Moment I enable Morce on TOS 6.0.4, my logs get hammered with one rule and I have no idea how to disable it, generally I don’t care about ICMP requests on my local network or at least I’d like to whitelist MACs. I use it to automatically diagnose problems within the network so no reason for router to go haywire and lag because of it.
Uhm…is this serious?
Cause my syslog suddenly was one big torrent/flood of warnings…and no clue why , what, how, and why not
I assume this Morce is something for the cli wizzards.
I too installed it a while ago and I get a lot of similar alerts in the logs, but no notification in reForis or email notification, which I also activated. Then what is that “sh: nil: not found”? For the moment the service is in a state that is still too raw. Uninstalled and will try again in a few months/years.
Yes. The default configuration is very harmful. When you try to dismiss the hundreds of notifications in Reforis, your router will usually run out of memory. But that (“fortunately”) only happens if you fix the nil error.
The error is resolved by enabling notifications in the configuration file. The strange thing is that the notifications still do not come. Have you ever received notifications in reForis?
