I have the TO a few days up and running. One thing that’s really bordering me is that some websites open more or less quickly, others websites take seconds to react.
It’s not the time to load the website but the time between entering a URL and the showing of the first text/picture/add/etc.
After reading on this forum similar complaints/remarks in relation to DNS issues are made although i’m not knowledgeable enough to judge that DNS is the culprit.
I tried using the Google DNS servers (8.8.8.8 and 8.8.4.4) and different browsers to improve the response time from websites (like fifa.com) but with very limited improvement. I installed back my old router (Asus RT-N66) and these websites open instantly so i guess its a TO thing.
Does anybody else experience this behavior, is there a fix?
Luci : Network : DHCP and DNS : Advanced Settings : DNS server port
You will loose DNSSEC support by disabling kresd resolver and moving to dnsmasq.
Other option is to disable IPv6 either in Omnia or host, or in both. The host or Omnia is most likely doing AAAA record queries for IPv6 and when they fail (timeout) it will fallback to A record queries for IPv4.
