Hi guys,
This is has been an issue since forever on all of my Turris Omnias.
ReForis shows the Senitnel “Firewall Logs” as “Failed”.
Logs show:
Oct 23 19:02:04 sentinel-fwlogs[21568]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 23 21:02:05 sentinel: INFO [certgen.action_spec_init:89] Valid certificate found
Oct 23 19:02:08 procd: Instance sentinel-minipot::instance1 pid 5128 not stopped on SIGTERM, sending SIGKILL instead
Oct 23 19:02:11 sentinel-fwlogs[22034]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 23 19:02:17 sentinel-fwlogs[22047]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 23 19:02:24 sentinel-fwlogs[22056]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 23 19:02:31 sentinel-fwlogs[22063]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 23 19:02:37 sentinel-fwlogs[22076]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 23 19:02:37 procd: Instance sentinel-fwlogs::instance1 s in a crash loop 6 crashes, 1 seconds since last crash
With the update to TOS 6.0 I made a fresh install and re-configuration from scratch on one of them, but this still fails.
Starting manually show the same error once:
$ sentinel-fwlogs --verbose
