[SOLVED] How to configure stunnel?
I installed the OpenVPN package in reforis and that’s working fine. However, I want to tunnel my OpenVPN connection through stunnel. Normally, I would just edit /etc/stunnel/(whatever).conf to point to my OpenVPN server, then create an OpenVPN configuration file that points to 127.0.0.1:(stunnel_port).
There is an /etc/stunnel/ folder on my Turris Omnia router, but stunnel seems to ignore configuration files there. For example, if I set the configuration file there to have stunnel listen on port 1413 and then restart stunnel, stunnel is still listening on port 6000 according to ss -lnpt.
Instead, when I restart the stunnel service, the following appears in /var/log/messages:
messages:Aug 11 11:19:40 turris stunnel: LOG5[ui]: Reading configuration from file /tmp/etc/stunnel.conf
I’m guessing I shouldn’t edit that file directly since, being in /tmp, it will be lost when the router restarts? I’m not sure how it is generated. It doesn’t seem to be copied from anything in /etc/stunnel.
I’ve googled and looked through the docs and this forum but I don’t see anything about how to configure stunnel. I looked through the UI (reforis and luci) and don’t see any way to configure it there either. Apologies if this is someplace obvious and I just overlooked it.
Edit 20240813: As an experiment, I tried changing /tmp/etc/stunnel.conf to listen on a different port, and then restarted the stunnel service. As expected, that caused /tmp/etc/stunnel.conf to be overwritten, and my changes were ignored.
Okay, I ran service stunnel info and that led me to /etc/init.d/stunnel which might shed some light on things. Looks like this might be an OpenWRT issue.
Found the real stunnel configuration, it’s in /etc/config/stunnel. I should be out of the woods now, but I haven’t quite gotten stunnel working yet, so I’ll mark this solved once I do.
Edit 20240814: That was it. stunnel is working now. I’m marking this solved. One last thing - I want to use tshark or wireshark to verify stunnel is working as expected, but opkg tells me it doesn’t know about either package. If anyone knows what package I should install for this I would appreciate it.
Thank you!
opkg update
opkg install tcpdump
Thank you for your reply! However, after running opkg update, I get the following:
root@turris:~# opkg install tcpdump
Package tcpdump (4.99.4-1) installed in root is up to date.
root@turris:~# tshark
-ash: tshark: not found
root@turris:~# wireshark
-ash: wireshark: not found
root@turris:~# opkg install tshark
Unknown package 'tshark'.
Collected errors:
 * opkg_install_cmd: Cannot install package tshark.
root@turris:~# opkg install wireshark
Unknown package 'wireshark'.
Collected errors:
 * opkg_install_cmd: Cannot install package wireshark.
I’m looking for tshark specifically because I want to verify my traffic is encrypted with TLS, e.g.
sudo tshark -i eth0 | more
# Without stunnel
1 0.000000000 (IP 1) → (IP 2) UDP 83 443 → 39627 Len=41
2 0.000224008 (IP 2) → (IP 1) UDP 83 39627 → 443 Len=41
#With stunnel
5 7.316491889 (IP 1) → (IP 2) TLSv1.2 138 Application Data
6 7.365448081 (IP 2) → (IP 1) TLSv1.2 138 Application Data
I’ve been looking to see how to do that with tcpdump but haven’t figured it out yet.
Thank you!
If you have tcpdump installed on your Turris router then you could use Remote capture session on your laptop’s wireshark gui:
