I wanted to set up Set Let’s Encrypt certificate for web GUI according to the wiki - Let’s Encrypt certificate for web GUI
However, the wiki seems outdated or missing important information as I run into scores of errors upon running /root/.acme.sh/get_acme.sh
Is there anyone to guide me through the correct setup? I can even create a step by step guide for Turris Mox based on the information possibly provided in this thread, hopefully.
The full log is below:
# /root/.acme.sh/get_acme.sh
Warning: Option @zone[1].sentinel_dynfw is unknown
Warning: Option @zone[1].sentinel_fwlogs is unknown
Warning: Option @zone[1].sentinel_minipot is unknown
Warning: Option @zone[1].haas_proxy is unknown
Warning: Section 'turris_vpn_client' has no device, network, subnet or extra options
Warning: Section @zone[3] (tr_vpn_cl) has no device, network, subnet or extra options
* Clearing IPv4 filter table
* Clearing IPv4 nat table
* Clearing IPv4 mangle table
* Populating IPv4 filter table
* Rule 'Allow-DHCP-Renew'
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Rule 'Allow-IPSec-ESP'
* Rule 'Allow-ISAKMP'
* Rule 'guest dns rule'
* Rule 'guest dhcp rule'
* Rule 'vpn_turris_rule'
* Redirect 'Turris Lets encrypt'
* Forward 'lan' -> 'wan'
* Forward 'tr_guest' -> 'wan'
* Forward 'lan' -> 'tr_vpn_cl'
* Forward 'vpn_turris' -> 'lan'
* Forward 'lan' -> 'vpn_turris'
* Forward 'vpn_turris' -> 'wan'
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Populating IPv4 nat table
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Populating IPv4 mangle table
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Clearing IPv6 filter table
* Clearing IPv6 mangle table
* Populating IPv6 filter table
* Rule 'Allow-DHCPv6'
* Rule 'Allow-MLD'
* Rule 'Allow-ICMPv6-Input'
* Rule 'Allow-ICMPv6-Forward'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Populating IPv6 mangle table
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Set tcp_ecn to off
* Set tcp_syncookies to on
* Set tcp_window_scaling to on
* Running script '/usr/libexec/sentinel/firewall.sh'
Warning: Sentinel-firewall include reordered: another firewall reload suggested!
iptables v1.8.7 (legacy): can't initialize iptables table `raw': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
ip6tables v1.8.7 (legacy): can't initialize ip6tables table `nat': Table does not exist (do you need to insmod?)
Perhaps ip6tables or your kernel needs to be upgraded.
ip6tables v1.8.7 (legacy): can't initialize ip6tables table `raw': Table does not exist (do you need to insmod?)
* Dynamic blocking on zone 'wan'
- input
- forward
* Logging of zone 'wan'
- DROP
- REJECT
* HaaS proxy on zone 'wan' (22 -> 2525)
* Minipot FTP on zone 'wan' (21 -> 2133)
* Minipot HTTP on zone 'wan' (80 -> 8033)
* Minipot SMTP on zone 'wan' (25 -> 5873)
* Minipot SMTP submission on zone 'wan' (587 -> 5873)
* Minipot Telnet on zone 'wan' (23 -> 2333)
/root/.acme.sh/get_acme.sh: line 17: can't open DOMAIN: no such file
/root/.acme.sh/get_acme.sh: line 20: can't open DOMAIN: no such file
2024-10-26 10:19:24: (../src/mod_openssl.c.3141) SSL:openssl library version is outdated and has reached end-of-life. As of 11 Sep 2023, only openssl 3.0.0 and later continue to receive security patches from openssl.org
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_cl'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
