid 11 from fdb: -2 [ 689.279503] mv88e6085 f1072004.mdio-mii:10: port 2 failed to add 26:f8:91:81:a9:7f vid 12 to fdb: -95 [ 689.295251] mv88e6085 f1072004.mdio-mii:10: port 2 failed to add 26:f8:91:81:a9:7f vid 11 to fdb: -95 [ 689.382169] mv88e6085 f1072004.mdio-mii:10: port 4 failed to add 26:f8:91:81:a9:7f vid 12 to fdb: -95 [ 689.397741] mv88e6085 f1072004.mdio-mii:10: port 4 failed to add 26:f8:91:81:a9:7f vid 11 to fdb: -95 [ 689.427176] mv88e6085 f1072004.mdio-mii:10: port 4 failed to delete 26:f8:91:81:a9:7f vid 12 from fdb: -2 [ 689.436955] mv88e6085 f1072004.mdio-mii:10: port 4 failed to delete 26:f8:91:81:a9:7f vid 11 from fdb: -2 [ 689.485222] mv88e6085 f1072004.mdio-mii:10: port 4 failed to add 26:f8:91:81:a9:7f vid 12 to fdb: -95 [ 689.501989] mv88e6085 f1072004.mdio-mii:10: port 4 failed to add 26:f8:91:81:a9:7f vid 11 to fdb: -95 ...
in /var/log/messages (same lines as in dmesg, plus )
Nov 1 14:55:41 omnia kernel: [ 17.646307] mv88e6085 f1072004.mdio-mii:10: p2: hw VLAN 1 already used by port 0 in br-lan Nov 1 14:55:41 omnia kernel: [ 17.660506] mv88e6085 f1072004.mdio-mii:10: p2: hw VLAN 1 already used by port 0 in br-lan Nov 1 14:55:41 omnia kernel: [ 17.706544] mv88e6085 f1072004.mdio-mii:10 lan2: failed to initialize vlan filtering on this port Nov 1 14:55:41 omnia kernel: [ 17.760222] br-vlans: port 1(lan2) entered blocking state Nov 1 14:55:41 omnia kernel: [ 17.765646] br-vlans: port 1(lan2) entered disabled state Nov 1 14:55:41 omnia kernel: [ 18.505259] device lan4 entered promiscuous mode Nov 1 14:55:41 omnia kernel: [ 18.514154] mv88e6085 f1072004.mdio-mii:10: p4: hw VLAN 1 already used by port 0 in br-lan Nov 1 14:55:41 omnia kernel: [ 18.527133] mv88e6085 f1072004.mdio-mii:10: p4: hw VLAN 1 already used by port 0 in br-lan Nov 1 14:55:41 omnia kernel: [ 18.586495] mv88e6085 f1072004.mdio-mii:10 lan4: failed to initialize vlan filtering on this port Nov 1 14:55:41 omnia kernel: [ 18.644434] br-vlans: port 1(lan4) entered blocking state Nov 1 14:55:41 omnia kernel: [ 18.649876] br-vlans: port 1(lan4) entered disabled state
brctl show gives (strange that br-vlans is empty …) :
bridge name bridge id STP enabled interfaces br-lan 7fff.d858d70036f9 no wlan0 lan0 wlan1 br-vlans 7fff.000000000000 no
ip address :
35: br-vlans: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000 link/ether c2:69:68:xx:xx:xx brd ff:ff:ff:ff:ff:ff 36: br-vlans.12@br-vlans: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000 link/ether c2:69:68:4exxxx:xx brd ff:ff:ff:ff:ff:ff inet 10.95.12.1/24 brd 10.95.12.255 scope global br-vlans.12 valid_lft forever preferred_lft forever 37: br-vlans.11@br-vlans: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000 link/ether c2:69:68:xx:xx:xx brd ff:ff:ff:ff:ff:ff inet 10.95.11.1/24 brd 10.95.11.255 scope global br-vlans.11 valid_lft forever preferred_lft forever
ip link :
35: br-vlans: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000 link/ether c2:69:68:xx:xx:xx brd ff:ff:ff:ff:ff:ff 36: br-vlans.12@br-vlans: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 link/ether c2:69:68:4exxxx:xx brd ff:ff:ff:ff:ff:ff 37: br-vlans.11@br-vlans: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 link/ether c2:69:68:xx:xx:xx brd ff:ff:ff:ff:ff:ff
/etc/config/network
config device option type 'bridge' option name 'br-vlans' list ports 'lan2' list ports 'lan4' config bridge-vlan option device 'br-vlans' option vlan '11' list ports 'lan2:t' list ports 'lan4:u*' config interface 'vlans_11' option device 'br-vlans.11' option proto 'static' option ipaddr '10.95.11.1' option netmask '255.255.255.0' config bridge-vlan option device 'br-vlans' option vlan '12' list ports 'lan2:t' config interface 'VLANS_12' option device 'br-vlans.12' option proto 'static' option ipaddr '10.95.12.1' option netmask '255.255.255.0'
/etc/config/dhcp
config dhcp 'vlans_11' option interface 'vlans_11' option start '10' option limit '10' option leasetime '2m' option force '1' list ra_flags 'none' config dhcp 'VLANS_12' option start '100' option limit '150' option interface 'VLANS_12' option leasetime '2m' list ra_flags 'none'
