root@turris:~# ls -lisa /usr
510 0 drwxr-xr-x 1 root root 44 Aug 20 21:17 .
256 0 drwxrwxr-x 1 root root 272 Sep 8 23:40 … <<< here is not the same
511 0 drwxr-xr-x 1 root root 2968 Sep 2 18:49 bin
855 0 drwxr-xr-x 1 root root 8704 Sep 8 20:23 lib
853 0 drwxr-xr-x 1 root root 30 Sep 2 16:45 libexec
701 0 drwxr-xr-x 1 root root 1494 Sep 7 21:27 sbin
5567 0 drwxr-xr-x 1 root root 370 Sep 2 16:51 share
Can you do a
chmod 755 /usr
Then again post the ls -lisa /usr
Done:
root@turris:~# chmod 755 /usr
Oke, you have to do the next commands. The first 2 commands, is to show you that i got the same permissions as you and the later command chmod 755 ..
puts it back to.
Follow through
root@K-Router:/# chmod 775 ..
root@K-Router:/# ls -lisa /usr
2044 0 drwxr-xr-x 1 root root 44 May 3 06:58 .
256 0 drwxrwxr-x 1 root root 134 Sep 9 12:09 ..
7618 0 drwxr-xr-x 1 root root 4252 Aug 22 22:40 bin
2519 0 drwxr-xr-x 1 root root 11656 Aug 22 22:40 lib
7614 0 drwxr-xr-x 1 root root 148 Aug 22 22:40 libexec
2045 0 drwxr-xr-x 1 root root 2618 Aug 22 22:40 sbin
2191 0 drwxr-xr-x 1 root root 522 Jun 27 11:03 share
root@K-Router:/# chmod 755 ..
256 0 drwxr-xr-x 1 root root 134 Sep 9 12:09 ..
Ready:
root@turris:~# chmod 775 ..
256 0 drwxrwxr-x 1 root root 272 Sep 8 23:40 ..
root@turris:~# chmod 755 ..
256 0 drwxr-xr-x 1 root root 272 Sep 8 23:40 ..
Oke, nou try again with
opkg remove kmod-fs-ext4
Then
opkg install kmod-fs-ext4
root@turris:~# opkg remove kmod-fs-ext4
Removing package kmod-fs-ext4 from root...
Removing package kmod-fs-ext4_4.4.150+1-1-0a333a8e606ab056173befac424900d2-1
root@turris:~# opkg install kmod-fs-ext4
Installing kmod-fs-ext4 (4.4.150+1-1-0a333a8e606ab056173befac424900d2-1) to root...
Downloading https://repo.turris.cz/omnia/packages//base/kmod-fs-ext4_4.4.150+1-1-0a333a8e606ab056173befac424900d2-1_mvebu.ipk
100 1231 100 1231 0 0 4789 0 --:--:-- --:--:-- --:--:-- 4789
Configuring kmod-fs-ext4.
root@turris:~# mkf
mkfifo mkfs.btrfs
can you do a ls -lisa /
7879 4 -rw------- 1 root root 1024 Feb 27 2018 .rnd
257 0 drwxr-xr-x 1 root root 654 Aug 19 04:16 bin
328 0 drwxr-xr-x 1 root root 120 Aug 22 22:43 boot
82471 68 -rw------- 1 root root 208896 Aug 19 16:41 core
1488 0 drwxr-xr-x 8 root root 1840 Sep 9 00:12 dev
333 0 drwxr-xr-x 1 root root 1920 Sep 9 00:33 etc
74648 4 -rwxr-xr-x 1 root root 78 Sep 14 2017 init
1480 0 drwxr-xr-x 1 root root 624 May 2 02:58 lib
1927 0 drwxr-xr-x 1 root root 44 Feb 27 2018 mnt
1 0 dr-xr-xr-x 269 root root 0 Jan 1 1970 proc
1929 0 drwxr-xr-x 1 root root 8 Aug 19 04:16 rom
1931 0 drwxr-xr-x 1 root root 240 Jul 14 20:54 root
13541 0 drwxr-xr-x 1 root root 50 Feb 27 2018 run
1932 0 drwxr-xr-x 1 root root 1650 Aug 19 04:16 sbin
12921 0 drwxr-xr-x 1 root root 32 May 10 14:18 srv
1 0 dr-xr-xr-x 11 root root 0 Aug 30 20:56 sys
1464 0 drwxrwxrwt 32 root root 1400 Sep 9 12:33 tmp
2044 0 drwxr-xr-x 1 root root 44 May 3 06:58 usr
7799 4 lrwxrwxrwx 1 root root 3 Feb 27 2018 var -> tmp
7800 0 drwxr-xr-x 1 root root 48 Feb 27 2018 www
7416 4 -rw------- 1 root root 1024 Sep 2 16:45 .rnd
264 0 drwxr-xr-x 1 root root 654 Sep 2 16:52 bin
260 0 drwxr-xr-x 1 root root 120 Sep 2 16:51 boot
41 0 drwxr-xr-x 7 root root 1800 Sep 8 20:20 dev
6263 0 drwxr-xr-x 1 root root 1612 Aug 20 20:22 etc
8851 4 -rwxr-xr-x 1 root root 78 Sep 14 2017 init
21906 4 -rw-r--r-- 1 root root 1231 Sep 8 23:40 kmod-fs-ext4_4.4.150+1-1-0a333a8e606ab056173befac424900d2-1_mvebu.ipk
5838 0 drwxr-xr-x 1 root root 582 Aug 20 20:23 lib
6261 0 drwxr-xr-x 1 root root 20 Sep 2 16:46 mnt
259 0 drwxr-xr-x 1 root root 0 Oct 5 2016 overlay
1 0 dr-xr-xr-x 147 root root 0 Jan 1 1970 proc
398 0 drwxrwxr-x 1 root root 8 Sep 2 16:43 rom
6262 0 drwxr-xr-x 1 root root 52 Sep 2 19:46 root
400 0 drwxr-xr-x 1 root root 806 Sep 2 16:51 sbin
328 0 drwxr-xr-x 1 root root 6 Jan 1 1970 srv
1 0 dr-xr-xr-x 11 root root 0 Sep 8 20:20 sys
1466 0 drwxrwxrwt 24 root root 840 Sep 9 13:34 tmp
510 0 drwxr-xr-x 1 root root 44 Aug 20 21:17 usr
257 4 lrwxrwxrwx 1 root root 4 Jan 1 1970 var -> /tmp
330 0 drwxr-xr-x 1 root root 48 Jan 1 1970 www
Oke, do a
rm kmod-fs-ext4_4.4.150+1-1-0a333a8e606ab056173befac424900d2-1_mvebu.ipk
Then
chmod 755 /rom
and try again with remove and install.
@Bazarov you have check the NAS option in the updater tab ? http://192.168.1.1/foris/config/main/updater/
=_=!,
i thought you already had done the basics and it did not work, but you haven’t even done the basics.
root@turris:~# rm kmod-fs-ext4_4.4.150+1-1-0a333a8e606ab056173befac424900d2-1_mvebu.ipk
rm: can't remove 'kmod-fs-ext4_4.4.150+1-1-0a333a8e606ab056173befac424900d2-1_mvebu.ipk': No such file or directory
How its possible? It`s here:
@Bazarov Check it and wait for update.
Because you did a opkg download
command of that file, so it downloaded to the root, which that is the root.
But please go and first install the NAS utilities. If you have done that, then reply.
Yeah!
With that checkbox i got what i need.
Such a fail, that`s my fault.
Sorry guys.
Thanks a lot, Big_Boss.
Oke, because you are a failure, donate $100.000 to @czlada and @Big_boss charity foundation.
have fun :P.
Do mark this topic as solved, choose the comment that solved, so others can also look for the solution.
@Big_boss Simple possibility is always right. Thank you for your hard work
