Since my recent upgrade to Turris OS 5 with my omnia, I’ve been having issues with shairport (AirPlay) in my home setup.
Is there any mDNS issue or setting I need to look at to allow broadcasts to happen between switches and AP that extend the signal?
I can typically only discover AirPlay devices that are close to a specific switch/AP and only when I switch Wi-Fi AP range, I can then see the other “belonging” air play devices. This limitation only happens with Linux based shairport enabled devices but not with Apple airplay ones (appletv/minipods/LG TVs).
Also if not mainly, when directly served by omnia’s Wi-FI to my iOS device which is seeking airplay devices, I can’t see the shairport at all. If I move the shairport device and connect it to another wired AP switch then it shows up only if the client is also close by to the same AP.
