Setup USB Printer to share in LAN
Hello Guys,
anyone out there who managed to share a printer over turris?
I found the option to add Printer support on the fotis Webinterface, but no was to configure which Printer I use.
So I took a look at this HOWTO
https://wiki.openwrt.org/doc/howto/p910nd.server
I managed to get the printer listet in the USB list of the router.
But If I try to print from OSX nothing happens.
I’m very new to openWRT-Based routers.
So I you could give me a hint where to get more Info about Setting up a Brother HL-1250 to work with the turris it would be great.
Thanks to all
Toking
Looking on the brother page at the specification it is written that it supports network.
http://support.brother.com/g/b/spec.aspx?c=us&lang=en&prod=hl1250_all
Solution	NC-2010P(Optional)
Interface	10BaseT
Protocol	TCP/IP, Appletalk, Netware, DEC LAT, Banyan VINES, NetBEUI, DLC/LLC
Or is your printer one of those who does not offer this option?
If that is the case, have you thought about a “print server”?
Or maybe there are other users who have managed to set up a usb-printer on the Omnia.
I have running a P910ND server myself and you don’t have to configure much, all the work can be done through the luci webinterface. This is a dumb question but did you started server in software -> startup?
Sometimes Life can be so simple if one knows the correct way.
Perhaps there are more beginners to this topic out there, so I’ll try to describe how my Printer-Setup was done:
  1. Step install p910nd Printer-Server
Login to Luci
Navigate to System>Software
Klick on Available Packages an search for p910nd -> klick install
  1. Step Enable p910nd
    Navigate to System>Startup
    locate p910nd and klick enabled
  2. Step Configure p910nd
    You should now find an entry p910nd - Printer server within Service
    Klick “enable” and Select the Interface Lan
    save and Apply
  3. Step Client Configuration
    I use MacOS
    Open Prefrences>printers&Scanners
    Klick the + Symbol
    Chose IP
    Enter the ip or dns-Name of your router
    Chose Protocol HP-Jetdirect-Socket
    Chose the correct Printdriver
Now everything should work fine.
Thanks to @Codetux and @Big_boss
Greetings
Toking
I followed the same steps for my Brother DCP 7010L, an older laser printer without network interfaces. Initially, I could not get it to work, although I could see that the p910nd print server was listening and receiving requests on port 9100:
root@turris:~# netstat -an | grep 9100
tcp 6 0 192.168.1.1:9100 0.0.0.0:* LISTEN
tcp 0 0 192.168.1.1:9100 192.168.1.175:59230 SYN_RECV
tcp 1 0 192.168.1.1:9100 192.168.1.248:59676 CLOSE_WAIT
tcp 1 0 192.168.1.1:9100 192.168.1.248:59680 CLOSE_WAIT
In my case, the solution was to uncheck “Bidirectional mode” on the LuCI p901nd configuration page. Since then, all is well. :grinning:
Has anyone had luck with setting up a Brother DCP 130C? I have tried both options, CUPS and p910nd. By looking at the specs page I am guessing it won’t work as a network printer.
