Using TOS 6.1.0 here.
This is my current situation:
- primary WAN configured on eth2, VLAN 835 using pppoe (FTTH connection 1)
- secondary WAN configured on eth3 using DHCP (LTE connection using cdc_ether driver)
I’ve setup mwan3 for failover and everything is working as expected.
Now I’ve got an additional FTTH connection (FTTH connection 2) and I’d like to use it as secondary WAN in place of the LTE connection. I’d like to ask for help in configuring LAN4 to connect with VLAN 100 using pppoe (let’s forget about the mwan3 for now).
My understanding from:
is that to use LAN4 as a WAN port I should assign it in the switch to use one of the native SOC ports, while leaving the ports LAN0-3 to use the other one.
How do I check the current switch configuration?
Is the default configuration still as in the diagram in this post (port4 to port 6, in other words lan4 to eth0)?
I’ve removed lan4 from the br-bridge as indicated here:
But it seems there is still something I’m missing as ip link
shows:
# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1024
link/ether d8:58:d7:00:8e:d9 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1508 qdisc mq state UP mode DEFAULT group default qlen 1024
link/ether d8:58:d7:00:8e:d7 brd ff:ff:ff:ff:ff:ff
4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1024
link/ether d8:58:d7:00:8e:d8 brd ff:ff:ff:ff:ff:ff
5: lan0@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP mode DEFAULT group default qlen 1000
6: lan1@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
7: lan2@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
8: lan3@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
9: lan4@eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/tunnel6 :: brd :: permaddr f669:cabb:315e::
11: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
12: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/gre 0.0.0.0 brd 0.0.0.0
13: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
14: erspan0@NONE: <BROADCAST,MULTICAST> mtu 1450 qdisc noop state DOWN mode DEFAULT group default qlen 1000
15: eth3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
link/ether 0c:5b:8f:27:9a:64 brd ff:ff:ff:ff:ff:ff
16: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 04:f0:21:32:40:e9 brd ff:ff:ff:ff:ff:ff
20: br-guest_turris: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
link/ether 06:f0:21:31:8f:4e brd ff:ff:ff:ff:ff:ff
22: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
24: eth2.835@eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
26: wlan1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP mode DEFAULT group default qlen 1000
link/ether 04:f0:21:31:8f:4e brd ff:ff:ff:ff:ff:ff
29: guest_turris_1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-guest_turris state UP mode DEFAULT group default qlen 1000
link/ether 06:f0:21:31:8f:4e brd ff:ff:ff:ff:ff:ff permaddr 04:f0:21:31:8f:4e
30: pppoe-wan: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1492 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 3
link/ppp
34: tun_turris: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 500
link/none
In particular, does the lan4@eth1
mean that the lan4 port is connected to eth1 (port 4 with port 5 of the switch)? How do I configure the switch to connect lan4 to eth0 (port 4 with port 6 of the switch)?
Thanks in advance.
P.S.: of course I’ve tried setting up a VLAN device eth1.100 and a new WANB interface with PPPoE, but that doesn’t work. To me, the issue is that LAN4 is connected to eth1 in the switch, along with the other LAN0-3 ports, while it should be connected to eth0.
