It might perhaps be interesting for TO users to share here benchmarks of wireguard’s bandwidth/throughput performance in their real life enviroment compared to other vpn solutions, that is not in the local LAN but over public WAN.
Unless there is a remote WAN vpn exit node involved which is controlled by the TO user it will probably a VPN provider’s exit node with unknown bandwidth capabilites and thus benchmark results may only be rather indicative.
Particularly interesting might be the loss of bandwidth due to the cryptographic overhead of the various vpn solutions compared to the bare connection with the ISP.
Haven’t yet got around to test wg (will update here once done) but let’s start with an openvpn benchmark as baseline
ISP promise 100 Mbps down | 20 Mbps up
NetMetr average ~92 Mb/s down | ~20 Mb/s up
Ovpn | WG exit node promise 150 Mbps down | 150 Mbps up
Ovpn | WG exit node actual meter > 150 Mbps down | > 150 Mbps up
Ovpn TO client actual meter ~ 50 Mbps down | ~ 20 Mbps up
Ovpn TO client bandwith loss ~46 % down | 0 % up
WG TO client actual meter ~ 82 Mbps down | ~19 Mbps up
WG TO client bandwidth loss ~ 11 % down | ~5 % up
The Ovpn | WG exit node is controlled by me (except for the bandwidth provision), utilizes TUN | WG UDPv4 and the physical distance between TO router and the exit node is in the range of 1.500 km.
Loss percentage is calculated against the NetMetr figure and not the ISP promise.
Just updated the figures. Mind you that may not be a blueprint for every other setup and outcome may differ.
The speed test was conducted with OpenVPN v 2.4.4 on the TO side and v 2.4.6 on the server (with a heavy encryption implementation - ECDHE-ECDSA-WITH-AES-256-GCM-SHA384, tls-crypt, ecdh-curve secp521r1, dhpram 4096 bit).
WG on the other hand v 0.0.20171017 on the TO and v 0.0.20180708 on the remote endpoint (server) and utilizing a preshared key.
This is an update on wireguard now with version 0.0.20181007 on the remote endpoint and having the SQM instance for the wireguard interface on the TO disabled (SQM instance for WAN interface still enabled).
Download (bandwidth in Mbps)
exit node
promised bandwidth
actual measured bandwidth
bandwidth loss (promise vs actual)
bandwidth loss lowest actual ISP (local here) vs actual VPN
local ISP
100
~ 92
~ 8 %
remote ISP
> 150
> 150
0 %
OpenVPN
~ 50
~ 46 %
WG
~ 84
~ 9 %
Upload (bandwidth in Mbps)
exit node
promised bandwidth
bandwidth loss lowest actual ISP (here local) vs actual VPN
